Question about Garden
I have a craftsman push weedeater and the pull cord broke and I want to know how to reinstall so the cord so it will work. I have taken the cover off and fixed the cord and put everything back together but the cord pulls out and will not go back in.
    President:
  • 3,074 Answers
You will need to pull the shroud back off, turn shroud upside down, wind it up and with a screwdriver or another pair of hands thread the cord back through, tie a knot and burn it, let go of the it, it will wind the cord back in, pull on it a few times and make sure it is working, then reinstall. Hope this helped Tim
Posted on Mar 12, 2011
I need to know how the clutch works as I believe it is broke. The engine is an EZ fire 25cc craftsman on my weedeater/cultavator.
The clutch is centrifugal, if the clutch is broken it will most likely be hung up and not disengage making it difficult to pull the rope. Please let me know the model number xxx.xxxxxx and more about the symptoms.
Mar 23, 2011 | Craftsman Garden
How to replace a craftsman weedeater gasline?
you hook one line to it the return line inside the tank
The line you used as a return line pull it back thru the gas cap hole and put that piece on one end of that line and pull it back in the tank until it stops and then hook the return line back where it belongs
May 14, 2010 | Craftsman Garden
Pull cord broke on my craftsman gas push edger. I replaced cord but when I pull cord..It wont rewind but I can hear it trying to start
It sounds like you did not properly rewind the spring that is behind the spool that the cord would around, that spring is what rewinds the cord after pulling the cord.
May 05, 2010 | Craftsman Garden
Pull cord stuck in the out position
this can be caused by sevral things inside the pull cord hub assembly. examples: Dirty inside & needs taken apart & cleaned. something logged inside, plastic spool tabs broke, spring/s broke, levers broke or any of these items could just be to worn. replacement parts should be available.
Oct 04, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Replacing pull cord on weedeater
there is another t20 screw in the neck of the drum. once removed you will expose the drive clutch. soak it good with WD40 then unscrew it from the shaft. if you have all the housing screws out, you should be able to simply remove the housing to expose the pull cord assembly, screwed to housing.
Aug 06, 2009 | Ryobi Garden
Repalce the pull cord a Craftsman Weed eater 32CC
I have a craftman weed eater model M358.796600 and the pull cord will not retract any more...how do you fix it?
Drew
Jul 02, 2009 | Craftsman 25cc Gas Line Trimmer
Broken pull cord
ur going to have to unmount the the motor from the shaft
step 1. Unbolt throttle housing
step 2. now with that out of the way u should see a clamp holding the motor to the shaft, loosen and pull the shaft out, there will be a cable, so make sure u have it lined up so it goes back into place
step 3, look at the back of the motor, u should see screws going into the plastic housing (coming in from back going into plastic)
step 4. once that is off pull the broken part of the cord out
step 5. wind up the starter coil, (it will only wind up one way) its spring loaded so be carful, once it stops back it off 1 full turn
step 6. u will see a hole for the cord in the housing and in the coil, make sure they are lined up
step 7. insert the cord through both holes, tie it as tighttttt as possible, then let the spring do the rest
step 8. put it back together
May 30, 2009 | Craftsman 25cc Gas Line Trimmer
Broken pull cord
You have to take four allen screw out of the plastic that holds the engine on. There is also one by the spark plug that needs to come out. Once the engine is loose, you have to unplug one wire and unscrew the other. Then the engine should come off. Then loosen the two allen screws holding the pulley in and it will come out.
REplacing the pulling cord on a gas trimmer
those are usaully under your pull start cover and if its broke you can buy a new rope but if its broke near handle i would open it and retie it to save ya money. but remember to wind spring a little to keep tension on it before pushing it through the hole for handle.
Apr 17, 2009 | Craftsman Convertible 25cc. Gas Line...
Weedeater quits working/button no longer activates weedeater
try this get a good extension cord test it plug it in now with the trigger pulled wiggle the cord going into the weeder i have in the past moved the cord till i got working and taped it to the handle, if that dosent work get a new one
Mar 07, 2009 | Poulan Genuine Weedeater Part # 36006-128
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
