Question about Dryers
The dryers heats up but doesn't completely dry clothes. After 10 minutes a code Ad appears in the timer slot. What is the issue?
    President:
  • 3,074 Answers
AD is air dry, more then likely the vent is restricted and needs cleaned out, you will need to clean the inside of the dry out,also. You thermal fuse is bad. here is a website that will help Good Luck Tim
http://www.davesrepair.com/DIYhelp/DIYthermalfuses.htm
Posted on Mar 12, 2011
Frigidaire Model FEQB2152FE1. Start dryer and after 5 minutes "Ad" code; lights blink dryer drum turns, but does not dry clothes
Check that exhaust air vent is venting air. If not, clear vent and retry.
Check that heating element is heating. if not, check overheat switch for continuity with power unplugged. If you don't have continuity get new switch. If it reads ontinuity then suspect the heating element.
Aug 20, 2013 | Maytag Clothes Dryer Almond Timer Knob...
Timer goes to 99 minutes and clothes note drying all the way
Hi cayjr1
Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry.
But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
Please take time to rate me
Bud
Oct 09, 2012 | Maytag Neptune MDE5500AY Electric Dryer
My dryer keeps shutting off after a few 10 to 13 minutes...and clothes are not drying. An element was changed some time ago. it does heat up but keeps shutting down...is it the timer or element?
Turn the breaker to the dryer completely off and back on again. Also check that nothing is blocking the venting. Remove the vent hose and run the unit if you are not sure. Make sure the lint trap is cleaned first. It probably is neither element nor timer since it is heating and quits without the timer advancing completely.
Apr 05, 2011 | Maytag HYE3657A Electric Dryer
My dryer is not drying my clothes completely. I have to set it to time dry for at least 120 minutes to get a load of clothes to dry. I can feel that the dry is warm .I usually dry my clothes on optimum dry...
Your dryer has a double set of heating elements
1 side of the coils is probably broken and you are getting half the heat.
This is making the dryer take longer to dry them clothes.
Air restrictions in the dryer and vent can cause the heater control to shut down quickly also.
If you have a bad breaker the power will sometimes work and sometimes not.
If all of these are good you might have a problem with the timer.
Most of the GE timers have leaf switches in the that get a burr on the contacts. The come apart simple enough.
I have more HERE
Apr 01, 2011 | GE DWSR463EGWW Electric Dryer
I have a Kenmore 70 top load dryer that is not heating. And the timer doesnt turn off anymore either. Both items seem to have malfunction at the same time. Help?
This is typical. If the heating element is no longer working, the unit doesnt know to turn off due to the clothes still being wet. However, the timer has absolutely nothing to do with the heating of the unit. If the timer doesnt turn off the unit even when the time is short (example: 10 minute timed dry), the timer has a different issue. If you have merely set the dryer to dry the clothes (not a "timed cycle" to dry) then the dryer will continue to run as I have stated before. The dryer will run until the clothes are dry. Now, its time to address the heating part. Your dryer heating element has gone bad. It can be replaced if you are somewhat handy. You can pick one up from your local appliance store and it has simple instructions. Please make sure that you disconnect the unit from its power source prior to attempting any repairs. Safety First. You can also call someone to replace it for you and it shouldnt be too costly. Good luck on either option.
Feb 08, 2011 | Kenmore Dryers
The timer keeps readjusting while drying clothes, will say there is 45 minutes left and clothes are perfectly dry, this could be a fire hazard if left unattended.
you will need to clean the vent tube/internal duct work:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature then the thermostat tells the timer to begin advancing. The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
if the vent/duct work is clogged then the
I hope this helps here is a website on how to remove cabinet:
http://www.partselect.com/dryer+amana-open-cabinet+repair.htm
Oct 24, 2010 | Amana NED7200TW Electric Dryer
Dryer has to be run repeatedly to complete one load. shuts off before clothes are dry. is this a sensor issue, and how is it replaced?
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Aug 05, 2009 | Dryers
We have a Kenmore Elite gas clothes dryer (110.73952101). It will not completely dry large loads. We have to reset timer and restart the dryer. If we set timer for 40 minutes, dryer may run for 10 minutes...
Loads may be too large. Also when you reset and restart, the heat overload is cutting out. If your discarge is kinked or not venting properly this will cause it not to dry as well. Also check your lint screen. Good Luck!
Apr 13, 2009 | Dryers
Dryers Logo
108 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
