Question about HTC Touch P3450 Smartphone
I have a htc touch p3450 handset. its battery is swollen and it gets turned off in a minute even though its fully charged. so what is the problem and wat is the solution?????? if u get the solution the call me on-9762712716
  • 341 Answers
The battery is swollen means the battery is bad and it can't hold charge. Please replace your battery and everything should be fine.
Posted on Mar 12, 2011
I wana fully formate to my htc p3450
hi i am using htc touch p3450 plz give me mobile format idea
Feb 10, 2011 | HTC Touch P3450 Smartphone
The phone cannot start only the dead screen appears
Check if the battery is fully charged.?
If it is then it is a software problem so you need to reinstall the software.Take the mobile to the nearest authorized service centre of HTC and they will reinstall it.
Thank You
Nov 22, 2010 | HTC Touch P3450 Smartphone
Serial Number htc touch p3450
i guess you're trying to download and install the wm 6.1 upgrade for you htc touch. use this serial number : HT831G609985
once done with download, connect your phone to computer and run the downloaded file. make sure that the battery is charged 50% up.
Aug 29, 2010 | HTC Touch P3450 Smartphone
I have an htc ozone, what is the proper way to charge it for maximum battery life? seems to drain out shortly after an all night full charge. Thanks.
I just got my Ozone a few days ago. What you should always do with an electronic device is charge it fully before turning it on. Then using it until it dies completely with no battery. Then fully charge it again for maximum battery life.
You can go to Start, Settings, More, Power, Power Management. Change the different things to make it save on power. Also a big help is Start, System tools, Task Manager and delete everything that is being used. That just turns it off in the background, it doesn't delete the program.
Aug 31, 2009 | HTC Touch P3450 Smartphone
HTC Touch Dimond displays Roaming symbol E beside Signal strength
yea i also have the same problem even though i have my data switched off nd no gps etc. wont i b charged for the e symbol meaning it uses data even thou i have data switched off? this is really weird someone please help us out. thanks
Jun 15, 2009 | HTC Touch P3450 Smartphone
Discharge Battery
If it is within warranty, have them replace the unit. Are you using a wall charger or a trickle-charger such as the USB Cable? The wall charger is the only way to truly charge it to full.
If you are using a USB charger or other trickle charger, after the device says it is fully charged remove it from the charger for about 2 minutes and then reconnect it. It will then charge (most of) the rest of the way.
If you don't do this, the problems gets worse and worse. After 1 day, the trickle charger may get you up to a 90% charge. After two days, 80%, etc. After a week you'll only be holding half a charge, even though the device is reporting a full charge while on the charger.
Another tip I have found is to perform a soft-reset after removing it from the charger, particularly if it has been plugged in for a long time at full charge (more than an hour or so). It seems like the device doesn't always detect that it has been unplugged and tries to **** down juice as if it were still plugged in. If you have noticed that your device gets pretty hot when the battery drains quickly, this is probably what is happening to you.
You also haven't mentioned the programs that you are using during the day. Some programs, particularly chat clients, will drain the battery in about 5 hours, though obviously you're not using anything like this while in flight mode.
One more thing. You noted that you were told that leaving it on the charger whenever possible is the thing to do. This is incorrect. The more the battery is exercised in this way, the shorter the lifespan of the battery will be. With any mobile device we're all bound to charge it every night, but once it is charged you want to take it off the charger. A battery being fully charged is just as bad as a battery being fully drained, so you want to keep it somewhere in between as much as possible. __________________
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 12, 2009 | HTC Touch P3450 Smartphone
Battery shows fully charged, stays on for 3 minutes and freezes.
I've had this happen. Try a soft reset, if that doesn't fix it - try a hard reset. If it still does this, you will need to replace the battery. It may either be a problem with the battery itself or the power regulation circuit that is built into the battery. Either way, replace the battery and it should fix it. Word of warning though, some aftermarket chargers actually reverse-charge the battery - I had a USB charge/data cradle that did this and I still have short-lived battery life on my new E2 battery if I use that cradle. I just stopped using it because it kills my E2.
Jan 12, 2009 | HTC Touch P3450 Smartphone
I have lost my contact no from my handset while sync. Though the numbers are available in the system Outlook but I am unable to get it back in my HTC handset when Synchronizing again. What to do?
Nov 27, 2008 | HTC Touch P3450 Smartphone
Htc touch diamond freezes on start-up
I called and spoke to HTC ..apaprently there are issues with some of the handsets .. and its power related ... the best this is to do 2 things to solve any number of issues....
A: Get a replacment battery, and recharge it fully without turning the phone on. So plug it in and charge it until the white pulsating light is fully lit and not 'breathing' ..as they say. Once fully charged then turn on your phone...
B: Once on ... 'hardware' reset it -  (you turn on the phone, holding the volume down button, and the hang up button and pressing the 'software reset button, at the same time)
Should solve it ... IF it dosent .. and your getting the same issues after battery replacment, software and hardware resets ...you've basically got a 'hardware' issue with the phone in which case you need a replacment or repair... (make sure your phone is insured)
Hope that helps folks...
p.s. My phone eventually stopped charging ...nothing, no power so i sent it back for a replacment which im waiting for to arrive...
Nov 17, 2008 | HTC Touch Diamond Smartphone
HTC Touch P3450 Smartphone Logo
159 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
