I have Panasonic TC 14S72 portable colour TV. Height is less. I need service mode
  • 899 Answers
SOURCE: height is small in aiwa
this is the conversion chip and vertical deflection chip that need to be replaced
service mode will only make the color alignment worse since the conversion chip is failing so it won't align properly
it will need that repair
Posted on Oct 16, 2008
  • 4 Answers
SOURCE: service mode for hi sense tc3418uf
Hit the menu button. By hitting the volume button once you will see a menu to adjust TV. Click down by hitting channel to TV frame. Click adjust volume.
Posted on Jan 04, 2009
  • 864 Answers
SOURCE: Panasonic TC-P54S1 mounting hole pattern
See page 8 of the manual at: http://service.us.panasonic.com/OPERMANPDF/TCP42S1.PDF The bracket shown there looks like the mounting holes (4?) are vertical on the back of the TV. They may be identified by an arrow pointing to them. There will be two holes on each side of the TV centerline to attach the vertical components of the bracket that hang on the horizontal angle bars on the wall.
Posted on Oct 06, 2009
gopakumarg43
  • 74383 Answers
SOURCE: nececito el codigo para tv panasonic viera TC-L32X30A
Get in to this site "Electro-help". The site had all details you want. Serch for code by brand name. Four digit codes and synchronisation methods given in detail. Type in the site name, either to Google or Yahoo search box, and click search. The site is powered by Google.
Pull up older posts there.
Three digit codes for Panasonic are: 003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
Posted on May 25, 2012
SD Tech
  • 14553 Answers
SOURCE: Panasonic Viera 65 inch tv shut off, will not turn back on. Red light blinks 7 times.
Power supply or related to it.
Posted on May 26, 2012
How to adjust vertical height for panasonic crt tv model number TC-2119R
To adjust height and other parameters, you have to enter its service mode option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window".
Aug 03, 2015 | Panasonic Televison & Video
What is theService mode code for sansui tv using IC TDA9370ps /N3/A/1839?
Jul 30, 2014 | Sansui Televison & Video
A reset button for panasonic TC-P42ST30?
There is no such reset button for this TV. You have to enter its service mode, to make a system reset. To get more details, http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular TVs are given.
Nov 28, 2013 | Panasonic Televison & Video
May we request the diagram of panasonic TV power supply TC - 21f3p.
All service manuals are available at the Panasonic National Parts Center which can be contacted directly at 1-800-332-5368 9am-8pm EST during weekdays.
Sep 08, 2013 | Panasonic Tv Service Manual Model Tr-120v...
Hight less
Hello
You have only stated that the height of the picture of your TV is less. Check whether your TV is working on "wide" mode. The mode should be set to "normal" for a full screen picture. There may option to turn the mode; through remote control handset of your tv. Select it, after entering into menu option and check. There are normally 3 modes will be displayed. "NORMAL, WIDE, ZOOM". You have to select "Normal" mode. If this does not helps, your TV needs height adjustments. It can be done only through some code send to the tv via remote. It is known as "service code". It is uneque code, and can be had only with the help of a well experienced technicin. If the problem pereists contact any one of such mentioned above.
gopakumarg43@ymail.com
gopakumar1@hotmail.com
Oct 19, 2010 | Zenith C27A24T 27" TV
How do you get the set into Service mode to adjust
try the zoom button on the remote or go into your menu and see if you can find something there
Feb 13, 2010 | Televison & Video
Oct 06, 2009 | Panasonic TC-P54S1 54 in. Plasma HDTV
Tv turns on for two seconds, shuts off, begins binking.
The problem is most likely a power supply related problem.
The TV is in protection mode right now. It's keeping the other parts inside the TV from being damaged by automatically turning itself OFF. The 9 blinks should be an error code for the problem with the power supply. I don't have the Service Manual for your TV model number to tell you what the code means and which part to replace. Every brand of TVs have a different meanings of the code.
If you have electronic experience, you can find a factory repair manual over the internet. Normally, it's called a Service Manual. It costs about less than $20.
Jul 31, 2009 | Panasonic TC-26LX70 26 in. LCD Television
Service mode for hi sense tc3418uf
Oct 30, 2008 | Hisense TA42P40M 42 in. Plasma Television
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
