Question about Panasonic CT-32SL13 32" TV
TV does not come on at all.......would there be some replaceable fuse?
    Top Expert:
  • Panasonic Master
  • 74,383 Answers
Hello
Certainly there will be a replacable glass cartridge type fuse. It will be there, not only for Sanyo, but for all TVs. The fuse used is for protection. That is, if anything wrong happens to the power supply or its internal circuits, fuse will blow up, and prevent further damage to other components. Therefore, you must understand that if fuse in your TV has blown up, certainley there will be some reson for that. Without find that reason, and rectify it, never put a fuse there, it it has blown. It will cause more trouble to your device. Check it well. Find out the reason for the blown out fuse. Rectify it first, and then put a new fuse there. OK.
Posted on Mar 12, 2011
Keep blowing the main fuse.
To which circuit section did you replaced the fuse? Main power retulator? Just understand, the fuses are used to protect the circuit and TV from any short circuit or over voltage. Without any one of these, no fuse will blow up. If it was due to over voltage, the set should work after a fuse replacement. But here, the fuse blow up again, means, there is some thing shorted component/s. Check which component is shorted, and replace it, before replacing an other fuse. One more thing to say is, never insert a fuse other than specified. The voltage and ampere specification to fuse, will be marked at the circuit board, very near to the fuse clamp. Insert a fuse of same rating only. Using other fuse, rated higher ampere rating, might make things worse.
May 27, 2013 | Mitsubishi WD-73827 73" HDTV DLP TV
Problem with the JVC AV-36D503 36" TV.........TV will not turn on. Bought TV New in June of 2003...Dec 2003 the TV went Dead...They replaced the Safety Fuse. If same problem would you have any idea...
Tv might have more dead parts than just the safety fuse.If tv have only a power supply board fuse only they can do it for u wright there take the tv aparts and replace the tv power supply safety fuse like 15 mins job and will cost u like $40 dollars take it to any tvs repair shops.
Aug 25, 2011 | JVC AV-36D503 36" TV
Toshiba Model 51H84. Power breaker tripped during a storm. Breaker reset, and TV will not power on. Is there a fuse? Is there a reset button of some sort? How should I proceed? Thanks.
Your TV has a fuse on power circuit board ( that is a standard part).You need to resemble your tv to get the fuse ( make sure to disconnect all power and antenna before doing this service). Usually any tvs use a clear glass cover on fuse ( you can see a small conductor inside the glass). Replace the fuse if the small conductor gets broken. If after the fuse replacement, you got no joy on tv, the receiver part could be get problem also ( due to storm attack) and need to repair / replacement.
I hope the storm only attack your TV fuse.
Good luck
Aug 02, 2011 | Televison & Video
Tv at standby mode blown fuse fu120 2.5A.What next to do?
Unplug the TV from the power point.
Replace the fuse with the same value 2.5Amps
Do not put a higher value fuse in there because if there is a fault it may damage your TV.
When you replace the Fuse, plug the TV back into the power point.
If it works great, then it may have been a faulty fuse or power surge.
If the TV doesn't work then you may need a TV Technician to check the TV.
I hope this helps you.
If so please leave a vote or comment.
Have a Great Day
MobileJB
Jul 15, 2011 | Televison & Video
Is there a power fuse in this tv. sony 32" 1998 trinitron. Had great color, picture & sound. Will not turn on/no power.
There are fuses in most TV's... and in some cases, it's nothing but the fuse. BUT, the fuses are there to protect the circuits... so unless you know that there is nothing wrong with the TV, you shouldn't simply replace the fuse and plug it back in. However, if the TV is an older TV and it's either fix it by replacing the fuse or get rid of the TV... then I'd certainly take out the screws and check the fuses in the TV. But many times the fuse blows to protect it when something else fails... so if you find a blown fuse, look around for other signs.
WORKING ON ELECTRONICS should be done by professionals!! Proceed at your own risk!
Oct 08, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How to replace fuse on sanyo tv DS 24424
Actually, when a fuse blows, most of the time there is something that went bad and is causing the fuse to blow. Some TVs don't use the typical glass fuses. Instead the might use a surface mount soldered component. These components are usually labeled with the letter F for fuse. Example would be F1 or F2. They are usually found near the power cord or near the power supply. Hope this helps...
Feb 01, 2009 | Sanyo DS24424 24" TV
Fuse keeps blowing out on Panasonic CT36HL44J TV
Thanks for this post. It inspired me to replace my fuse in my TV and it is working great now... I took pics of the process in case anybody wants to see what they are in for. http://joedotcom.com/2009/09/01/panasonic-fuse/ Although I did use a 6.3a fuse (just like I removed). I read on another forum that you can replace it with a 7a fuse and get better results. I have had this TV for years and this is the first blown fuse. If it becomes a reoccuring theme, i may up it to the 7a.
Jan 14, 2009 | Panasonic CT-36HL43 36" TV
TV will not work
Hello dnjmartz,
Your friend is correct there is a fuse in your televisions's power supply. Now I do not however suggest that you open the TV set and try to find it, because it's not like the old days where the fuse was located in or around about the same area in most TVs . The fuse in this case might be towards the middle of the set or on the power supply board in any location so finding the fuse will be the biggest chore. However here are some simple instructions of how you might be able to find the fuse.
1. unplug the TV
2 take the back off of the tv
3. using a flashlight look for a component that looks like two round metallic cylinders separated by a glass cylinder.
4. remove the fuse from the fuse holder
5. visually inspect the fuse for internal burning (black soot)
6. if possible test the fuse with an ohmmeter should read 0 ohms
7. Replace the fuse with one of the same voltage and current rating (check for replacement fuses at radio shack or some place like that)
8. After the fuse is replaced try to turn on the TV before putting the back on "BE VERY CAREFUL DANGEROUS VOLTAGES ARE PRESENT"
9. If the TV comes on you are read to turn the TV off and put the back of the TV back on.
10 If the TV does not come back on you will have to get the set looked at by a qualified TV technician since if the TV does not come on it may be the result of a power supply malfunction.
I hope this helps,
Thank you,
Shuttle83
Jul 14, 2008 | Orion1934 19" TV
Samsung Flat Screen Won't turn On
yea take your tv to a tech tv has a problem in the power supply there is 10mf cap in the power supply that likes to go bad replace it if that model does not have it check regulator and the microchip.however your problem lies in the powerand related circuit.good luck
Apr 02, 2007 | Samsung TXN3275HF 32" TV
Panasonic CT-32SL13 32" TV Logo
153 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
