Question about Logitech C120 Webcam
I have a Logitech Webcam 120, I have had it for about a year and it recently started flashing green light all the time.
  • emily_friesz Mar 13, 2011
    Thank you for taking the time to post a step by step solution! This fixed it and was an easy fix!
    Problem Solver:
  • 17 Answers
Hi, how do u do?? I will write a step by step guide for ur problem, I had this problem before with my Logitech webgam
1. unplug webcam
2. unistall the driver (Start => Control Panel => Progrrams (for windows seven) add/remove... (for windows XP => Find Logitech Dirver and uninstall it) also there is a link with photo if u can't unistall the driver. (http://logitech-en-emea.custhelp.com/app/answers/detail/a_id/20388/section/troubleshoot/crid/435/lt_product_id/6065/tabs/1,3,2,5/cl/za,en/kw/
3.restart the computer.
4. find and download the latest driver here: http://www.logitech.com/en-za/435/6065?section=downloads
5. plug your webcam to a new USB port (not the one u used before) (for example, if u used the first port then u plug it to the second one)
6. Install the new Driver.
7. Restart the computer.
8. Your Problem will solved. (if u do these steps, and still have the same problem, u can double check the webcam maybe it's broken)
Posted on Mar 12, 2011
Testimonial: "Thank you very much!! This fixed the irritating blinking light! "
  • Logitech Master
  • 10,322 Answers
1st You download Webcam Driver.
Logitech Webcam After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Logitech Camera Drivers for Windows XP Vista Windows 7
Posted on Jan 24, 2014
No picture and green light flashes rapidly!!
Disconnect cam, restart computer, plug back in.
Nov 15, 2012 | Logitech C120 Webcam - Black
The green light on my lochtech webcam rapidly flashes all the time why is this ? the problem only started recently i have move it to other usb ports but to no avail
its not loaded to that particular usb port ,to keep this from happening get a hub and yu can switch it around and have more ports to work with
Jun 30, 2011 | Logitech WEBCAM C200
I have audio and video but my friend only has audio when we are using our web cam. Is the problem on my end or their end? This is the first time I've tried to use our webcam ( SKYPE) . It is a logitech...
logitech.com ... I've checked out their website before and had no luck with solving my webcam problems... BUT this time I found their website very helpful. I just had to follow a few of their very easy steps and my webcam problems were solved!
Jan 09, 2010 | Logitech Webcam
My camera quit working in skype, any suggestions in troubleshooting? the green light isnt coming on at all, it was working like 5 minutes ago
To test if the Logitech QuickCam is functioning, check the USB cable, make sure it is connected properly. Then click on Start - All Program - Logitech - Logitech QuickCam and see if you can get the camera to capture your image/video.
If this works then the fault is with the Skype configuration. Sometimes the WEBcam settings drop off and the WEBcam need to be selected again. Open Skype - Tools - Options - Video Settings and select the Logitech QuickCam
Also check the Audio Settings for the Microphone THEN click on Save.
Dec 14, 2009 | Logitech QuickCam Connect Webcam
I70 wont print & Printer Head won't return to the centre
The first error was waste ink near full which you can bypass with resume button, now the absorber is full which means it won't print until you have the drain pack replaced and the counter reset by a shop.
Aug 01, 2009 | Cannon i70 Printer
Logitech QuickCam Communicate MP - black screen
  1. Either one of these image sizes:
    • Small image size: 160 x 120
    • Large image size: 320 x 240
  2. RGB, I420, or IYUV formats. (Each is fine; we recommend RGB 24.)
  3. Microsoft DirectX version 9.0
To get this information, click here to download a Microsoft application that checks to see if your webcam device meets these requirements.
To make it easy, when you’re asked where to Save the program, just save it on your Desktop.
Once it’s downloaded, here’s what to do:
  1. Double-click the amcap.exe file on your desktop.
    • If you have more than one webcam installed, click the Devices menu and select the one you want to use.
  2. Click the Options menu, then click “Video capture Pin.”
  3. Under “Color Space/Compression:”, choose one of the following formats:
    • RGB 24 (our recommendation)
    • I420
    • IYUV
    Note: If one of the options above isn’t in the list, then your webcam is not compatible with Yahoo!7 Messenger.
  4. Under “Output Size”, choose one of the following:
    • 160 x 120
    • 320 x 240
  5. Click OK
  6. Close the ampcap application.
  7. From your desktop, click ‘Start’ and select ‘Run’.
  8. In the run box, type: dxdiag
  9. In the confirmation dialog box, click OK.
  10. On the System Tab under ‘System Information’, look for DirectXversion. Verify that your version is DirectX 9.0. If it is, just click Exit. If your version is older than 9.0 (any lower number), click here to download the latest version of DirectX.
  11. Start the webcam from Messenger by clicking My Webcam in the Messenger menu.
Attention Logitech webcam users:
Some Logitech webcam drivers may cause one of the following problems:
  • Windows freezes when accessing the webcam
  • A black screen appears when using the webcam in Messenger
  • A ‘Webcam not found’ error message appears.
  • After 3 seconds, the sound drops out of calls made via Messenger
If you already verified that your device is compatible through the above steps and you’re a Logitech webcam user, please click here to update your Logitech webcam driver.
Dec 16, 2008 | Computers & Internet
Webcam video email
you can save your video to wma , 3gp or any other playable formats, so that they can view it in a third party softwares like realplayer , divx or winamp etc..
or maybe they should install the latest activex and adobe flash player.
i hope it help.....
Aug 06, 2008 | Computers & Internet
Flashing light
cycle the batteries in a external charger a fex times (charge then discharge) I suspect that over the years of using then putting it in its dock the batteries have had a very erratic charge discharge cycle cycling them as I suggest should bring them back.
Jul 25, 2007 | Logitech MX 700 Mouse
Logitech C120 Webcam Logo
261 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
