We bought a used tv and have no book. We do not know how to plug in the dvr box and get it to work. Tv comes on but no picture.
    Problem Solver:
  • 7 Answers
Does the DVR box have composite cables or an HDMI? If it is HDMI, you have an easy fix just take that one cord and plug it in to the HDMI OUT port on the box and HDMI IN on the TV
Posted on Mar 12, 2011
My TV has no sound. The picture is perfect,DVR and cable box are ok. The only thing different is I added a sound bar a few weeks ago when the sound went out on it. I disconnected it thinking the audio...
there could be a number of things effecting it.
check that your TV is not set to only go to the sound bar. This is like plugging headphones in your phone......the tv is probably still seeing the sound bar and the only way you want to hear sound.
try plugging headphone into it and see if they work through that
Mar 11, 2016 | Televison & Video
LED TV takes 7-13 mins to display a picture when hooked up to cable DVR box, when hooked up w/ out DVR Does Not do that???
I would suggest you verify your cabling. Are you using HDMI cables? Connect a HDMI cable from the TV HDMI 1 to the Cable DVR Box, In the TV setup ,select HDMI 1 as source. If your Cable box does not have HDMI contact the provider for a updated box. With out the Make, Model of Box, Cable? Sat? Make, Model of TV. I don't know the connections?
Jan 26, 2013 | Televison & Video
I have a Verizon FIOS DVR connected to the Samsung receiver. After watching TV for a period of about 30 minutes or so I start to get a delay in the volume coming out of the speakers compared to the picture...
common problem, trouble is that the receiver cant keep up with the dvr box. try this, dont use audio from your dvr into your reciever, take the audio out from the tv, and go into the receiver, now the sound is after the picture and should catch up with itself.
Mar 20, 2011 | Samsung HTC6930W Theater System with...
Having problems gettin sky channels through archos i get to setting infrared settings and can not get code.dont know wether to connect dvr t the tv or the sky box
Remove the DVR station from the box, and attach the DVR adapter plate (found in the
DEVICE box); it is correctly attached when it clicks on.
-Take the Black Audio/video Marked "output" cable, and insert the connections into the corresponding coloured sockets, yellow>yellow, green> green etc. Make sure they are
inserted into the TOP row on the back of the DVR Station "Marked Out". The remaining
black connector should be plugged into the SW socket, which can be found underneath
the orange socket on the back of the DVR station. (If after setting up your ARCHOS the
picture is very green remove the black cable from the SW socket)
-Plug the SCART connector into the SCART socket on your TV set. These are usually
marked AV1, AV2, or Ext 1, Ext 2, L1, L2, Line in 1, Line in 2, Aux 1, Aux 2, make sure you
select the corresponding channel above (ie AV1 AV2 etc) on your TV set when you turn on
the TV.
-Attach the UK plug adapter to the Mains charger, and plug the charger into the DC-In
socket on the back right of the DVR station. Turn the mains on at the socket.
-Insert the powered off ARCHOS unit onto the DVR station, the unit will now power on,
and ask if you want to 'Switch to TV out', select 'Okay'. The 'TV output configuration' set
up will load up. Select 'Okay'.
-TV connection: When your DEVICE is connected to the optional DVR Station you need to
select the type of video output (Composite, S-video, component, RGB, HDMI etc), based
on how you have connected the DVR Station to your TV and what possibilities your TV will
allow. For the cables supplied and the instructions aboce you will need to select either
RGB or Composite. Use the arrows to go through the options and select either RGB or
Composite.
-TV Standard: this should be set to PAL (Europe). Select 'Next'.
-Now you need to test the settings, select 'Okay', the ARCHOS home screen should now
be visible on your TV set. If you have nothing showing on your TV, scroll through the
AV/Ext channels, the channel will correspond to the AV/Ext socket you connected the
cable to on your TV set. Use the ARCHOS remote to select 'Okay'; you have now set up
the output connection settings for your DVR station.
-You may need to adjust your output from the ARCHOS to match your TV, from the "TV
Format" options. Use the arrows on the ARCHOS remote to select the format of your TV
screen, so the ARCHOS unit outputs the correct picture size (ie 4:3 / 16:9 etc). Use the
arrows on the remote to select 'Next'.
Dec 24, 2010 | Archos 605 WiFi Digital Media Player
Yamaha HTR-6230 receiver set up w/HDMI no sound
BD and DVR hooked up to the receiver and from the receiver to the TV right? If yes: Your receiver set to pass sound trough to the TV, if you want sound from the home theater setting has to be changed.
Nov 28, 2009 | Yamaha RX-V463 Receiver
No picture in HDMI
After reading tips on this site I did a manual reboot of my cable box. Sure enough, that had been the problem. I'm going to keep a watch on it from now on; if it happens again, I'll call for a new DVR/cable box. Thanks for all the info on this site!
Jan 14, 2009 | Panasonic TH-46PZ80 46 in. HDTV-Ready...
Just need to know where to plug in the red, green and blue cords
The red-blue-green outputs of the cable box are COMPONENT video, and the yellow-white-red inputs on the tv are COMPOSITE video. Although the words sound almost alike and the connectors look similar, they are incompatible signals. You'll need to change either the cable box or the tv so they match. Maybe this would be a good way to rationalize getting that new home theater system! Or maybe call your tv cable company and ask for a different box with composite video output. Once the cable box matches the tv, you don't necessarily need to change the cables. If the connectors fit, go ahead and use the cables you have.
Jul 15, 2008 | Quasar SP-3235 32" TV
Televison & Video Logo
Top Televison & Video Experts
