Windows XP SP2, Intel DG965WH mobo. Two SATA hard drives, two EIDE hard drives (WD200EB). Suddenly one day, without warning, the two EIDE drives just disappeared from the Hard Disk Drive list and files on the drives could not be accessed. In addition, XP will not reboot with the EIDE drives in the system but the system seems to work fine when the EIDE drives are removed. The EIDE drives work fine in another system, running Win 2K.
    Genius:
  • 1,027 Answers
The problem sounds like you either lost the IDE channels on the MOBO or the chipset was updated with corrupt files.
run everest home and see if there are current updates for the northbridge chipset. if you have 2 ide channels on the board switch the primary and secondary ribbons and see if the hard drives are there. if your cdrom's are ide and after switching ribbon cables they disappear and the hard drives reappear your mobo lost an ide channel, you would need to replace the board.
Posted on Aug 01, 2008
Problem replacing sata drive with eide drive in HP A1330n
if hard drive show in the bios setting and not loading the window then your hard drive not work properly.change your hard drive.
Jan 16, 2010 | HP Pavilion a1330n (EL466AA) PC Desktop
Cd rom door won't open, and it won't play
Reisntall system without service pack 2
Reintall devices not working.
Or uninstall drives reinstall sp2
then reinstall drives
Personally I would leave sp2 uninstalled
but if it is installed prior to the drives it
might recognize them (microsoft likes to be 1st)
Nov 29, 2007 | Computers & Internet
SATA 2
Yes!
The good thing about SATA, is that once you plug into a SATA header on a motherboard, BIOS will recognize that device.
Jan 04, 2010 | Lenovo IdeaCentre K210 Intel Desktop...
IDE Ports not working on ASUS P5LD2-VM Mobo
Good Day sir, hi, Have you tried to enable the IDE on BIOS setup. If the Bios setup did not solve the IDE problem, check the IDE port of the HARD drive, check if there are bent pins.
If still wont work, you can buy a PCI to IDE/SATA card, this is an expansion card in PCI format with IDE and SATA port.We use this card incase the IDE or SATA on the motherboard gets bad. Connect it on the available PCI slot. Then connect the IDE cable of the Hard disk to this card. Thats it.
Nov 10, 2009 | ASUS P5LD2-VM Motherboard
Hanging on detection of drive when installing Windows XP
Installing Windows XP on a SATA hard drive is not a straight-forward task as Windows XP does not recognize the SATA drive. In order to install operating systems such as Windows XP on SATA drives, the latest SATA drivers are required.Download SATA drivers for the motherboard from the website and integrate them with the XP installation CD using software such as nLite. SATA drivers can also be installed as third party drivers; you will be prompted during the installation process. Without proper SATA drivers, installing Windows XP on a SATA hard drive is not possible as SATA mode would have to be disabled in the BIOS to continue with the installation.
Installing Windows XP on a Serial ATA hard drive is not an easy task, because the system does not recognize SATA drivers at startup. Windows XP Pro SP2 fares a little better with SATA drivers, but here is what can be done in cases where the driver is not recognized.
Mar 31, 2017 | Excelstor Technology J880 Hard Drive
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Controller Driver Issue on Armada M700
I am running a Armada M700 with a Hitachi HTS541060G9AT00 60GB Hard Drive - Ultra ATA-100, 5400 RPM, 8MB. The driver that is loaded in mine is on both primary and secondary is atapi.sys. This driver is also installed on the Intel 82371AB/EB PCI Bus Master IDE Controller, along with intelide.sys. The main difference is I am running Window XP Pro SP2. But I believe that they should use the same driver.
Hope this helps.
dferguson64
Sep 09, 2008 | Compaq Armada M700 Notebook
Pc hangs up oftenly or show blank screen
Set your C Drive as Master and other all Drives as Slave
I Think this will slove your problem
Try IT
Mar 07, 2008 | Intel D845GVSR Motherboard
Wont Install
Ofcourse you will need it..Get your DVD writer's brand and model...
Oct 27, 2007 | Intel DG965WH Motherboard
SATA won't work
I think you're saying you've got XP installed, but the second drive isn't showing up.
You need to format the drive.
Right-click My Computer/Manage/Disk Management.
The drive should show as unallocated. Right click and select format. It may ask you to create a partition first.
Oct 16, 2007 | Intel Motherboard
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
