Question about Husqvarna 155bt Gas Backpack Leaf Blower
Where is the air purge on the husqvarna 150bt backpack blower?
4 Suggested Answers
boscia
  • 163 Answers
SOURCE: leafblower
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. check the primer bulb for pin holes and seating/sealed properly. if that doesn't work have the carb repaired at a service center or replaced.
Posted on Nov 30, 2008
jdlipscomb41
  • 157 Answers
SOURCE: I have a husky 150BT backpack blower. When I
sounds as though you need to install a new kit in the carb or try adjusting the carb
Posted on Sep 18, 2009
  • 251 Answers
SOURCE: husqvarna 125bt backpack leaf blower. I put
if you've ran it for any length of time you will need a new cylinder and piston/rings and cylinder gasket ,
take the muffler off and look for scoring /scorching on the piston
Posted on Oct 21, 2009
Compression on 150bt blower from factory
Any 2 cycle engine must have 90 PSI or higher to run. Typically a new engine will read around 100 - 120 PSI with Gage on and pulling rope 3-4 times.
Jun 29, 2016 | Husqvarna 50.2cc 2-Cycle Professional Gas...
How to disassemble the throttle/trigger assembly on at Husqvarna 150BT blower.
Internal or external snap rings usually require a special pair of pliers to remove. In absence, you might try a very pointed pair of needle nose pliers or even a pair of dental tools or similar. Once the ring begins to dislodge from its groove you should be able to work it out. Reinstallation might require the specific tool.
Oct 03, 2014 | Husqvarna 150BT 50CC Gas Leaf Backpack...
Why is it failing?
open gas cap and see if it will run again. m,any times the gas tank vents clog and the engine can't draw gas after a few minutes.
another thought is the oil mixture.. 50:1 with oil made for air cooled engines....not boat engine oil
Apr 02, 2014 | Husqvarna 150BT 50CC Gas Leaf Backpack...
Plastic tube for blowing the air keeps falling off the blower. The clamp won't keep it in place
easy solution....just screw 2 small sheet metal screws into the tube to hold them together
Sep 06, 2013 | Husqvarna 150BT 50CC Gas Leaf Backpack...
Start
They are refering to the 'fuel primer bubble' located on the bottom of the carb.
Jun 23, 2013 | Husqvarna 150BT 50CC Gas Leaf Backpack...
Leafblower
Oct 18, 2008 | Husqvarna Backpack Blower 25cc, 140 Mph,...
Husqvarna 155bt Gas Backpack Leaf Blower Logo
387 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
