Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
Working great, lots of steam. Then no steam at all. Help
  • Euro-Pro Master
  • 43,501 Answers
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Posted on Mar 23, 2011
Black & Decker Steam Buster SV1000. Can't get to steam (or spray). Never used before but have had for several years. Nothing clogged. 50 water/50 vinegar in water reservoir. Vacuum works fine. Pump...
The impellar or your water pump is on its very last broken fin, time for a mew machine or the long hunt to find a replacement impellar
Nov 06, 2014 | Vacuums
Oreck vacum steamer stopped steaming
Probable failure of the steam generator
Jun 03, 2014 | Oreck steam-it Stick Vacuum
I was using the steam mop this morning working great, went to put on the attachement for carpet, that's all I did, and now it doesn't work, no steam comes out, I don' know what happened one minute it was...
Hey it just broke like most of them do...
heatman101
Sep 06, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Steam coming out but no water is being distribued for the steam to dry it
If you have used it a lot and you have hard water... the calcium deposits will clog the water dispenser. That's what happened to mine. I cleaned it out with white vinegar and it started working fine. It's simply something clogged in the water dispenser.
Zashiban
Jun 28, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My hoover steam vac will not **** up the water on the carper.
the lid on the tank is not on properly or the duct/block that fits in the front of tank is missing..
May 05, 2010 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
My Hoover Steam Vac Ve brushes stop working
Hi There,
You'll need to try and diagnosis what is causing the brushes to stop spinning first. A lot of the times this can just be caused by debris stuck in the brushes. I have written a in-depth repair solution on how to diagnosis the brush problem here:
http://www.fixya.com/support/t4286338-hooverspin_scrub_brushes_always_stop
If it just needed to be cleaned, and this fixed your problem, great! If not however, and you need to replace the turbine assembly inside, here's another repair solution that I've written that explains step by step how to replace the turbine assembly:
http://www.fixya.com/support/r4530769-diagnosis_fix_hoover_steamvacs_when
If you need further help, or have any specific questions, please just use the comment field here on the Fixya repair page, and I'll be more then happy to help you, and answer any questions that you may have.
If you found this repair helpful, it would be greatly appreciated if you could send some feedback and/ or rate the repair helpful by clicking on the 4 thumbs up icons.
Thanks again!
Chris Jones
GoVacuum.com
Apr 23, 2010 | Hoover F7431-900 SteamVac Vacuum
Bessell steam cleaner #%$@#%%$%
Model number would help. With water squirt out of the hose? If it does then the heater in the handle is probably clogger and will have to be cleaned out. If no water, then is the pump belt ok? If it is then you could have a bad pump. Also check that the seal is on the bttom of bothe tanks, and not sitting in the hole that the tank sits in. It has to be on the valve on the bottom of the tank.
Feb 13, 2008 | Vacuums
No steam coming out
The fall might have damaged or moved the trigger so that it does not depress the valve on boiler.
Try removing the screws which hold the handle together. The cap needs to be removed to allow the handle to separate.
Once the handle is apart check the trigger piece looking for any broken parts.
Jul 07, 2007 | Euro-Pro Shark SC-505 Handheld Steam...
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Greg Cann
Greg Cann
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
