Mitsubishi green blinking light then it wont turn on
  • 3 more comments
  • sherwoodjljs Aug 01, 2008
    ws 65515 blinks for standard amount of time as it always has but no responce hint i alwies suhut the tv down with a power strip on highnsight probally fouled a relay or something
    no response to pushing the buttons
    were is that located were the power cord comes in ?
    i found one small standard fuse it looks good the - + line fuses look good i see fuses that look like diods green labled fuse is this also a fuse
    ill have to do it tomarrow my fulke meter quit have to bring one from work tomarrow thank you for your help
  • 8,617 Answers
I will need the model number of your set and also need to know if the led blinks constantly or not. Please reply to this same post when responding.
Posted on Aug 01, 2008
  • 3 more comments
  • Sonny Berry
    Sonny Berry Aug 01, 2008
    Have you tried pressing the menu button and the Devic/input button both in together on thr front panel and holding them both in together for 8 seconds to see if the set will blink a two digit error code? If so let me know the number blink code.
  • Sonny Berry
    I would check the fuses a couple of them may be blown as the set should blink an error code if its going into protective shutdown. Another thing common with that model is the convergence Ics shutting down and blowing the + and - 24 line fuses.
  • Sonny Berry
    yes, there should be at leats four fuses on that board.
  • Sonny Berry
    yes those are the Pico fuses, They need to be checked with a ohms meter. If those are blown ( no Reading) Let me know the board location number and I will post the most likely cause of the problem
  • Sonny Berry
    youre welcome
Green Blinking light on Mitsubishi Unisen lt 40164, tv wont turn on?
Blinking light means your bulb is blown and needs to be replaced. Very easy to do. Check owners Manuel . Shop the bulb on ebay
Dec 19, 2014 | Mitsubishi Lt-40164 40 Inch Unisen Led Tv
Mitsubishi hdtv
NOT A GOOD IDEA AT ALL!
You likely now have one of two things happening:
1. Green power light constantly blinks and will not stop(should blink for 70 seconds and go out).
2. Green power light comes on and a few seconds later goes off.
Which do you have?
May 17, 2012 | Mitsubishi Televison & Video
Wd-73737 wont turn on blinking green light
First is if you are able to get it to turn on and blue screen only appears it will shut down as no signal noted.
If you can get it on with Mitsubishi remote : Menu, 1,2,3 enter
This is the soft reset and the set also has a hard reset.
Try the soft reset first and let me know what happens.
Mar 09, 2012 | Mitsubishi WS-55613 55" Rear Projection...
I have a 60 in. mitsubishi hdtv. i just got it and the tv wont turn on and the green timer light kept blinking. now the green light wont even blink. thank you
Send an email to Paul on this Hi Def forum and he will send you detailed instructions for repairing your set inexpensively. Hope this helps
http://www.highdefforum.com/rear-projection-tvs/58189-blinking-green-light-death-frequent-prob-w-mitsubishi-rear-proj-widescreens-5.html
Jun 01, 2011 | Mitsubishi WD-62725 62" Rear Projection...
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
TV wont turn on, the power light turns green for a second then blinks three times and turns off?
That blinking light represents an error code,give Mitsubishi a call they will help you troubleshoot and diagnose your problem and if needed help you set up service. 1-800-332-2119 Good luck !
Nov 29, 2009 | Mitsubishi WS-55411 55" Rear Projection...
I have a mitsubishi 1080 projection tv. I wont turn on, the green light just keeps blinking.
Check the manual...blinking green light is normal. The unit is powering down cooling the lamp. It could have been a shut down command through pressing the off button by accident. If problem continues I would unplug tv and power on/off. Steady green. Next to the lights is a small indentation where you can reset the TV to the defaults. Take a paper clip ...power on..and put in the center. The green light will blink for a minute or two then go dark. THen power up.
Dec 10, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi Medallion HD 1080 model ws-48413
my mitsubishi medallion tv wont power on.
all I get is a blinking light. How can this be fixed
May 08, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Please help with tv! green blinking light wont stop and tv wont turn on
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
please post your error code
Dec 19, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
169 people viewed this question
Top Televison & Video Experts
Electro Med Services...
