Question about Fujitsu Computers & Internet
Need wireless info - Fujitsu Computers & Internet
    Scholar:
  • 97 Answers
The information you'll need is set up in your wireless route. Connect your PC to your router using a network cable, and surf to the router's IP-address to visit your modem interface and take a look at the modem settings. You can find this address in Windows by opening the Command Prompt (it's under Accessoires, which is under Programs) and typing in "ipconfig", then hitting Enter. The address you're looking for is displayed next to "default gateway".
Posted on Mar 13, 2011
Trying to conect wifi on my vigo anroid tab and it asking for ssid and security method wat is that ssid
Your Wireless device, you didn't supply that info, If Secured, has a SSID (name) and a Security Key (password) . Who setup your wireless device? They have the info. I need more info on what the wireless device is? Make, Model?
Jan 11, 2013 | Computers & Internet
Had a new router how do i get my wireless back on have installed the router but not sure how to install the wireless
You did not give much info. Your Make, Model of computer? What OS you are using? The wireless device? Is the wireless working? Is it secured with a SSID and Security code? Need more info.
Dec 13, 2012 | Computers & Internet
Turn on wireless radio for hp windows7
You didn't give much info to work with, your HP Model? Is there a switch on the computer? In the Tray Notification Area there is a icon, right click . Are you connecting to a wireless access point? Secured? Need more info to give a informed solution.
Nov 27, 2012 | Computers & Internet
I need to get some info on how to get my ssid# off my wireless router please
You will need to log into the routing and check the box "Enable Hidden Wireless" on the Wireless Settings page.
To log into the router:
Open a web browser and enter http://192.168.0.1 and press Enter. When the login window appears, set the user name to admin and leave the password box empty. Click OK to continue. (this is assuming you have not changed the username and password)
May 20, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Do i need a user name and password to use the wireless modems
All you need is wireless network name which is usually name of the router brand or default unless some one has put on encryption in that case you need both. If you cant find out what info you need just reset router to factory settings by pressing reset button for 20-30 seconds and this will erase all the info saved in the router settings and bring it to defaults.
Dec 31, 2009 | 2wire (2701HG-B) Wireless Router
I have a Belkin_Pre-N_310946 router but I am not sure how to hook it up so that I can get wireless on my laptop I have followed the how to install Belkin N1 wireless info, but it doesn't work for this
To get the information about the wireless settings of the router,
you will need to open the set up interface of the router.
Router set up is very easy . you don't even need the set up disc.
Click Here for more info
Oct 18, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
Netgear WGR814v2 does not see my ASUS 1005HA-P netbook, but the netbook sees the the Netgear wireless network but cannot connect .
To connect into your own Netgear router, you need to configure the wireless card with your router's wireless configuration settings, eg.the SSID and encryption settings. Check your router manual on how to configure the router or go to the Netgear WEB site to download this info.
To configure the Netgear router for wireless you need to connect a LAN cable from the laptop to the router and run your browser with the configuration IP address. for Netgear type the URL address ;-
http://192.168.0.1
the login = admin PW = password
Then configure the SSID and encryption, record this info so you can configure the wireless card with the same settings.
You can also connect to the Internet by using a LAN cable and plug it into the Netgear router without a wireless connection.
Sep 04, 2009 | NetGear WGR614 Wireless Router
Amlio li 2727 notebook adding to wireless network
find out first if your comp is wireless capable, then if it is, see if your wireless network is locked. for what ever wireless you are using you can go to the website and see if there is a way to get your passkey info. once you have that info then you should be able to add you comp. however if your comp isnt wireless capable then you will net a wireless card, pref. the same name as your wireless router.
Aug 25, 2008 | Computers & Internet
My Dell does not recognize my wireless connection.
First of all make sure your dell "sees the wireless network, if it does - go back to your router program, write down all pertinant info needed for the dell under wireless network connections; SSID, encryption password, type of encryption, etc. fill in the info you wrote down. That should fix it.
Aug 17, 2008 | Computers & Internet
Bt broadband wireless
Go into your device manager and check and see if the usb connections are active and not turned off. If thats all ok open your network connections and make sure you see a wireless adapter there you should see two connections there, one should be lan adaper, and two should be wireless adapter. If not I need a little more info. Just write back to this sight and give more info what operating system your have wireless card ect. anything that will help, I hope this helps you out, usually you can fix it a couple differant ways you can email me anytime for more info.
Dec 12, 2007 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
60 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
