DVD/CD don't work any more, not recognized by the computer. Driver is missing? Windows Vista
    Scholar:
  • 115 Answers
Try to go this website gur.in, click registry tweaks and on the Tech domain registry look for Restore missing CD drive. Just run it and allow. After that restart the laptop. Check if CD/DVD drive is back and test a disc.
Hope it works!
Posted on Mar 12, 2011
LITEON DVD/cd rewritable device not reconized
Since the system originally had another version of Windows did you run the Upgrade Advisor and
check the Compatibility Center for the CD/DVD compatibilty (and other devices as needed).
Windows 7 Upgrade Advisor - please run this now.
http://www.microsoft.com/windows/windows-7/get/upgrade-advisor.aspx
Also check the Compatibility Center (for major devices)
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
Check with the System maker and the Device maker for information about drivers for Windows 7.
(BIOS, low level chipset drivers, and other major device drivers).
Check these :
The DVD drive does not function after you install Windows 7 - these are different Sony drives
however the same issue could be affecting your drive.
http://support.microsoft.com/kb/975270/
Your CD drive or DVD drive is missing or is not recognized by Windows or other programs
http://support.microsoft.com/kb/982116
If the System can run Windows 7 AND there are drivers for the devices these might help :
References to Vista also apply to Windows 7.
Stage 1 : Please do all the below even if you have done some before as it is often the total
process which solves the issue.
Try this - Control Panel - Device Manager - CD/DVD - double click the device - Driver's Tab -
click Update Drivers (this will likely do nothing) - then RIGHT CLICK the drive - UNINSTALL -
REBOOT this will refresh the default driver stack. Even if drive is not shown continue
below.
Then work your way through these - remember the drive could be bad, could have a loose
cable or slight corrosion on the contacts (usually for a laptop) and other issues.
http://support.microsoft.com/kb/314060 - a Mr Fixit
Manually try this fix if the 314060 Fixit did not work
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Your CD drive or DVD drive is missing or is not recognized by Windows or other programs -
a Mr Fixit
The CD drive or the DVD drive does not work as expected on a computer that you upgraded to
Windows Vista
http://support.microsoft.com/kb/929461
When you insert a CD or a DVD, Windows Vista may not recognize the disc
http://support.microsoft.com/kb/939052
Your CD or DVD drive cannot read or write media - A Mr Fixit
http://support.microsoft.com/gp/cd_dvd_drive_problems
CD/DVD drive does not appear in Windows Vista, or you receive this error during Windows Vista
setup after booting from the DVD (AHCI)
http://support.microsoft.com/kb/952951
CD-R drive or CD-RW drive is not recognized as a recordable device
http://support.microsoft.com/kb/316529/
Hardware devices not detected or not working - A Mr Fixit
http://support.microsoft.com/gp/hardware_device_problems
Another possibility is that the cables are loose. Remove ALL power, then check cables in both
ends. Remove and replace, do not just snug. For laptops you can often clean the power and
data contacts with a pencil eraser.
Some DVD drives do not use the Windows default drivers so check with the System maker and
device maker to see if there is firmware or drivers for you drive if needed.
Stage 2 : You could have drive issues as the CD/DVD is actually 4 drives in 1 case ( CD & DVD
burn and CD and DVD read). So it is not unusual for 1 or 2 parts to not function while the others
do so properly.
Did you complete the troubleshooter for the drive that still does not work? There are some
registry entries that the troubleshooter does not fix and those "might" be the cause.
Check with your System Maker and Device maker for both possible firmware updates and the
correct Registry entries for your drive.
These are the keys I think are the ones in question - for the CD/DVD drive sub-keys of course
as there will other sub-keys in these keys. Be sure to ask for specific keys involved as well as
the settings.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\IDE
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Hardware Profiles\0001\System\CurrentControlSet\Enum\IDE
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
You probably can find more info here and maybe even the exact registry settings for your CD/DVD
drive from someone with the same model.
Forums - a lot of real expert help
http://club.myce.com/
CD/DVD units
http://www.myce.com/storage/
Use DevManView to locate CD/DVD in registry (be careful and make a Restore Point before
changing anything) - find the device in DevManView and then Right Click on it Open in RegEdit.
DevManView - Free - an alternative to the standard Device Manager of Windows, which displays all
devices and their properties in flat table, instead of tree viewer
http://www.nirsoft.net/utils/device_manager_view.html
Hope this helps.
Oct 20, 2013 | Philips Dh-16a3s & Lite-on Dvd/cd...
Tsstcorp cddvdw ts l633p error code 19
Code 19 means there is a driver conflict such as two devices trying to use the same resources.
Try this - Control Panel - Device Manager - CD/DVD - double click the device - Driver's Tab - click
Update Drivers (this will likely do nothing) - then RIGHT CLICK the drive - UNINSTALL - REBOOT
Normally the above will fix that issue if not work your way down through these even if you have done
them before.
