Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
I have a problem wiht my 25 Hp vanguard backfireing
  • 2,019 Answers
There are lots of possibilities.
If the sparkplugs are fouled that can cause a weak spark, carbon residue that can ignite the incoming gas too soon.
A plugged muffler is also a common cause, and will happen the most at highest RPM.
Cross firing wires can also do it.
If nothing else, it could be a burned or misadjusted valve, which a compression test would help determine.
Posted on Mar 12, 2011
Changing the stator on a 757 ztrak john Deere lawn
1st need to know if it's a briggs vanguard or the kawaisaki model and what Hp they came with 17.5 to 25 hp models why ive even seen them with a honda v-twin on them i do have a youtube video on the briggsvanguard engine disasembly you can view anytime
Oct 03, 2014 | Garden
My briggs and stratton 18 hp vanguard model 356447 will not start just back fires through the carb. I have good comprssion and spark at both plugs. I replaced the flywheel key as thought the backfireing...
check intake valves for proper seating. If the valves do not close completely it will allow the engine to backfire thru the carb. Another possibility is internal timing caused by the misalignment of the timing gears between the crankshaft and cam gears.
Oct 29, 2013 | Briggs & Stratton Briggs Stratton Intek V...
Backfires
check for loose manifold bolts . Check for blocked air filter. clean out carby and jets
Jun 01, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
Backfiring
Backfiring is either burned valves or often due to timing slipped because of broken flywheel key/keyway.
Jun 17, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
I have a Toro ride on mower with a 17 hp Vanguard OHV engine about 6 years old. 17-44HXLE Model No 71283. It has a habit of backfiring and missing and occasionally stalling. I rarely have a problem...
Hi Samuel,
This is an indication that your carburator was malfunctioning due to dirt build up. Send it to shop to tune up the unit, If you can't find a qualified shop ask the manufacturer of your unit where is the nearest local service center in your area. Preventive maintenance is needed by this kind of unit to function well. Also they will clean or replaced the spark plug.
Hope it may help you.
Thanks for using Fixya.
Feb 07, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
My briggs vanguard v-twin 16hp after initial start up this fall started leaking fuel from the carb into the cyl. and into muffler. The jet is seated and not dirty. It leaks somewhere else in the bowl. ...
The solenoid on the bottom is a fuel shut off solenoid to prevent backfiring if shutting down engine with the throttle still open. If you're leaking fuel into the engine, the float is not closing the needle valve in the carb. remove fuel bowl and replace float, and needle valve with seat.Be sure to blow out all fuel passages
Oct 15, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
I have a B & S vanguard 20 H.P. vert. shaft, 8 years old on Simplicty tractor. Keeps fouling plugs. Clean or replace plugs and it runs fine for about 1/2 an hour then starts to miss, blacksmoke, and...
Anti-foul plug adapters might be a temporary solution (treats the symptom and not the cause).
Personally, I would take it to a good, reputable, small engine repair shop that has verifiable references, and have them repair it.
Aug 03, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
I am considering purchasing a used Exmark with a 23 HP Vanguard engine (~70 hours on the engine). I've not been too pleased with Briggs (have one on my John Deere garden tractor - hot natured and...
yep its a briggs and normaly there very good ploders
if your john deere spluters and back fires it needs a good looking at check the valves first,,,a hand full of bolts and the heads off and if your carfull you can still use the same head gasket again,,,also check the carb there very finiky and need to be kept clean the air filter is a joke,,,but clean it anyhow and they like new plugs,,,every ten years or so? iv worked on 100s of brigss and stratons/vanguard. there good engines but there ploders not sprinters there ok in a tractor but no good in a tank there to darn slow
Mar 27, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Engine appears to run normaly until PTO is egaged,then it backfires and quits. Engine is an 18 HP Vanguard twin, model 350777.
Check you float in the carb I had one a few years back and it was partualy plugged cleaned it out and everthing worked fine. Also is the PTO binding up or bearings going bad putting an excessive load on the motor.
Jul 04, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
435 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
