Question about LaCie 724 LCD MONITOR-LED BACKLIGHT 14 BIT
How to operate? samsung monitors 2430h - LaCie 724 LCD MONITOR-LED BACKLIGHT 14 BIT
I just took samsung 23 inch led monitor out of the box, got it working for about 10 minutes, then pushed a button and now all it does is recycle the Digital/HDMI/Analogs indicators on the upper left of...
I assume you have it connected to an external monitor output on the laptop. The laptop's operating system probably identified the monitor when it was first plugged in, but somehow pressing the button changed the monitor's identity as far as the laptop is concerned - maybe there is an incompatibility in the resolution setting. The laptop has apparently shut down the external video port.
Turn off the monitor, but leave it connected to the laptop. Restart the laptop and turn the monitor on when the laptop brings up its BIOS screen (begins the startup process). When the operating system gets started, it should recognize the monitor again.
What operating system are you using, and what kind of connection are you making with the laptop (DVI, VGA, HDMI)?
Jan 23, 2011 | Samsung BX2335 23 inch Monitor
Where can I download Samsung CyncMaster 757 dfx monitor driver?
Which operating system are you using if win xp or win 7 it dosent need any driver
any way the driver for windows 98 is not possible.
Dec 05, 2010 | Samsung SyncMaster 757 DFX (White) 17" CRT...
Fuzzy/blury fonts on a samsung syncmaster 920nm
Good morning! Please review/check the set-up settings of your samsung flatscreen, best to refer it to the operations manual of the monitor which should be included when you bought it. best regards.
May 02, 2009 | Samsung SyncMaster 920NW Monitor
I need a a SAMSUNG monitor driver ( SyncMaster 753s)
You do not need to install any driver to use this monitor. The operating system has built-in drivers for this monitor
Apr 30, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
How can I operate the Samsung SyncMaster 1200 NF monitor as TV
Tiger Direct carries the following device to convert an LCD or CRT monitor into a TV.
Let me know if you need more assistance.
Apr 11, 2009 | Samsung SyncMaster 1200 NF (Ivory) 22" CRT...
Samsung 710v 17'' lcd problem
Dear
The problem is main board inside monitor which is needed to be changed with new one. So I suggest you to take monitor in nearest samsung's service center.
Best regards
Dec 14, 2007 | Samsung 710V 17" LCD Monitor
LaCie 724 LCD MONITOR-LED BACKLIGHT 14 BIT Logo
61 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
