Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA D52W20; no power
Heard a pop and the tv turned off. I'm guessing a fuse. Found one that is burned out (125VAC). Is this my only problem? Where do I find a replacement fuse? Thanks.
  • RCA Master
  • 8,617 Answers
If its the regular glass fuse, radio shack should have a replacement for that just bring the old fuse with you so you can get the correct amp fuse. If it blows again, let me know and I will try to assist you as usually fuses blow for a raeson. Please respond to this same post when replying.
Posted on Aug 01, 2008
I have a RCA D52W20 in. Rear Projection HDTV. Just a few minutes ago there was a loud pop while watching tv and then the picture when black. I immediately turned off the television, checked behind it, and...
This TV if the model # is D52W20 ,`Then it is Projection and has 3 Tubes Red / Green / Blue
these tubes Cost over $450.00 each problem will be in the Deflection Board/ it will be the bottom left hand side board that has the FBT flyback Transfomer on it.
Most common repair is 3 capaciotrs on the deflection board CP150 2200uf 16v use 25v, CP114,CP120 220uf 35v replace all 3 caps.
Dec 15, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a HD52W55 and it will not come on. heard a pop and smelled something burning, took the back cover off can not find anything obviously burnt but have no lights and no power.
Well, my first guess would be a blow fuse, did you check for that?
But if you smelled something burning, then even if the fuse did blow, it failed to protect something; probably the main power transformer. That's a coil of wire in a sort of square shape that should be near the fuse. Its hard to tell if they're burnt sometimes, but it may need replacement.
Please upload a few pictures so we can have a look too.
Mar 25, 2010 | RCA HD52W58 52" TV
Turned on tv no picture only sound then i heard a pop and smelled burning tv turned itself off. 5 min tried turning on tv again nothing happened tv does not turn on at this time
Your RCA TV needs serious troubleshooting. Burning smell is from HV transformer or resistors smoking.
Most likely power supply and/or high voltage circuit or convergence circuit. Many times RCA have multiple or secondary faults that occur with HV or convergence failure.
Repair of RCA HV or convergence usually requires exact manufacturer parts and upgrades or repair in power supply. I would not advise trying this repair without manufacturer support for correct part numbers and service bulletins.
easyab
Feb 28, 2010 | RCA Televison & Video
RCA projection, no power, no sound. recently moved.
Ur DM power board have burn capacitors,check for puff up capacitors,and replace it.Tries these websites.Tv Repair World.com Shopjimmy.com Ebay.com or Partstore.com.
Sep 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV made a popping sound and then faded to all red. Now if you turn it on, all red with wavy lines and shuts off after a minute. 2 years old
Ur video board inverter is dead.
Need a new one.Keep turn on with out changing the board it will burn the power inverter board too.
Aug 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Have a 52 inch rca d52w20 rear projection tv, the tv was on then it just turned off..attempted to turn it back on and heard a sqeaking noise and tv will not turn back on.. please help..
replace the flyback, very easy repair. You need flyback 259296 you can getone at the following link with free step by step instructions with pictures. heres the link read their reviews.
http://servicemanuals.vstore.ca/
Jan 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 52'' rear project. d52w20 smells and powers off
you need to replace the flyback number 259296 very common problem and easy repair. You can get a replacement flyback at the following link with free detailed instructions with pictures so you can easially do the repair yourself. Heres the link.
Nov 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 Fuse problem
Well you could always use a bigger fuse but I would not advise to do it, it could and most likely will blow tv not fuse. Fuses ussually blow from a short or power surge. If it is new or under warranty I would return it for replacement or repair.
Jul 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Heard popping now want turn on
Hi there!
Something did pop. Could be the fuse or something else. My guess as good as yours. Good luck, JUS004
Feb 26, 2008 | GE 25GT538 25" TV
RCA D56W20 no power
Opps! Your problem is most likely in the power supply section. No doubt a blown fuse, a diode or two and probably a few resistors. To be sure that you found all the problems you will need to check all the components in the power supply. If you know how to use a DMM have at it, safely of course. First unplug it, if you already haven't done so. Check the fuse for continuity. If you are lucky that may be your only problem, but don't count on it. Look for burned components or burn marks on the circuit board. Don't overlook resistors with large values and replace any components which do not test within the proper parameters. When you are sure that you found all the problems don't plug the unit back in to 220 or you will have to do it all again. Get the appropriate sized 220/120 transformer which means one with a current rating higher than the current draw of the TV. That information should be on the data tag on the rear of the unit. Again, remember safety and Good luck.
Jun 29, 2006 | RCA D56W20 56" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
101 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
