Question about Vacuums
Have a Broan VX6000C, likely 3 to 4 years old.....Turns on and provides suction for about 1/2 minute then turns off ..... need to unplug and wait about 1 min .. turn back on and have suction for another 1/2 minute .. then redo entire process ..... might be shutting down due to overheating ???? debris bin emptied ... filter cleaned (vacuumed) ??? help!!!
chrispurs1
  • 372 Answers
SOURCE: Dyson DC07 Original won't pick up at base
Lie machine on its side pull back handle as if vacuuming & switch on (KEEP YOUR FINGERS & ANY LOOSE CLOTHING CLEAR OF BRUSH ROLLER)
Brush should spin if it doesnt ensure clutch control knob on side of machine is in drive position if it isnt rotate knob by hand to drive brush should now spin.
If it doesnt & your machine has A clutch either clutch will need replacing or belts will need replacing.
Manuals are available to replace belts & remove the clutch from this site http://dysonmanuals.llc.nu/index.htm
Posted on May 18, 2008
GoVacuum1
  • 6 Answers
SOURCE: Bosch Vacuum Cleaner: I changed
Greetings from GoVacuum.com,
It sounds like you may have a bad thermal switch inside the machine. Most vacuum cleaners have a switch connected to the motor, so if the vacuum cleaner is running hot, it will shut off to prevent any damage to your motor. You did all the right things by checking the bag, making sure the hose was NOT clogged, and replacing HEPA filter.
Most of the time on canister vacuums, the reason is caused by a clog in the hose, or somewhere in the powerhead. If you're sure that there is no clog anywhere, it is going to be the thermal switch on the motor.
Here's a link to the parts schematic for the Bosch upright vacuum. I hope it helps you in determining how to access the thermal switch. A word of warning to you before you try it, this is a very tough vacuum cleaner to work on, you may want to bring it in to a vacuum repair shop, as this is not an easy repair.
Here's the link;
http://www.essco.net/Customer/SchematicFrame.asp?FileName=Turbo%20jet%20upright.pdf
Please let me know if you have any other questions,
Chris Jones
GoVacuum.com
1-866-468-2288
chris.jones@govacuum.com
Posted on Aug 18, 2008
SOURCE: Roomba shuts down after a few minutes
The brushes are clean on the outside, but probably not inside of the little yellow contact on the end. Also the junk that collects on the brushes finds its way into the gear box. Mine kept shutting down w/ the "Please remove and clean Roomba's brushes" message. I finally gave up and took it apart. There was a surprising amount of junk in the gear box. After I got it apart, I cleaned it out and I even used a straight pin and a pair of tweezers to get all of the gunk out. Now it runs like new. I'm no mechanic, but I used to help my daddy fix things around the house. I posted my solution to the problem and it has worked for a couple of other people too.
Posted on Dec 30, 2008
  • 3 Answers
SOURCE: hoover mach 3 cyclone vacuum
I had same problem. Turned out to be the filter that sits above the waste cannister. Remove the waste cannister. There is a little orange lever that releases the filter. It was caked with dirt not allowing any air flow causing the motor to overheat.
This foam filter gets dirty pretty fast.
Posted on Mar 01, 2009
galati2k
  • 281 Answers
SOURCE: suction problem
check the intake hose at the bottom it may be clogged.try blowing into the long hose if you can't blow through it then you have a clog somewhere between the long hose and your intake hose at the bottom.the intake hose is the somewhat clear hose that comes up from behind the base at the bottom.you will see it on the backside
Posted on Apr 04, 2009
I have a 4 yr old vx6000c central vac that constantly blows house breaker
This unit requires a 15AMP 120 VOLT dedicated circuit. If there are other appliances or items on this central vacuum circuit, this could overload the circuit causing it to pop. The other issue that could be occurring is that the central vacuum is on a GFI circuit or ARC fault circuit. Central Vacuum Units are not designed to run on these types of electrical circuits.
