Question about Toshiba 46XV640U 46 in TV
My toshiba 46xv640u powers on but i do not get a picture. what could the problem be?
My tv sat in the garage for 6 months
Never would have fixed my tv without your tip thanks nick and thank god
$2.50 at radio shack
Posted on Nov 09, 2014
  • William Ward
    William Ward Aug 14, 2016
    Thank you very much I have had this TV on back burner for 8 months and when I saw this I had to try it and after about 35min start to finish I had my TV back up and working perfectly
Guys I found it. It is on main board on Toshiba 46xv640u TV.
You need to know how to solder very small parts, or ask someone with steady good hands to help you. It is faulty 22uf16v capacitor. It is marked on the circuit board as "C606". It is somewhat between two big heat sinks (cages). Do not try to solder out bad cap, nearly impossible. Just twist it off like chicken head, and then using soldering iron just clean soldering spots. You don't have to use SMD Cap. Just band the legs of regular one and solder, watch polarity of course. I am pretty sure this one causes the problem with delayed pictures and no picture at all. I have spent weeks every day to hunt it down. I am not a professional but very stubborn. I even bout ESR Cap meter for this project. Have replaced dozen suspitious CAPs with no success.
So Guys save money. Try it before buying new main board or new TV.
Fix it and be proud of yourself, and give thanks to God because God Is Good.
If someone will have success because of this info, could you please comment. I would be pleased to know my solution helped someone.
Thank you
Nick
Posted on Jan 24, 2014
  • 2 more comments
  • ngubatiy
    ngubatiy Jan 24, 2014
    Thank you
    Nick
  • Mark
    Mark Mar 22, 2014
    Did this fix your tv?
  • James Wilson
    James Wilson May 07, 2014
    Nick, YOU ARE THE MAN! You don't know the frustration I've had regarding this problem, I'm even banned from Toshiba's forum. It is exactly the capacitor you said it was. I even used a salvaged 50v 33uf instead of the 16v 22uf. Thank you so much for sharing this info, it's guys like you that restore my faith in humanity.
  • Dan Schmitz
    Dan Schmitz Dec 29, 2014
    Thanks a lot Nick. That works!
TOSHIBA 46XV640U TRUNES ON LITE GLOW TO SCREEN BUT NO PICTURE
Posted on Sep 29, 2013
Wont turn on. no power light. it worked one day and then wouldn't tuen on the next. no power surge to it
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Sep 01, 2015 | Toshiba 46XV640U 46-inch Hdmi Lcd Tv 16 9...
Can I watch netflex movies on my Toshiba 46xv640u tv?
I just downloaded the manual from Toshiba and did a search for Netflix and nothing came up. When I googled your model I saw other people complaining that the TV didn't come with Netflix built in. You can download the manual here: 46xv640u om pdf
Jan 28, 2015 | Toshiba 46XV640U 46 in TV
My toshiba 46xv640u goes through the initial setup every time after turning it off and turning it on later.
Most newer LCD, LED, or Plasma models "flash" the setup into non-volatile memory devices so this is not normal. If you are requested to "save" the configuration and don't or don't know how, maybe this would happen. Even power outages should not cause what you are seeing unless the configuration is somehow not be retained when the power is removed or by chance you are using a power strip to turn it off when it needs constant power to retain the settings.
Dec 01, 2014 | Toshiba 46XV640U 46-inch Hdmi Lcd Tv 16 9...
Keeps taling longer for tv to start
Probable power supply decline to failure.
Dec 28, 2013 | Toshiba 46XV640U 46 in TV
How do i change the the antenna from cable to antenna
which of these TVs is yours?
Originally supplied with models: 19AV600U, 19C100U, 19SL400U, 22AV500U, 22AV600U, 22C100U, 22SL400U, 26AV500U, 26AV502R, 26AV502R/U, 26AV502RZ, 26AV502U, 26AV52R, 26AV52U, 26C100U, 26C100U1, 26c1100u, 26SL400U, 32AV500U, 32AV502R, 32AV502RZ, 32AV502U, 32AV50SU, 32AV52R, 32C100U, 32C100U1, 32C100U2, 32CV510, 32CV510U, 32DT1U, 32E200U, 32RV530U, 32SL400U, 37AV500E, 37av500u, 37AV502R, 37AV502U, 37AV52R, 37AV52U, 37CV510, 37CV510U, 37E200U, 37RV525R, 37RV525RZ, 37RV52R, 37RV530U, 40E200U, 40E200U1, 40E200U2, 40FT1U, 40G300U, 40G30U, 40RV525R, 40RV525U, 40RV52R, 40RV52U, 40XF550U, 40XV640U, 40XV645U, 40XV648U, 42AV500U, 42RV530, 42RV530U, 42RV535U, 46/40/55S41U, 46G300U, 46G30U, 46RV525R, 46RV525U, 46RV530U, 46RV535U, 46RV53CU, 46SL412U, 46XF550U, 46XV640U, 46XV645U, 46XV648U, 52RV, 52RV530U, 52RV535U, 52RV53U, 52XF550U, 52XV645U, 52XV648U, 55G300U, 55HT1U, 55S41U, 55SL412U, 19AV600UZ, 19SL410U, 24SL410U, 32C110UM, 32FT2U, 32SL415UM, 40E210U, 40SL412U, 55G310U, 42RV525R, 32C100UM, 32DT2U, 40E210U1, 65HT2U, 32RV525RZ, 46RV525RM, 40G300U3, 46G300U1, 32C120U, CT90302 Programming Instructions and Codes, CT90302, 75022871, 75017678, 32E20U, 37E20U, 40E20U, CT90325, 75028874, 24SL410UM, 32C110U, 32SL410U, 32SL410UM, 40E210UM, 46G310U, 32C110U1, 32DT2U1, 40FT2U, 32C10U, 19L4200U, 24L4200U, 32L4200U, 40L5200U, 46L5200U, 50L5200U, 26C100UM, 40E200UM, 55HT1, 50L2200U, 39L1350UC
Jan 12, 2013 | Toshiba Ct90325 Remote Control
42rv530u toshiba tv no sound no picture change power supply and main board
The 42RV530U is known to develop problems in both the power board and the main board. You can check out our power board repair service at
http://www.coppelltvrepair.com/p/442/repair-service-for-toshiba-42rv530u-power-board-75010942-dead-tv-or-clicking-on-and-off-problem
and I'd also recommend that you search for 42RV530U at http://blog.coppelltvrepair.com as we will eventually release an article on how to test the board.
Hope this helps.
Aug 12, 2010 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
My parents lost their manual for their new Toshiba Tv. Model # 46XV640U. Where can I get one.
on the web at toshiba.com customer care just download it . it is free
Dec 02, 2009 | Televison & Video
Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
Oct 02, 2009 | Toshiba 42HP66 42 in. LCD Television
Toshiba problem
did you try power reset leaving unpluged for 5 minutes
it might be the power house component went out
do u get sound at all
this might be indicator of bulb replacement if no picture but sound
May 09, 2008 | Toshiba 57H81 57" Rear Projection...
Toshiba 46XV640U 46 in TV Logo
990 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
