Question about HP Compaq 6735s Notebook
HP Compaq 6735s. When powering up, blue light is on and wireless light is on, but the drive light that should be blue is blinking yellow. Nothing on the screen. Is the hdd dead?
  • jb3529 Mar 15, 2011
    The computer is barely 2 years old and the motherboard is dead. I will never buy another HP.
  • 2,632 Answers
Welcome to Fixya. On your description it seems that there is a power on the laptop however we cant determine yet if the problem is the hard drive. We can so some steps to check if the problem is the hard drive or other components of the computer.
1. Can you remove the battery of the computer for 2 minutes after that connect it and turn it on. We'll try to power drain the system and see if it will work.
2. Is it possible for you to use an external monitor to check if the problem is the LCD. Press FN + F4 to toggle the display and see if the problem is with the LCD.
If NO display is shown on the external monitor you have a graphic chipset problem.
This requires replacement of the motherboard.
If the problem is with the hard disk you will still be able to see the POST screen.
If you wont be able to see this on an external monitor than the problem is the Graphic Chipset. but if you see it then the problem is the LCD of the laptop.
If you have questions please let me know. Thanks for using Fixya
Posted on Mar 13, 2011
Hi good morning, my hp 6735s doesnt display anything when I power it on. it flashes a quick brief light on the screen and keep blinking an orange light thereafter the caplock (blue) light comes on and...
Possible that PC is hanging up as there is fault on the OS ( operating system) or a virus in the OS. Also it is possible that the back up( CMOS) has low voltage or the memory card is a suspect. In this case you need to check the voltage and also try and swap a memory card. If not the OS is a suspect.
It is also possible that the mother board is faulty but can be confirmed only after you ensure that the memory and power supply is good.
Thank You for using Fixya
Aug 23, 2011 | HP Compaq 6735s Notebook
I am an owner of an HP Compaq 6735s Notebook PC. I have experienced the notebook failure. I am unable to start the computer at all. It just happened when I tried to restart it. I have noticed the...
my daughters hp 6735s had the fan running all the time issue, having got fed up with this I decided to try to fix it. I downloaded the service manual from the hp website and dismanteld the laptop to remove the motherboard. The fan defuser had some dust but not much, so I removed the heatsink that covers the cpu and gpu. I noticed the cpu did have thermal compound that was in contact with the heatsink, however the gpu had compound on the chip but nothing touching the heatsink. I cleaned the heatsink, cpu and gpu with degreaser, then applied new silver themal compound from maplin. I made sure i also applied a thin coating to the heatsink. I refitted the heatsink and reassembled the laptop. I powered on the laptop and instantly noticed the laptop fan running at half speed which it should do, I installed a program from a dvd and left the laptop running and so far so good. If we had left this any longer I suspect the solder under the gpu would have become molten and then we could have had another issue which maybe we could not have fixed. I hope this helps you if you have similar issues.
Jan 19, 2011 | HP Compaq 6735s Notebook
Hi my hp 6735s laptop has just started turning itself off when knocked or moved slightly. When you try and power back up the orange light around where the power lead plugs into the laptop flashes about 10...
Check the power cord at the connector. Hp has a problem with the cords breaking internally. I had a problem with mine and found that if I played with the cord then it worked for a while. I ended up buying a new power supply.
May 26, 2010 | HP Compaq 6735s Notebook
Compaq 6735s notebook pc goes to HP screen, but wont boot
First you need to determine how many blinks you are getting when you try to power on the laptop.
Check the blinking codes below and reason behind that for HP Compaq laptops
Blinking battery power LED Battery Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock - System board General system board failure
Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure
Plz get back so I can suggest you the steps to resolve the issue.
Dreamkam
May 24, 2010 | HP Compaq 6735s Notebook
Hewlett packard 6735s power up
Your battery is critically low. Didnt you recharge your battery? Try turning it on with the external power source connected.
Jan 14, 2010 | HP Compaq 6735s Notebook
HP Compaq 6735s battery light orange blinking
Have you tried another power cord? If you try another power cord, and it still does the same thing, then I think your laptop is having a power problem. You need to take is to a technician to fix the problem for you.
Best wishes.
Nov 28, 2009 | HP Compaq 6735s Notebook
Hp 6735s screen blank problem
If you use it from the power cable does it work better? There is a known issue with the 6735s and power management settings from battery.
Oct 02, 2009 | HP Compaq 6735s Notebook
HP Compaq 6735s Notebook Logo
618 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
