Question about Western Digital WD RE3 WD5002ABYS hard drive 500 GB SATA300 SATA II
My WD5002ABYS drive crashed and it won't format.
  • penteren Mar 12, 2011
    When you say it crashed, what do you mean? Are you able to access the drive at all?
  • Western Digital Master
  • 27,725 Answers
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
one bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Mar 12, 2011
External drive crashed
Formatting the drive, depending upon the type of format, is destructive of data. There are specialized recovery programs that can sometimes save the old FAT tables, but chances are you are out of luck. Many times these external drives fail because they are not built to handle the heat and shock/vibration that comes with being encased and mobile. Often it is not the drive itself that fails, rather the SATA/USB controller in the enclosure. I have seen many individuals pull their "failed" drives out of the enclosure, install it internally, and find all the data is still there.
Jan 11, 2015 | Hitachi Computers & Internet
Dban problem ( crash : "dev/sda" )
Use fdisk and / or format from command prompt. Easy and no fuss. gl
Nov 03, 2012 | Computers & Internet
I have a USB memory stick with data on it and it is now saying it needs formatting, What can I do to retrieve the data
If this (free) software won't recover the flash drive data, it is permanently
lost.
http://www.piriform.com/recuva/download - then select the version you want
From an experienced sysadmin:
Back up your flash drive to your hard drive, and your hard drive to your flash drive. When one crashes/gets lost/destroyed, the other survives without a desperation move like a data recovery utility like Recuva V1.42.
The first time through, Recuva V1.42 will run a "Wizard" which asks a few questions about which drive/files you're interested in. Check the appropriate boxes, and let it do its thing.
Dec 06, 2011 | Toshiba Computers & Internet
My flashdrive won't respond at all. I think that it was somehow disconnected on the inside, but I have no way of knowing. Is there any way that I can retrieve the data or fix the flashdrive?
you can try some data recovery software. You can see
http://www.asoftech.com/articles/undelete-files-from-usb-drive.html
It tells the steps how to perform data recovery.
If above does not work, you may have to format the flash drive (use quick format), and then use above mentioned software to scan again the flash drive and recover your files.
Sep 05, 2011 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Can i format my HD on an external bases with my laptop, then install it back into my pc. my hard drive crashed and i need to get it to boot. i dont have the boot disk
Technically, YES, the hard drive can be formatted as an external (with the appropriate equipment) on your laptop (if there are still files on it, you may even be able to extract them from it) but it still won't be bootable because it does not have an operating system on it.
That would be the part where you need the recovery disc. Windows setup programs from these boot discs already have the format utility so if there aren't any files to extract from the drive, you can skip to reinstalling Windows on the desktop and formatting it in the process.
Bottom line is that you need a Windows installation disc to make the hard drive bootable again, regardless of where you format it.
Aug 12, 2011 | E-Machines emachines (emachinees) CD-ROM...
Good morning. I have a question regarding hard disk WD5002ABYS that's running on a Cisco DVR for surveillance (CIVS-GM-ISP12-6TB). I need to reformat all the drives on it, 12 in all. How do I that?...
you have to format your hard drive using a third party disc to erase everything on your hard drive
Press and hold that key during the boot up process to enter BIOS the scroll to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE0 means Pri master
IDE1 means Pri slave
IDE2 means Sec master
IDE3 means Sec slave
or if you are using a USB
insert your usb drive
click start right click on my computer select open you should see your USB drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
also you might use a disk wipe utility
http://majorgeeks.com/Free_Disk_Wipe_d5309.html
Free Disk Wipe data cleanup and file wipe tool, that allows you to completely wipe/ remove / delete / erase a selected file(s) on most disks (floppy disks, hard disks, logical drives, etc).
Data recovery software can
Jul 14, 2011 | Western Digital WD RE3 WD5002ABYS hard...
My Avastor HDX Portable HD drive just crashed. I had it connected to my Mac, and when finished using it I wanted to eject the disc but it wouldn't, whatever i tried. So i disconnected it anyway. But...
Hi!
i dont know if your drive is dead , but try to connected to an Other Pc with different System (windows Xp Or 7 ) and see if it work try to formate it , but if he didn't work that's mean is dead ,
good Luck
May 23, 2011 | Avastor HDX-800 400 GB FireWire 400...
Computer crashed while USB was inserted. USB will no longer open.
Scan you pendrive for Virus from another computer who has effective antivirus program & it have latest Update.
Norton is my trusted.
Thanks.
Oct 06, 2009 | Lexar FireFly 1GB USB 2.0 JumpDrive - Blue
Display hardware or drive broken
format your laptops's harddrive and install the operating system. When computer crashes very often, it is better to format it and install the operating system. Don't opt for quick format. This will help you to detect bad sectors. If there is bad sector, you have to replace the hard disk.
Jan 30, 2009 | Acer Aspire 5920-6727 Notebook
Western Digital WD RE3 WD5002ABYS hard drive 500 GB SATA300 SATA II Logo
66 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
