Question about Oki Electric Industry MB280 MFP 22PPM 120V-E/F/P/S Printer
I have an OkiDATA MB280 multifunction printer/copier/fax machine that has developed a permanent paper jam problem. Each time I remove the cartridge from the machine, there is no paper in the pathway. Further, when I feed a single sheet through the bypass slot, the paper is taken up, ultimately "jams" and when I pull out the toner cartridge, the paper has moved past the fuser into the outlet tray but the "Paper Jam" warning still comes up. I've changed the cartridge, including using the "smart card" to let the machine know that this is a new cartridge. Any suggestions? Thanks Doug
5 Suggested Answers
SOURCE: My oki printer b430dn is flashing 380 paper jam
Hi
You have to look under the cover remove the black plastic cover, Remove in the left side by sliding the litte plastic tab in to the mittele and gently pull up, when it is loose in the left side slide it on to the mittle and it will go of in the right side too, Now remove the next black plastic cover, it's all black with at little "sharkfin" i the center, Just pull genltly upwards, and under there is the "380" It is at little tab, just wrikele it a few times. Now just assemble the printer an you are good to go
Posted on May 17, 2010
  • 18 Answers
SOURCE: error code 391 paper jam - no paper jam though.
Check the area where its showing the paper jam to see if there are bits of paper there. Most of these issues are caused by tiny pieces of paper blocking the sensors.
Posted on May 04, 2011
Poul_g
  • 97 Answers
SOURCE: I HAVE PROBLEM. THE PRINTER
Take out the InkJetPrint (The big black thing that gives the black inc) and reinsert, should clear up.
Posted on May 08, 2011
davidmamian
  • 543 Answers
SOURCE: Put a new toner in, now says "paper jam"
There is little of paper in printer. Take the toner out and with very attention see, it must be in taht place, from where the paper going out, or that place from where taking paper, it can bee small paper.
Posted on Oct 28, 2012
How can i fix paper jam when no paper is seen
The paper jam may be in some inner part of the feed path. You may have to do some disassembly and use a bright light to find the jam then figure out a way to remove the material.
Jul 30, 2014 | Canon imageCLASS D-480 - 23 PPM...
Printer won't print after clearing a paper jam
I use to have an HP All-In-One Laser Jet printer that, for reasons unknown to me, wouldn't print after clearing a paper jam until I replaced the ink cartridge.
Jan 13, 2013 | Canon IMAGECLASS MF-6530 Multifunction...
Oct 12, 2012 | Oki Electric Industry Okidata Okidata...
Paper jam s405
Update your printer firmware http://bit.ly/t7sPJR.
There are a number of conditions that can cause paper jams. First, check the condition of the paper. You should use only clean, undamaged paper designed for inkjet printers. Remove the paper and fan the edge to make sure it is not sticking together.
Next, make sure that the paper is properly loaded. The edge guides should be snug against the paper without causing it to buckle. Do not force paper into the printer.
Finally, check that there are no obstructions in the paper path. Use a flashlight to look into the printer. If you are physically able to lift your printer, remove the paper, turn the printer upside down and shake it a few times.
Apr 26, 2012 | Lexmark Interpret S405 - multifunction ...
Wad of paper has become jammed in X6675, can't pull it out
Try to carefully remove the sheets of paper one at a time and avoid tearing it, any torn pieces of paper in the printer can cause future paper jams if left inside. You can also access the paper jam by opening the cartridge area.
May 08, 2011 | Lexmark X6675 Pro Colour Wireless...
My HP M1319f fax machine diplays a "No Print Cartridge" error.
I have checked for paper jam, remove the paper and cartridge was recognized.
Mar 02, 2010 | HP Laserjet M1319F Laser Multifunction...
Panasonic fax kx-fp153
Please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Panasonic KX-FHD332 Plain Paper Thermal...
Jammed paper
u have remove toner form the printer then u can remove by hand
Jan 16, 2009 | Canon imageCLASS MF4690 Multifunction...
Paper jam went try to sent a fax
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Step
Step
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Step
9
Mar 30, 2008 | Lexmark X4270 All-in-One Multifunction...
Paper jam
If the jammed sheet is entirely within the printer, remove the sheet as follows:
r_1.gif Make sure that the printer is turned off.
r_2.gif Open the printer cover by pressing the latch on the left side of the printer and lifting the cover up all the way.
r_space.gif r_warn.gif Warning: r_space.gif r_space.gif Opening the printer cover exposes the fuser, which is marked CAUTION Hot Surface Avoid Contact. Be careful not to touch the fuser. If the printer has been in use, the fuser may be very hot.
hppe004.gif 1. CAUTION Hot Surface Avoid Contact
r_3.gif Remove the developer cartridge.
r_space.gif r_caut.gif Caution: r_space.gif r_space.gif When removing the developer cartridge, never touch the developing roller under the flap; otherwise, print quality may decline.
r_4.gif Remove the photoconductor unit.
r_space.gif r_caut.gif Caution: r_space.gif r_space.gif Never touch the photoconductor unit's light-sensitive drum; otherwise, print quality may decline.
r_5.gif Remove the paper from the paper path.
r_space.gif r_note.gif Note: r_space.gif r_space.gif If paper is jammed at the fuser, grasp the bottom of the paper and pull it out.
r_6.gif Reinstall the photoconductor unit, and then the developer cartridge.
r_7.gif Close the printer cover.
r_8.gif Tap the edges of the stack of paper on a flat surface and carefully reload it into the MP tray. (Do not reload curled or wrinkled sheets.)
Printing automatically restarts from the page that jammed. If the Paper light stays on after removing all jammed paper, open and close the printer cover to clear the error.
Oct 16, 2007 | Lexmark X7170 All-In-One InkJet Printer
Oki Electric Industry MB280 MFP 22PPM 120V-E/F/P/S Printer Logo
252 people viewed this question
Top Oki Electric Industry Office Equipment & Supplies Experts
Tony
Roger Binsfeld
Victorman
Victorman
Are you an Oki Electric Industry Office Equipment and Supply Expert? Answer questions, earn points and help others