Please visit our website if you need a replacement part or if you have more questions. Or give us a call at 1-800-533-3249
Don't forget to like and visit our Facebook page.
https://www.facebook.com/QualityHomeSystems/
Jun 06, 2014 | Broan-NuTone Vacuums
Nutone cv750 problem
I doubt that's an electrical breaker - because it wouldn't take 10 minutes to flip, it would happen almost immediately. It must be the heat breaker. There are two reasons your vacuum system could be overheating and tripping that breaker. Either you need to replace the filter - if it's partially clogged then the motor may have to work too hard to get suction and cause it to overheat. I'd suggest checking the filter first, because that's the easy fix. If it's not the filter, then your motor is going out. You'll want to replace that. Check the filter, and let me know. I'll see if I can find a place to order a new motor for it.
Sep 01, 2007 | Broan-NuTone CV570 Central Bagless Central...
I have a broan central vac 24 yrs old ,vac works if you turn sw on cannister,not by plugging hose att,is this a major problem,thanks
Broan 450 air-watt and 8.5 amp power unit. Covers 3,000 sq. one 30-ft. crush-proof hose with on/off switch, one 10-in. wide hard floor brush features swivel neck for easy maneuverability around furniture. My new home is just under 2000sf. Will this new unit have enough suction?? Just buy or don't??
Jan 22, 2013 | Broan-NuTone CV350 Central Vacuum
Hi, I have a 1 year old XL Pro Plus Upright. Motor works fine, brushes are turning but it will not create any vacuum. we made sure thenew bag is connected properly and still no suction. Any advise? Thanks,...
The belt that turns the brush bar is probably stretched and worn. Once this happens, you will lose suction. When they get worn they stretch, thus causing it to spin on the bar itself.Just simply replace the belt with a new one that fits your machine.
Good Luck!
Jim
Jul 28, 2011 | Oreck XL Pro 18T Upright Vacuum
The unit turns on when hose is plugged in any of the outlets but we are getting zero suction.
Do you have suction at the unit? If you do not, then there is something blocking the motors in the unit. Otherwise it sounds like you have a severe clog.
You do not need to buy the tornado wipes, just use a paper towel.
http://www.centralvacuumstores.com/cvs/trouble_help.php
Jul 21, 2011 | Broan-NuTone CV450 Central Bagged Central...
Loss of suction. we have checked that there is ni blockage.
Disconnect the incoming pipe from the vacuum power unit and turn the switch on (on the side of the unit) while you feel the bottom of the unit with your hand. If BOTH motors come on and sound normal and are producing suction you should feel the bottom of the canister flex or you should feel suction at the inlet connection.
If the bottom flexes but there is no section at the inlet there is an obstruction in the pipes witin the vacuum unit. A stiff wire with a hook bent at the end is usually sufficient for removing the dust stuck in that piping.
You can also unplug the 110v poser then remove the top cover (only 3 or 4 screws) and visually inspect the motors and piping for failures.
Dec 30, 2010 | Broan-NuTone CV750 Central Vacuum
Decreased suction
you might have a clog, to try and unclog the lines, you need to unplug the unit, and remove the bag compartment. Then take a shop vac using the hose attachment hold it into the attachment door where there is low suction and try to draw the clog out the way it went in.
May 09, 2009 | Broan-NuTone CV353 Central Vacuum
I have a one year old Beam central vac. It has supervalves. The handle (connected to the hose stopped turning on the unit. The handle still powers the brush but no longer turns on the suction?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=566201
Generic problem for all Vacuums
I have a one year
posted by jon89 on May 02, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Beam Central Vac may have more than a one year factory warranty and it sounds to me that you may have a bad relay switch the Central Vac, if you do it should be covered under the factory warranty. Otherwise, you may have a bad supervalves or a wire came loose, if the hose switch turns on the power nozzle then it may be a bad supervalve or a bad relay and to contact the installer or the manufacturer of Beam. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.beamvac.com/usa/ Owner Support
Customer Service 1-800-369-2326 Phone #
Email: beam.dir-support@beamvac.com
Technical Support: beam.tech-info@beasmvac.com
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 02, 2008 | Vacuums
Vacuums Logo
308 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
