Question about Maytag MSD2454G Side by Side Refrigerator
Maytag Model MSD2454GRW side by side - the refrig door is not sealing tight about halfway down the door. Is there a adjustment I can make to help to door seal properly?
  • 55 Answers
Check to be sure the frig is sitting level. You should have leveling adjustment on each side below the doors and behind the grille. Also, on the bottom door hinge (usually fridge side) should be an adjustment to raise or lower the door to align the doors. After that if you simply have a deformed seal you can try carefully heating the seal with a hair dryer to soften it and should smooth out the wrinkles. Be careful not to over heat the seal. Good Luck
Posted on Mar 12, 2011
The refridgerator door is not sealing properly and the magnetic seal between the refrig door and the freexer door is hot.
Heat the seals with a hair dryer and then pull it tight - strap it tightly shut - you can also use some super glue to keep it in place while it dries.
Gary @ Fix Ya
Sep 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrig door does not seem to close as tight as it used too. Do I change rubber gasket? Will that help Frig is not very old.
look for door hinge problem as the door seal may be bad but i think the hinge cams have failed .. mm
Aug 09, 2010 | Maytag MZD2766GES Side by Side...
The freezer is freezing but the refrigerator is not getting cold why?
check the damper door vent located between the refrige and freezer for being iced up and stuck shut,if cold air from freezer can't get past thid door the refrige will warm up,if this isnt the problem,adjust the refrige temp control and watch and see if this makes this door open and close as you adjust the temp of the refrige compartment
Apr 03, 2010 | Maytag MSD2756G Side by Side Refrigerator
Older model fridge freezes on the refrig. side
check the damper door and see if its iced up this is between the refrige and freezer compartments and lets cold into refrige from freezer,if it ices up in the open condition the refrige control cant change the temp,defrost the door and then see if the control moves the door,if so also check the door seals to make sure they are sealing good so as not to let warm air in that can condense and freeze things like the damper door
Jan 16, 2010 | Refrigerators
Refrig door stays open
Your refrig has legs you can adjust down ... this will tilt the refrig to the back so it will close be itshelf...
hope it helps let me know if it helps
Sep 26, 2009 | Refrigerators
My refrig door wont seal tight can you buy
if you are having frost buil up on the model and it appears to be a freezer the seal may not be bad but you can not buy new magnets.the seal comes as one piece.you can do it your self.but try sealing the air flow vents in the bottom of the door with tape or silicone.the the diffuse plate in the back if it has slotted holes in it they can be covered with some aluminum tape.if you change the door seal the insultaion in the door panel should be change as well it more than likely has some ice build up in there
Sep 19, 2009 | Frigidaire FRU17G4JW Refrigerator
Maytag side by side fridge door vacuum lock
This is actually not a bad situation, it is a good thing that the vacuum is tight. it provides a greater level of freshness when keeping the contents cool of frozen. you can ease the tension by applying a gel solution or 3 in 1 oil but, i wouldn't recommend this.
This tight seal will save you on the electric bill as well. keeps the fridge from cycling to much.
A good tight seal is a good thing not a bad thing.
May 26, 2009 | Maytag MSD2656G Side by Side Refrigerator
Refrig door does not seal shut.
jack up the two front leveling feet a bit to make it lean towards the back. or put a level on it to see how far it is off.
Dec 04, 2017 | KitchenAid Superba Architect KSCS25IN Side...
Freezer side door opens when large refrgerator door is closed
no promblem when you shut one door it forces air to the other side remove the kick plate at the bottom adjust the rollers till the fridge leans back i set them so when you turn loose of the door slightly past the halfway position it shuts its self that way when it pops open it shuts its self
Feb 15, 2009 | Maytag MSD2454G Side by Side Refrigerator
Temperature 94 in refrig. normal in freezer
Check to see if refrigerator door is lower than freezer door. If so remove toe panel, (bottom front). Under refrigerator door hinge at bottom right is adjuster for door. Adjust upward so door is even. On some models when door is too low it causes light to stay on some times, raising ref. temps.
Nov 04, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag MSD2454G Side by Side Refrigerator Logo
222 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
