Question about Hitachi 42HDT51 42 in. Plasma SLC1551AW
Our Hitachi 42HDT51 monitor has been shutting off, however the lights on the panel and AVC box have remained green. There is no picture or sound, the screen is black. If I unplug the power cord from the back of the panel for 5-10 min. It will turn back on. Sometimes this lasts a few minutes, other times it will remain on for hours until we decide to turn it off. Once we turn it off, we go through this when we try to restart it. We have eliminated the Satellite receiver to rule that out as a cause and the problem remains when just using the off air antenna. This started a few days ago, after changing the channel. Any ideas??? Thanks
  • 1 more comment
  • C Anderson Mar 13, 2011
    Would this leaky/dried capacitor be on the plasma panel or in the AVC box? Would the single capacitor or an entire board be replaced? What would be involved in replacing a single capacitor? I think a friend has a capacitor tester we could use.
    To be clear--you are saying it is located on the back of the plasma panel where the power cord plugs in near the lower left side (when looking at the back). Just want to start looking in the right place :)
    Also, once the offending capacitor(s) are found, will they be have a number on them to know what to replace them with. Do you have a place/site you recommend for replacement parts?
    I assume this will require soldering the new capacitor in place. Is there anything special about soldering one of them? I have done some soldering in the past.
    Thanks for your help so far.
    Thanks. We will contact our friend tomorrow to get the tester and try to get started on this. Will let you know how it goes.
  • Hitachi Master
  • 2,098 Answers
The symptom has no issue on the input (channel reception) because the problem is internal and caused by leaky/dried electrolytic capacitor in the power supply section of your tv. It will produced an unregulated supply which will disable the unit because the supply will not go into complete cycle. It will make itself stable within a warm-up (a few minute) but the symptom will get worst. Leaky capacitor sometimes has a bulged/dome at the top and easy to recognize even without using the capacitor checker but the problem is the dried capacitor which has no physical indication of fault. It is better to have a capacitor checker/tester if you decided to fix it yourself. Once you've replaced the said parts you're unit will back to normal again. If you can't do the job yourself I would advice you to look for a qualified technician to isolate the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Mar 13, 2011
  • 3 more comments
  • Jdvillanueva
    Jdvillanueva Mar 13, 2011
    This is in the plasma power supply where the power cord connected, good that you have a capacitor checker, this is caused only by one capacitor but much better to test all capacitor there since the replacement cost only a less that $2 or $5 at the most. Much cheaper if you troubleshoot the board since I've already point out the parts you are going to check but it is your choice if you like to replaced the entire board. Gudluck...
  • Jdvillanueva
    Also when intalling the new capacitor, ensure that it is in the right polarity to avoid further damaged.
  • Jdvillanueva
    Yes, you're right. This capacitor has a working voltage and capacitance labelled on its body. Replace with same ratings. Once found the faulty cap visit ebay.com or digikey.com for replacement or your local electronics supply.
  • Jdvillanueva
    Since you've already try to do some soldering before I know you can also do it this time, just prepare soldering iron (30w), soldering lead, disoldering pump.
  • Jdvillanueva
    ok bro, have a nice day!
Green lights on screen blank no picture no sound nothing
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 23, 2017 | Hitachi 42HDT51 42 in. Plasma SLC1551AW
Hitachi Plasma TV Model PD32-A3000/AVC-A3000
Check for any fuse blown also, Otherwise it s a power supply fault.
Jul 30, 2008 | Televison & Video
My monitor does not turn a green light flashing
I dont have a solution but I will purchase your AVC-50 audio video box when your ready to sell it. Please let me know, I really need one!
Mar 04, 2011 | Hitachi 42HDT50 42 in. HD-Ready Plasma...
I have a Hitachi 42" plasma/ 42HDT51 and the power
Replace your buffer boards they are two unit located on the right of the plasma if you are looking the plasma from behind. Do you have any sound?
Thanks,
Nov 21, 2010 | Hitachi 42HDT51 42 in. Plasma SLC1551AW
Tv wont turn on
If your AVC works and would like to sell I will buy this unit
Jun 03, 2009 | Hitachi 42HDT51 42 in. Plasma SLC1551AW
Need controller box (avc-50)for hitachi 42hdt50m
i have one that works fine..the screen died on me and i am getting rid of it--Angie
Jun 01, 2009 | Hitachi 42PD3000 42 in. Plasma Television
Hitachi 42HDT51 - AVC-75 has no power
Hi its not so easy to fix without experience,especially hitachi brand (they use many parts not avaliable).I have kind of solution for you,i can buy avc box from you if you are interested.
br.Rafael
Nov 18, 2008 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Hitachi Plasma Model PD32-A3000/AVC-A3000
vertical red line on screen - I have a Hitachi plasma 42HDs69
Jul 29, 2008 | Hitachi 42HDS69 42 in. Plasma Television
HDMI Malfunction
You may have to activate that imput through your menu.Alot of plasmas have the ability to mute imputs.
Mar 03, 2008 | Hitachi 42HDT51 42 in. Plasma SLC1551AW
Hitachi 42HDT51 42 in. Plasma  SLC1551AW Logo
232 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
