Hello, My play movie has no sound. When I put the DVD to watch i see the movie but no sound. It's not on MUTE, I've already veryfied it.
  • David Dunn
    David Dunn Mar 12, 2011
    A specific attempt to help you would require some details re: the hardware models and connections of everything in the scenario.
    Master:
  • 525 Answers
Check your sound driver. Also check to see if your main speakers are set to default by going to control panel sound/audio devices.
Posted on Mar 12, 2011
I have a ACER ASPIRE 5517, Windows 7, wi-fi laptop. I'm unable to what DVD movies or watch the ones that I've copied. A pop up box, says: DVD internal error code: (8 numbers shown)
install VLC MEDIA PLAYER. goto www.ninite.com then check vlc. Then click install. after it installs try to play in using vlc. let me know. good luck.
Oct 18, 2014 | Computers & Internet
Not burning and not veryfying
You can upgrade you DVD burner firmware for a try, this way can fix many general problem.
Or You may take a look at this step by step guide, it's regarding how to convert and burn movie to DVD. I followed it and successfully burned DVD to play on my home DVD player, it's easy to understand, I think it deserves a trial.
http://www.best-dvd-burning-software.com/how-to-burn-avi-divx-movie-to-playable-dvd.html
Hope it helps. Email me if you need further assistant.
Nov 24, 2013 | IBM (92P6581) for ThinkPad T40 (92P6581)...
The sound goes on and of when watching a movie
see the cause and fix it: God bless you
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Jul 21, 2012 | Wharfedale DVD-M3 DVD Player
1. How do I watch the same movie on both screens on the Philips PET9422 37 9 in. Dual screen DVD players? 2. I bought a refurbished model but did not get a user's manual. How do I get one?
hi,
You can do the following to watch the same moving in both the screen.
1.Connect the AV out of both the unit together. with supplied av cord
2. If you want to watch the movie played on the first unit then put the DVD/AV IN switch of first monitor to DVD and the DVD/AV IN switch of second one to AV IN.Now you can watch the movie played on the first monitor on both monitors.
3. IF you want to watch movie played on the second unit then put DVD/AV IN switch of second monitor to DVD and the DVD/AV IN switch of the first monitor to AV IN. Now you can watch the movie played on the second monitor on both monitors.
I have the manual of the same . As it is large pdf file can't sent through fixya. If you can sent your email id through fixya will sent you the manual
ok
Jun 11, 2011 | Televison & Video
How do I watch a movie?
You should be able to put the DVD in the tray and should automatically recognize it and go into the movie.
What type of media are you trying to watch. PS2's cannot play blu-ray movies.
Mar 09, 2011 | Sony PlayStation 2 (PS2) Console
Player stops during movie or will not start playing movie
hello,
the reason the dvd stops a movie while watching or doesn't play at all is that the lens is already weak.
the best advice is to replace the lens.
you can take it to an expert for repairs or fix it yourself.
to fix it yourself, you will have to get a compatible replacement lens, then try to unscrew the dvd player, carefully disconnect the components to locate the lens, try not to damage any part of it while doing this, the remove the old lens and carefully fix the new one.
couple it back together then try a cd on it. if you cant do it yourself, then take it to an expert.
goodluck.
Jan 29, 2010 | Panasonic DMP-BD60K Blu-ray/DVD Player
DVD movie background sound too loud to comfortably watch!
on some dvd players and surround sound systems have a thing called DRC (dynamic range compression) you can us that and it will help it a little. i have come across the same problem but im after a digital on to run with plex or vlc on a mac. im having to route it through protools to use a compressor on there, but thats eating my resources.
Aug 24, 2009 | Pioneer PDP-5020FD 50 in. Plasma HDTV
Dvd player plays the movie but there is no sound
insert a normal music cd for 5 seconds eject. put your dvd movie back in
Mar 05, 2009 | Cyberhome CH-DVD 300 DVD Player
Sound
oh I see. Is there a sound when your playing a mp3 music in your winamp? is that the only problem you encountered for previous days?
Check the mute button.
check if your speakers are plugged in to the right port.
check if the speakers turned on.
Feb 04, 2008 | LG GSA-E10L (8801031212552) DVD±RW Dual...
Dont know what to do
Probably not much help. but the 1st thing I would do is check to see if the disc is even turning...put it in with label straight up, then when it fails, eject...odds are severely against the disc being oriented the same way if it spins, so if it hasn't moved, the main drive motor is bound up or dead. Either way, return it.
Dec 29, 2007 | Coby DVD-233 DVD Player
23 people viewed this question
 Grubhead
Grubhead
