I have same problem as posted on this site. My Emerson microwave will not let me set time. Also, my number pad doesn't work anymore. How can I reset the control panel? Where is it?
Judy in Florida
Is your microwave a portable model so that you have access to the power cord? If it is, unplug the cord and leave it off for a few minutes. Then replug and it may reset. This seems such a simple solution, however, sometimes a simple solution is the answer. If your microwave doesn;t respond, I would consider the age and condition of it and consider replacement. Repair can be expensive and the price on these appliances is now quite reasonable. Good luck to you.
I believe that your control board is bad, and will need replacement. This part would probably be to costly versus a new unit. Only a warranty replacement would I advise a fix.
Brian
I maybe do not understand...if your number pad does not work, then how would one be able to set the time?
Here is the users manual that I greatly hope will help with your problem! Let me know if this helps!
Brian
Touch the clock pad.
Enter the time (like 1234 for 12:34)
Touch the clock button again!
This is on page 12 of the manual....Good luck!
Brian
If I helped with your problem, please change my rating to reflect such!
Sorry for my earlier misunderstanding of your problem, I thought that your problem was much more complicated!!
I forgot how to set the time. I had to do it once before and can't remember. Emerson MW8107WAC
None of the answers helps me. The microwave is only 4yrs old and used only for three months in the summertime. When we first arrived this summer, I forgot how to set the time. Then I just pushed the numbers and it worked. Last night we had a power failure and lost the time again but the machine still works. Can you tell the actual method for SETTING the time?
