Question about Necchi 6022 Sewing Machine
I am a Janome certified sewing machine repair person, but the Necchi Omega seems to have a problem with it's tension unit. This is the 3rd machine of this model with a tension problem. The first two units, I got to work. On the latest machine, the tension is totally not working. I tried to purchase a new tension unit and no one can find it for me. I am not new at this, but need some idea of where to go for information.
SOURCE: necchi
Same here but found this, hope it helps you out : )
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Necchi_Sewing_Machine_Threading/Necchi_584_586_threading_Diagram.htm
Posted on Dec 26, 2007
  • 69 Answers
SOURCE: Tension trobleshooting
The proper tension for the 537 is between 4-6. You need to make sure that your presser foot is in the up position before threading.
Posted on Mar 01, 2009
bargainbox
  • 1388 Answers
SOURCE: tension adjustment
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
Best Wishes
Martyn
Bargain Box in Australia
Posted on Sep 10, 2009
  • 96 Answers
SOURCE: Manual for New Home Special Edition Necchi 6015
google manufacturer and email request
Posted on Dec 13, 2009
SOURCE: I need a manual for a Necchi Omega 6030 sewing
did you every find one??i am looking for one
wt1078@hotmail.com
Posted on Apr 13, 2010
I have a Necchi Omega 6147. How can I adjust the drop-in bobbin to use upholstery thread to sew heavy fabrics or leather?
You would need to adjust the tension screw so the tension is looser than usual. However, remember to mark the setting BEFORE making any adjustments so you will know where to return the original setting.
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Understanding Thread Tension Threads
Feb 10, 2017 | Necchi Sewing Machines
What kind or brand of needle do I get for my Necchi Omega Special Edition sewing machine?
Your owner's manual should tell you what type needles your machine uses. According to this site, 130/705 needles will work with your machine, are also very common, and are available in several brands: Schmetz, Janome, Organ, etc.
http://www.sewingpartsonline.com/necchi-6018-sewing-machine-parts.aspx
In addition, you will need to determine the needle sizes (60/8 through 120/19) as well as the needle point (universal, ball-point, sharp/microtex, top stitch, embroidery, leather...) so the needle is compatible with the thread and fabric you are stitching.
SCHMETZ Household Needle Chart
Be sure to change the needles frequently. A needle should be replaced about every 8 hours of sewing time. Sewists tend to skimp in this regard (although needles are the least expensive fix!), but the needle is the most frequent cause of sewing machine issues. So, if your machine begins to misbehave, the first thing to try is a brand new needle.
Jan 10, 2017 | Necchi Sewing Machines
Someone gave me a Parsons sewing machine cabinet. How do I mount my NECCHI- omega sewing machine to it?its currently just sitting on top of a desk.
Unless your Necchi has fold out prongs undernerath it will have to remain on top of the cabinet, unless you have a very handy husband!
Jul 31, 2015 | Omega Sewing Machines
Correct bobbin size for a Necchi Omega 6030
You can use either 16 or 16J. If your threads are loopy on the bottom side of fabric, the problem is either your needle thread tension is too loose or you have a snag in your needle plate where you have broken a needle. Check needle plate and clear snag if any. Then tighten up your needle thread tension until both needle and bobbin threads are in middle of fabric.
Jan 30, 2015 | Necchi 6030 Mechanical Sewing Machine
I have an omega necchi model 6147 sewing machine and i need a down load manual
here's a link for a manual, it's a hard copy, I looked for a
downloadable copy & I couldn't find one, if you don't want the
hard copy, I'll give you 2 sites to email & ask them about a manual
for the machine
http://www.sewingpartsonline.com/instruction-manual-necchi-6147.aspx
here are the sites to email
sewvacdoctor.com
a1sewingmachines.com
Sep 11, 2012 | Omega 6147 Sewing Machine
Can I do a cover stitch with my necchi omega
No, you need a coverstitch machine like Janome Coverstitch 1000CP
Oct 23, 2011 | Necchi 3537 Mechanical Sewing Machine
I have an omega 3730m sewing machine and i find that when i am sewing, the stitching underneath balls up nad is not tight. i tried to adjust the tension but nothing seems to work. any suggestions?
I find that re-threading both top and bottom threads fixes the problem. Sometimes the thread has not gone through the tension springs properly. try a new needle too.
Dec 08, 2010 | Necchi 6015 Mechanical Sewing Machine
Jan 20, 2009 | Necchi 3102 Mechanical Sewing Machine
Necchi 6022 Sewing Machine Logo
41 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