The CD drive or the DVD drive does not work as expected on a computer that you upgraded to Windows Vista
CD/DVD drive does not appear in Windows Vista, or you receive this error during Windows Vista setup after booting from the DVD (AHCI)
Hope these help.
Jun 14, 2012 | Computers & Internet
Optical drive not recognized by windows
Hi,,,,,,,,,,,,
Do these to clear corruption and repair/replace damaged/missing system files.
Start - type in Search box - COMMAND find at top of list - RIGHT CLICK - RUN AS ADMIN
sfc /scannow
How to Repair Windows 7 System Files with System File Checker
http://www.sevenforums.com/tutorials/1538-sfc-scannow-command-system-file-checker.html
Then run checkdisk (chkdsk).
How to Run Disk Check in Windows 7
http://www.sevenforums.com/tutorials/433-disk-check.html
After the above :
below.
a Mr Fixit
Windows Vista
do so properly.
the settings.
CD/DVD drive from someone with the same model.
CD/DVD units
all devices and their properties in flat table, instead of tree viewer
Hope this helps......
GOOD LUCK.................
Sep 24, 2011 | HP Pavilion dv6647cl PC Notebook
My Matshita dvd ram uj 857s says code 10. I have
It's not "regeit" but "regedit".
Drives Disappear After You Install ITunes or Norton Ghost** If after installing ITunes or Norton Ghost, you get Device Manager error code, try locating the Audio File System (AFS) driver from Oak Technologies at C:\Windows\System32\Drivers\afs.sys or doing a search for it. Rename it afs.sys.txt and reboot. This driver is incompatible with the driver found in iTunes and Norton Ghost. The driver from these two companies is the same and made by a third company called Gear Software. After renaming the afs.sys driver file you will lose access to the CD burning feature of of the following: HP Memories Disc Creator, Liquid Audio Portal Player, Oak Technology SimpliCD, or Broderbund's Print Shop version 20. If you still wish to use the burning feature in any of that software, upgrade it to a Vista versions. For more information, see the article here - http://www.gearsoftware.com/wiki/index.php?title=CD/DVD_drives_disappear_after_installing_iTunes.
Description of Code 10-related errors that Device Manager generates in Windows-based computers
http://support.microsoft.com/kb/943104/
Please do all the below even if you have done some before as it is often the total process which solves the issue.
Then work your way through these - remember the drive could be bad, could have a loose cable or
Dec 30, 2009 | Dell XPS M1330 Notebook
Norton 360 install has replaced/overridden DVD drive
Hi, I can certainly understand how you feel and hope I can help.
error 19 isnt necesarily a corrupt driver, it can be 2 drivers trying to use the same resource (as in norton's backup drive and your cd drive, for example)
Try this - Click the start button, right click on "Computer", select "Properties", then click "Device Manager" in the upper left hand corner.
Open the bit that says "CD/DVD Drives" and try right clicking on the drives there and selecting "Update Driver Software". This will probably do nothing. Don't worry, I didnt really expect it to. Now right click on the drives, and select "Delete" and then reboot. This will reset the drivers for ya.
This fix usually DOES work. Most of the time. If it doesnt work, try the ones below.
Hope these help.
Dec 05, 2009 | Gateway GT5435E Refurbished AMD Desktop...
Code19 on sony cdrwdvd willnot reconize on inspiron 1525
Your CD drive or DVD drive is missing or not recognized by Windows or other programs, so you cannot play or access a CD or DVD. This issue might have occurred after you installed, uninstalled, or updated a program or Windows Vista.
This issue may have occurred after one of the following situations:
  • You upgrade a computer to Windows Vista or install Windows Vista Service Pack 1.
  • You install or uninstall CD or DVD recording programs.
  • You uninstall Microsoft Digital Image.
You may see one of the following error messages:
  • One of the following error messages appears when you view the CD drive or the DVD drive in Device Manager.
    Error message 1 The device is not working properly because Windows cannot load the drivers required for this device (Code 31). Error message 2 A driver for this device was not required, and has been disabled (Code 32 or Code 31). Error message 3 Your registry might be corrupted. (Code 19)
  • An "error code 39" error message.
  • A message that resembles the following appears in the notification area: Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
  • you can find this information and more at this site..
  • http://support.microsoft.com/kb/314060
Nov 08, 2009 | Dell OptiPlex GX260 PC Desktop
(Vista) Toshiba - Matshita DVD-ram problem.
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available.
Jan 10, 2009 | Toshiba Satellite A205-S4617 Notebook
GMA 4082n device driver not working properly code 39
The dvd does not need driver, you need to reinstall Windows.
Jul 18, 2008 | Toshiba Satellite A135 Notebook
Computers & Internet Logo
133 people viewed this question
David Payne
David Payne
