Question about Dryers
KENMOORE GAS DRYER
START BUTTON. ONCE YOU LET GO OF THE BUTTON DRYER STOPS. IF I HOLD THE BUTTON IN IT RUNS BUT STILL NO HEAT.????
  • 481 Answers
Kenmore = whirlpool, when it comes to dryers.
  • i usually dont just post a link to a solution but in this case i think that this site has some reasonable suggestions to help you fix your problem.
http://www.applianceaid.com/evenheat.html
Posted on Aug 01, 2008
Stops and all the lights come on
Instructions
    • 1 Make sure the home's gas supply valve is turned on. Check your Maytag owner's manual to find the location of the dryer's gas shut-off valve. This is usually behind the dryer's front panel or in the back of the unit. Open the valve to allow gas to flow into the dryer.
    • 2 Open the lower front panel of the dryer to access the pilot light assembly. Press and hold the starter button as you light the pilot with a handheld lighter. If you have trouble getting it to light, release the starter button and wait a few minutes before trying it again. Once the pilot is lit, hold the starter button down for another minute to make sure it will stay burning.
    • 3 Close the dryer's front panel and run a test cycle to see if it is producing heat. Call a repairman to evaluate the problem if lighting the pilot did not restore the heat.
Jan 15, 2013 | Kenmore Dryers
If i press the power button the dryer goes on but once i stop pushing the button it stops. I tried to keep the button pushed but the dryer doesnt heat up inside.
what kind of dryer is it and send the model number,if it's a whirlpool/ kenmore and it has even heat you have a bad even heat board...copy and paste and read this,it should help you out...............http://fixitnow.com/wp/2003/12/20/mailbag-dryer-stops-when-the-start-button-is-released/
Apr 25, 2011 | Dryers
You have to hold down the start button, once you let go the dryer stops. When I put something on the button to hold it down theres no heat. Only heat on heat sensor mode.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 21, 2011 | Dryers
Dryer start button
The motor switch is not switching over. Either the switch is bad or the dryer is not tumbling fast enough to activate it. Eric
Aug 08, 2009 | Kenmore Elite HE4 Electric Dryer
GE dryer must hold start button to keep dryer running
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 20, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Apr 18, 2009 | Kenmore 73952 Gas Dryer
My Dryer will only work if I hold start button, when I release start button the dryer stops.
Anra, this is a classic symptom of a failed even heat board. I've seen a lot of these failures out there. Easy to change out. Check out this link. Catriver..post back http://www.repairclinic.com/0080.asp
Mar 26, 2007 | Whirlpool GEW9878LW Electric Dryer
My Dryer will only work if I hold start button, when start button is released the dryer stops working.
Anra, the problem is in the even heat board under the consol. This is a very easy job. Check out this link. Catriver, post back http://www.repairclinic.com/0080.asp
Dryers Logo
57 people viewed this question
Top Dryers Experts
