Question about Garmin nuvi 1200 Car GPS Receiver
I just took my Garmin 1200 out of the box and plugged it into the cigarette lighter in my car and it did not work...I have a blank screen...my car is 12 years old!
  • 72 Answers
No power at all?
Check your lighter socket to see if it's getting power (plug lighter in and see if it gets hot). Check the power plug on the provided cable. It contacts a fuse that may either be missing or blown. And last, check the connection of the cable as it plugs in the rear of the Nuvi.
Posted on Mar 12, 2011
'93 Jeep won't start - used cigarette lighter for gps instead of power socket
Sounds like a bit of a stretch... (nah).
"Lighter" is a GREAT OUTLET...
Has been for decades.
Perhaps it is just time to consider some BATTERY MAINTENANCE... cable and terminal cleaning
or even A REPLACEMENT battery.
I ASSURE you a cigar/cigarette lighter ELEMENT
pulls a lot more power than your Garmin Nuvi 1450LMT.
Get your JEEP battery checked...!!
Carnac the Magnificent
Jan 07, 2018 | Garmin Nuvi 1450LMT
Garmin e-trex Vista - blank screen
I would suggest that you contact Garmin for a replacement if you still have it under warranty. If your computer can still detect the Garmin when plugged in you might still be able to update the firmware but as you said it does not turn on then that would be a remote possiblity so it would be best to have it replaced if it is under warranty
Aug 19, 2008 | Garmin 010-00358-00 GPS Receiver
Garmin says low battery and now will not work in the car. Does this Garmin have a battery inside the unit that I have to replace?
There is a battery in the satnav but it's not user replaceable. It can only be replaced by returning it to Garmin. Before sending it away to replace the battery you could check the following;
  • Have you the satnav connected to the charger?
  • If it's connected to the charger is the cigarette lighter socket working. You can check by plugging in another device to see if it works
  • If the cigarette lighter socket is working and the battery of the satnav is not charging it's possible that the fuse in the plug, that goes into the cigarette lighter socket, is blown.
To change the fuse;
Unscrew the ring that's at the end of the plug and the plug comes apart. Be careful not to lose the silver coloured tip. When the plug comes apart you can take out the fuse and get a replacement at any car accessory shop or a shop that sells garmin satnavs.
If you have to return your satnav to garmin you can find their contact details at http://www.garmin.com/garmin/cms/home/support/supportcontact
May 23, 2011 | Garmin nuvi 255W GPS Receiver
My Garmin nuvi 780 will not turn on. When I turn on, the Garmin logo shows on the screen. However, when "Loading Maps" is displayed, 1-2 seconds later the screen goes blank. This occurs when the unit is...
I had the same problem. When you have your nuvi plugged into your cigarette lighter it doesn't charge. Your battery is probaly near dead. I called Garmin and they told me to plug it into my computer via the usb cable. Turn the Garmin off and let it charge for several hours. That did the trick
Apr 03, 2010 | Garmin nuvi 780 GPS
Garmin screen is all i get, then it turns off
try changing the batteries or placing the device on charge and unplugging it, if both those don't work go to the support section on garmin's website www.garmin.com/support/
Aug 04, 2009 | Garmin nuvi 200W GPS Receiver
GPS plug do not fit in car cigarette lighter
Buy a adapter for your cigarette lighter socket that has multiple sockets with one that will fit the Garmin adapter.
I've never heard of a problem you are having??
Are you using a Garmin plug?
If not get one.
May 08, 2009 | Garmin Nuvi 660 GPS Receiver
Blank Screen on Garmin E-Trex Vista
The problem is that your software version needs updating. A recently added satellite creates a glitch in the older software. Go to the Garmin website, load WebUpdater if you haven't already done so, and the updated version (3.8) will automatically install to your Garmin unit. I had the same symptoms, they have now disappeared and my Etrex Vista is back to normal.
Oct 14, 2008 | Garmin GPSMAP 76CS GPS Receiver
Garmin. Supposed to be easy
Have you tried resetting the unit? Press the reset button under the faceplate and see if this helps. If not, you may need to do a Master Reset. Keep in mind, this would ERASE ALL YOUR FAVORITES and may remove some of the updates as well.
Feb 09, 2008 | Garmin StreetPilot C330 GPS Receiver
I can't charge my GPS while I am in the car
Verify that the car cigarette lighter outlet is working. Do you have something that you could plug into the lighter like a light?
With the car running plug the Garmin into the cigarette lighter outlet. Does it come on without pushing the ON button? If the answer is no then there is either a problem with the cable or the cigarette lighter outlet. It should come on by itself if the lighter is working. Also are you using Garmin cables and DC adapter?
Jan 31, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin nuvi 1200 Car GPS Receiver Logo
87 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
