Question about Samson C01U - USB Studio Condenser Microphone Consumer Microphone
I have 2 samson mics one usb the other audio the audo mic works well with my m box because i use protools but the usb mic does not how can i use both mics together
  • 604 Answers
The usb mic can't be used with the m box, it can be used as a source in your audio software however. When you assign your audio sources look for USB Codec in the choices. I have a USB mic and it works great
Posted on Mar 12, 2011
Do i need a driver for mic r21s to work on my compuer for karaoke?
No, but you do need one thing. You have two options. Option one is a Mixer with USB output or USB Interface. Option two is to buy a USB Audio Interface. Personally, I'd go with option one because you can control every aspect of the mic and the music or instrument. The USB Interface does need a driver but it is included. The R21S Mic is an XLR Dynamic Mic.
Apr 26, 2011 | Samson R21S Microphone
I have connected the samson mic to my computer. input not detecte
A condenser mic. requires "phantom power" usually supplied by a mixing desk. Without this, there will be no output signal from the mic.
Jan 12, 2010 | Samson C01U - USB Studio Condenser...
The mic does not record stereo anymore. when playing back a stereo works fine but when recording in stereomodus only the left channel records, the right channel seems to record silence/noise
This Mic is not a stereo Mic. If you're using a windows computer, check your sound control panel to see if the mic wasn't suddenly set to two channel device.
Sep 30, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Samson C01U USB mic not working on my PC.
try this;
1.using different usb inputs on your pc desk top
2.update drivers on both your desk top and laptop
3.using a different usb cable
if it works fine on your friends computer most likely its not the mic
Feb 25, 2009 | Samson Audio C01upak C01u Microphone and...
MY JOB DEPENDS ON THIS!!! SONY DSR PD170 AUDIO PROBLEMS
Appreciate the direct "Ask Me".
The Sony PD170 is not an everyday equipment, nonetheless, I will assume that on the Sony DSR PD170:
  • the Samson UHF M32 receiver is plugged to Audio 1;
  • boom mic is plugged to Audio 2; (or vice versa) and
  • Both Audio 1 & 2 are using the XLR connectors.
Assuming that your boom mic is a conventional dynamic, on the Audio Control Panel, pls set:
  • INPUT 1 -
  • MIC CH SELECT CH1&CH2
  • INPUT LEVEL MIC
  • +48 OFF
  • INPUT 2 -
  • INPUT LEVEL MIC
  • +48 OFF
This is of course assuming that both the boom mic and the output of the Samson UHF M32 receiver are set to MIC level. In some instances the Samson UHF M32 receiver requires a LINE setting. The only time the +48 is set to ON is when the mic that is used/plug in requires phantom power such as condenser types. If the mic or the Samson UHF M32 receiver requires power then this should be switched ON otherwise, there will be no audio coming in. Though most M32 uses a 9 volts battery.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 11, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
No recording?
The static after several seconds seems like this is a problem with certain versions of OS X. You might be able to fix it by downgrading or upgrading. Apple Forums say that it's fixed in 10.5.6.
You can double check that this is the problem by trying it on a Windows computer.
Jul 28, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Usb mic in cubase sx3
you have a pci audio card so maybe you can add an extra input device by going to devices panel or press F4 shortcut.
and choose your usb mic.
also you can check your wavelab audio inputs. they must have the same config so if you can record woth your usb mic and your poci card in wave lave you must be able to do so in cubase sx
hope it works
Apr 01, 2008 | Steinberg Cubase SX3 (502010600) for PC,...
Problem with Samson CO1U
Here are some instructions relayed from someone who was able to fix a similar problme with help from Samson tech support:
The C01U is a WAV device. Therefore, adjusting the slider for your default MIC input level on the volume control applet does not adjust the gain on the C01U. You access the actual volume control for the C01U as follows:
Start, Settings, Control Panel, Sounds and Audio Devices
Click on Audio tab.
Under "Sound Recording", insure that Default Device is selected as Samson C01U.
Once Samson C01U is selected as Default Recording Device, click on the Volume button just below the name. A new window will pop up, with a vertical slider. This window will be labelled "WAVE IN", however it actually does control the MIC volume for the C01U.
The key here seems to be that the USB device that represents the Microphone input (as far as Windows is concerned) is not a traditional microphone, but (as mentioned above) a WAV-IN device.
Jan 03, 2008 | Samson C01U Consumer Microphone
Playback only on left speaker
The quick, easy solution is to change your microphone to mono recording. In the attached YouTube clip, I'll show you how to do that.
The short and simple is to go to your Mac HD -> Applications -> Utilities -> Audio MIDI Setup. Select your C01U USB device, and set it to 1ch 16bit. This will set the microphone to record in mono, equally over both speakers.
Nov 26, 2007 | Samson C01U Consumer Microphone
Samson G-track - Vista requiring to install USB Audio Codec
If the LED doesn't light when you plug it in, and it doesn't show up in Device Manager ("USB Composite Device" or "USB Audio Device"), then the mic must be defective. Contact Samson for a replacement.
Nov 24, 2007 | Samson G-TRACK USB RECORDING MICROPHONE...
Samson C01U - USB Studio Condenser Microphone Consumer Microphone Logo
166 people viewed this question
Top Samson Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Umali
Vito Vacirca Jr.
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
