Question about HP PL4260N 42 in. Plasma HDTV
We have a 42" Hewlett-Packard
Y Board is out. The boards costs about $150 and easy to install.
Posted on Mar 12, 2011
  • Swtleilani May 18, 2011
    Same TV ours just went out also. Our TV is just under 3 years old and we have been told, by HP, that it would be about $600.00 just to look at it. So, where can we order these Y Boards and would our manual direct us in how to install/replace it?
    Thank you for all your advice...HP has not been helpful AT ALL!!!
  • Eric Oct 11, 2011
    Where do we get this Y board? I need one too...
40' plasma....black screen but audio excellent
There are some common reasons for this fault to Plasma displays. Buffer boards should be checked. If you wish to get more details about these checks, try the site linked here. It has details with illustrations to fault that occur to a Plasma Display. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the Brand name to your set in its search box, or view it in Mosaic / Timeslide / Flipcard option.
Jul 25, 2013 | Element Electronics PLX4202B 42 in. Plasma...
Vizio plasma tv
what connection are uusont tivo ? have u tryed other sourses
Jan 28, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Cannot get to be a monitor for my pc
check your resolution settings also set the hertz properly, it should be working!
Apr 05, 2013 | RCA Hp Hewlett Packard Plasma Flat Tv 42...
Hello, My Hitachi 42" plasma is about 5 years
A description of the fault may help with an answer.
Sep 18, 2017 | Hitachi 42PD7200 42 in. HD-Ready Plasma...
We have a 42" Hewlett-Packard HD Plasma TV. It's
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually the screen may come on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Apr 09, 2011 | HP Televison & Video
Viore 42" plasma tv has
The tv was working fine until this morning, then the picture went out but the sound is still working.
TV is only 3 years old, no real electrical problems
Jan 29, 2011 | Toymax Viore 42 in. Plasma TV
Screen only partial and only shows in red and black
sir/mam the problem of your plasma t.v is the panel,weak panel. i have already encountered that kind of problem.
Aug 01, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Sounds on but no Picture
check local tv repair shops. better price
Jul 22, 2009 | HP PL4260N 42 in. Plasma HDTV
Horizontal Black Bars on HD channels?
You can change aspect ratio by remote. I hope it will be solve
Apr 02, 2017 | Dell W4201C 42 in. Plasma HDTV
Plasma tv picture went black
I would say you dont need to repalce Servcie kit.kit is only for 42EP24S units.
examine your unit What is the problem?Is the blue indicator on?If indicator on you will have audio.
In this case I would check first Y-sus board or Z-sus board.
Good luck
Dals123
Sep 28, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
HP PL4260N 42 in. Plasma HDTV Logo
1,526 people viewed this question
Top HP Televison & Video Experts
Tony
Computer Links
Alun Cox
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
