Question about Dimplex DS5598 Mid-Size Heater
Change bulb on dimplex fire not sure of make and model
    Brigadier General:
  • 4,736 Answers
If it's a fireplace that sets inside a free standing cabinet mantle, you access the bulbs by removing the glass on the front (actually, it''s plexiglass). Then remove the logs and the glowing ember bed (It lifts out). Now you can see and have access to the bulbs to change them.
It it's wood stove look-a-like unit, you can access the bulbs by removing the rectangular panel on the back, near the bottom of the of the unit. Removal of that panel gives you access to the bulbs.
Hope this helps to answer your question.
Posted on Mar 12, 2011
  • zomba467 Aug 23, 2011
    You can download the repair manual for the Dimplex CS1205 from here: http://partner.dimplex.com/files/domain4...
    Very helpful!
4 Suggested Answers
SOURCE: How to replace fire bulb for Dimplex HTN20
Remove coals, then remove 2 screws L/R located 2nd bar down on brass feature front, withdraw brasswork, 2 lamps located under here...240V - 60W E14 SES clear candle lamp. Replace grate / fuel effect, secure with screws and add coal.
Posted on Nov 28, 2010
  • 4736 Answers
SOURCE: I need to change the
The plastic ember bed lifts out with a little effort. To assist you, I have included a link to your Bradford model Owners manual that you can download and print for future reference.
http://www.dimplex.com/customer_support/technical_and_troubleshooting?docsearch=GDS26-BW1052&type=&dlang=
Dave, I hope this helps you.
Posted on Apr 29, 2011
  • 4736 Answers
SOURCE: How do I change the
On the back of the cabinet, about 3" to 4" up from the bottom, you should see a removable rectangular panel. Removing it, will give you access to the bulbs. Which are 60 watt, small base chandelier bulbs.
Turn the unit OFF & Unplug it, before removing the rear access panel.
Hope this helped you and thanks for choosing FixYa.
Posted on Aug 24, 2011
How do I change the bulb in my dimplex wynford inset fire?
Aug 24, 2011 | Dimplex DS5603 Heater
I need to change the bulb in a dimplex brayford electric fire, how do I get the fake coal plastic off.
Apr 29, 2011 | Dimplex Compact Electric Flame Stove...
I need new light bulbs for my Dimplex Charlotte Optymist fire Model number CRT2OAB where can I get them
The model you have uses a different set of bulbs, than Dimplex's other models. So, you'll need to Contact Dimplex USA, Technical Service Dept @ 888-346-7539. I'm sure they can help you.
Mar 22, 2011 | Heating & Cooling
How to change bulbs on Dimplex HTN 20
If you have a compact fireplace in a cabinet mantle, you will need to remove the front Plexiglas and frame from the front of the firebox. Remove the logs, then the 1- piece ember bed (it just lifts out). This will give you access to the light bulbs.
If you what looks like an old wood stove, you access then from the rear of the unit. Remove the bottom access panel by unscrewing the 4 screws that hold it in place. You can then reach the light bulbs to change them.
In both cases, the replacement bulbs are small base chandelier bulbs.
Hope this helps to solve your problem.
Mar 11, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
We have a Dimplex Danesbury Dan 20 fire and need to change a bulb! How?
1.Remove the coals .
2.Remove the two screws in the front of the brass grate second bar down.
3.pull the grate assembly away from the fire.
4. The bulbs are now exposed.
Replace with 60 Watt SES clear candle bulbs. Reassemble in reverse order.
Oct 25, 2010 | Heating & Cooling
The heater on my dimplex fire appears to be working however i replaced dud bulbs with new bulbs, and they are not working?
dear sir/madam
have you checked for the power supply before changing the bulbs,if not please check it then you come back to us we will help you.
Aug 06, 2009 | Dimplex DS5598 Mid-Size Heater
I wanted an answer to this too. It was hard to find, but here we go.
Get hold of a torch, and look closely at the decorative surround at the bottom of the fire. There are two screws hidden in there, on each side! See below:
Unscrew these, and you can take the front off, and get at the bulbs.
For information, the fire takes two screw in bulbs, described as 240V – 60W E14 SES Clear Candle Lamps.
Hope this helps.
Feb 07, 2009 | Dimplex DS5598 Mid-Size Heater
Remote control working with fireplace.
try www.dimplex.com go to customer sevices they should be able put you on to a local dealer in your area
hope this is of some help
Dec 13, 2008 | Dimplex DS5603 Heater
Dimplex Model 3087S
I have the dimplex dancing fire W..20 and I've just managed to change the bulbs!!!! Take the coals out and turn the fire upside down. In the bottom you can get your hand in the middle and unscrew the bulbs. There are two and they face each other. It's a real pain and a large mans hand won't fit. You meed two 60watt candle small screw to replace them. hope this helps.
Nov 29, 2007 | Heating & Cooling
Dimplex DS5598 Mid-Size Heater Logo
544 people viewed this question
Top Dimplex Heating & Cooling Experts
paulcarew
ashburton
Kory Ronning
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
