Question about Philips GOGEAR SA6045 MP3 Player
When I turn it on - a picture comes up - it looks like a battery - but then it turnrs off, do I need a new battery (I just starting using it last month) what kind of battery do I need? And how do I get the battery out of there?
  • 604 Answers
Yes it needs a new battery. usually the case prys apart, but look for some tiny screws before prying it apart. the battery inside will have markings on it to help you find a replacement
Posted on Mar 12, 2011
I got the kodak easy share 143 model camera coming brand new off of ebay yesterday,,,but it keeps saying my batteries are half drained, then dead after a couple of photos. Then if they're dead it...
Alkaline batteries just don't have the power for more than a few pictures in today's power hungry digital cameras. Some batteries may also have reached their shelf life at the store, and though brand-new right out of the package may even have problems just powering startup of the camera. The one's that came with your camera are just to show you that the camera works, but as you've discovered, they'll only last for a few pictures. Digital cameras that use AA's for the most part should only be used with modern rechargeable batteries. If you read the camera's instruction manual concerning batteries, you should see the same recommendation.
Modern rechargeable batteries have over 5 times the power density of alkaline batteries (that's right, they last up to 5 times longer than an alkaline battery. And you can recharge them over and over!). Keep in mind rechargeable batteries will save you much money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Jun 26, 2011 | Kodak Cameras
1.why do my batteries last such a short time. They last around a day. . 2.When i put my sd card in these funny pictures come up on my images how do i put my original photos with that. Many thankx
Digital cameras are famously demanding on batteries. You must use good alkaline batteries or better, a set of high capacity NiMH recharegables. Zinc or "long life" batteries just aren't up to the task.
New rechargeable batteries are supplied only partially charged. You need to charge them fully before use.
I don't understand your description of the problem with the SD card. When you take pictures they will automatically be stored on the memory card. Are you saying there are other pictures there already?
Oct 29, 2010 | Vivitar ViviCam X327 Digital Camera
It died during the winter, it was great all last year, no problems. Today i turnred it on, nothing. where to start? who to call?
Make sure the outlet that you have it plugged in to is in good working order. i.e. plug a lamp/hair dryer in and see if it works
Check the breaker.
Jun 07, 2010 | Kenmore 70066 Air Conditioner
Tracker 5600 cant see display worked fine last week
Last fishing trip was at night and due to the brilliance of the display my son turnred it down and unknown to me actually turned it off ( the backlight) and it was only after trying everything else found it was the simple solution of turning it (the backlight) back on. oops
Jan 05, 2010 | Navman Tracker 5600 GPS Receiver
Draining rechargable batteries;
Carry spare alkaline batteries - just in case...
Does the same symptom happen with alkaline batteries?
Lithium Ion batteries are 1.2volts
Alkaline are are 1.5volts
Rechargeable Alkaline batteries are 1.5volts
Perhaps you should switch to Rechargeable Alkaline batteries if the symptom goes away when you use alkaline batts...
Sep 17, 2009 | Samsung Digimax D53 Digital Camera
Battery life
The rechargeables are only meant to last a couple years maximum (pretty good that you got three out of them). Also rechargeable NiMH's have approximately 5 times the power of standard alkaline batteries. Alkaline batteries should only be used in emergencies in digital cameras as they will only last for a short while before they are drained (as you've discovered).
The obvious solution is that it's time to consider purchasing a new set of rechargeable NiMH batteries. Look on the package for a power rating of at least 2,500 mah. Avoid batteries that do not list the power rating as they are generally inferior batteries.
Jul 20, 2009 | Canon PowerShot A710 IS Digital Camera
Low battery signal coming on with new batteries
Are you still using alkaline batteries? If so, alkaline batteries just don't have the power for more than a few pictures in a digital camera. Some may also have reached their shelf life, and though right out of the package may even have problems just powering startup of the camera. Digital cameras that use AA's for the most part should only be used with rechargeable NiMH batteries. If you read the camera's instruction manual concerning batteries, you may see the same recommendation.
Keep in mind rechargeable NiMH batteries will save you money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Feb 12, 2009 | Canon PowerShot A75 Digital Camera
My camera wont stay on even with new batteries
I Have The Same Exact Camera As You And Have lost of Experience With Digital Cameras I'm Guessing you just need digital camera compatible batteries (Rechargeable) Oh and keep in mind taking a picture requires a lot of energy use
Dec 30, 2008 | Polaroid i735 Digital Camera
The camara will come on with fully charged batteries and u can look through the pictures. but u cannot take new photos! when i turn it to the take photo button the camara turns its self off
I'm not sure what model camera you have, but it's possible that you may be using the wrong type. If your camera uses AA batteries, make sure that you are using lithium batteries instead of regular alkaline ones. The lithium batteries are a lot better for digital devices and they will last a lot longer too. However, they are a little more expensive. You can find them anywhere they sell batteries. They're the energizer e2 ones in the blue package.
Jun 12, 2008 | Canon Cameras
Batteries Dying Quickly
Change the internal rechargeable battery.
Dec 01, 2007 | Konica Minolta DiMAGE Z5 Digital Camera
Philips GOGEAR SA6045 MP3 Player Logo
67 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
