Question about NAD C545BEE
Pb with standby button from france. since a few weeks ago, the standby button of my c545bee doesn't work. it means that when the standby led is coloured amber, if i push on the standby button, the coulour doesn't change and the power doesn't come. BUT the cd player xorks well when i use the remote control sr8 or cd8. where do the pb comes from? thanks. jm
  • 4 more comments
  • caylajm Mar 12, 2011
    thanks for your response. but the "play" and the "eject" buttons should make power on, and it does not.
    jm
    for 16$, i was expecting an differnt answer than "contact the manufacturer".
    jm
    i think the pb doesn't come from the remote control because as i said in the original message "the cd player works well when i use the remote control sr8 or cd8". i said " the standby button of my c545bee doesn't work", as the "eject" and the "play" buttons: i can't switch the power on when i push on these buttons DIRECTLY on the c545bee itself. hopefully i can switch the power on with the remote control and then use my cd player. i saw after a google search that this pb have been ever reported.
  • caylajm Mar 13, 2011
    i don't understand your reply
    but, one more time, the remote control is working well. read my first message : "since a few weeks ago, the standby button of my c545bee doesn't work. it means that when the standby led is coloured amber, if i push on the standby button, the coulour doesn't change and the power doesn't come. BUT the cd player xorks well when i use the remote control sr8 or cd8. where do the pb comes from?". i wrote : the standby button of my C545BEE ... not the standby button of my remote control...
  • caylajm Mar 14, 2011
    nobody really answer to my request. read the request.
    the first one tasked me to contact the manufacturer!
    the second one told about remote control but it's not a pb of remote control.
    need some help.
  • 2,632 Answers
Hi JM,
Welcome to Fixya. This is not a quick fix, it seems that the problem with the player it the hardware part of the front panel though the sensor still works because you can still use the remote. You can check your system is it still has a warranty and check for repair NAD Dealers and Distributor are scattered all over the world. You can check the link below the check the nearest NAD on your area.
NAD Global Distributor
And if you have questions you can also look for the Faqs of NAD on the website below.
NAD Faqs
If you have questions please let me know. Thanks for using Fixya
Posted on Mar 14, 2011
    Top Expert:
  • NAD Master
  • 74,482 Answers
Hello
Check your remote control's infrared emission first. You can check it with a cellphone with camera option. Put fresh cells to the remote control, and do the check. Put your cellphone in camera mode, and place the remote control just a feet away from its camera lens and press each button. If there is infrared rays coming from it, the cellphone cameral will sense it , and you can see its image on its screen. You here reports that you can't get it switch on from standby to ON. Keep a special attention when you press the standby button on the remote control and see whether the signals are strong enough with respect when you press other keys on your remote control. if it seems to be week or interrrupted, you have to open your remote control and perform a cleaning process. Check this first and inform me by Fixya.OK.
Posted on Mar 12, 2011
  • The Knight
    The Knight Mar 13, 2011
    Sir
    If these doesn't help you to resolve the problem, and if it is general to all such pbs, what can I do in your case. Nothing at all. OK.
  • The Knight
    Sir
    Just clean your remote control. In some cases when the remote control contacts gets dirty, some of its buttons won't work properly. To do thie you have to open your remote control, It can be done with ease. Just look its sides, and you can find a **** of a space to open it by inserting some shar tool like screwdriver or so. But before do this, remove the battery from it battery compartment. Open it by suitable way, without damaging its cover.
    Soak a cotton cloath with medical quality turpentine, or rectified sprit, or alcohol, and clean its internal touch contacts by rubbing with it. There may be some dirt or dust. It can be removed with this process. Wait for some time, and let evoporate any solvent to be evoporated from the surface of the printed board. NEVER USE PETROL OR ANY OTHER HARD SOLVENTS LIE TO DO THIS JOB. It will damage the rubber parts of the remote control. Reassemble it as it was. Put cells and check.
    Inform me after this Ok.
    President:
  • 1,139 Answers
It is very possible that the tactile switch underneath the power button has become faulty. A little strange as these switches generally last for a long time. As the unit functions normally with the remote it cannot be a fault with the operation of the unit itself but just the power button. If it is under warranty I would contact the manufacturer or retail outlet you got it from and ask for a replacement. If it is out of warranty you could attempt to repair it yourself but to be honest tactile switches come in all different shapes and sizes and are not the easiest thing to replace if you don't have hot air soldering equipment.
If I were you I would give it a go with the manufacturer first.
Hope this helps and thank you for using FixYa
  • Kevin Penn Mar 12, 2011
    It is possible there is a seperate circuit board for those 2 buttons that have become faulty then if it is not a seperate tactile switch. Contact the manufacturer to see if they are able to supply spares for that model
Delonghi Magnifica Rapid Capucinno Power button not working. Hi all, We have a delonghi coffee maker that stops working few weeks ago. The machine doesn't power up. When you plugin into the outlet...
It's quite likely your unit had a blown thermal fuse caused by a bad thermostat. Test them by disconnecting one end and a meter should show continuity if the part is good. The pro's test them in circuit while the unit is plugged in, power showing across the part means it is bad. REPLACE BOTH PARTS TOGETHER.
Jul 02, 2017 | DeLonghi Esclusivo Magnifica ESAM3300...
SONY VPL FX-40 projector. After plug in-ON/Standby LED is red for few seconds and starts flashes in red(repetition rate of 12 flashes). After pressing I/O key-ON/Standby LED flashes in green(few...
A Flashing Red ON/STANDBY LED means one of the following
2 Flashes - The internal temprature is high. Check the air holes are unobstructed.
4 Flashes - The fan is broken
6 Flashes - The internal electrical system has failed.
There is no entry in the manual for 12 red flashes.
Feb 19, 2011 | Sony VPL-FX40 Projector
My flat screen tv shuts off and standby led blinks 13 times.
Our $2700 less than 3 year old Sony LCD KDL-40XBR5 did the same thing 2 weeks ago. Sony was anything but helpful. They said to take it to a repair shop or we could send them $550 and they would replace it with a $800 set. Repairman says that it is a panel and the part has been discontinued by Sony. The 46" sets had the same problem and were recalled but not the 40" screen. We stopped on the way home and purchased a 40"
Jul 12, 2010 | Sony KDL-40XBR4 40 in. LCD HDTV
Compaq F572US won't start (led turns on, but nothing happens)
I have been having the same problem. At first I thought that the motherboard was fried and the laptop was a paper weight, but I kept it plugged in and kept pressing the power button several times over the days. It would always seem to start (screen remained off/black) and then it would just go off again in seconds. But persevarence has paid off, finally almost after a week it started up like normal and started working again as normal. I then had the same episode repeat a few weeks later, the computer was useless for a few days and again started up as I kept pressing the power button several times a day.
I believe the problem is with the standby mode. Each time the problem happened, it seems like the computer was going into standby mode and the power button was pressed again before it could competely go into standby or the button was pressed again while it was coming out of standby.
To sum it up, nothing is wrong with the cimputer components, there is some problem with the standby routine. Keep pressing the power button and hopefully you can get lucky in getting the computer to start again. Long term, I am thinking about checking whether there was a new flash update that came out that could fix this problem. I purchased the laptop compaq F72US in 2008 and never updated anything. Also worth noting that I called HP and they didn't stand behind their product.
Sep 28, 2009 | Compaq Presario F572US Notebook PC
Doesn not want to switch on
i have the same issue with mine and is only 4 months old / this is my second replacment-do u have a contact number for sony?
Jan 17, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
Hi, I have a new tv bought in france a tucson TL32HD782 Led light flashing but tv not working please help
Unplug it for a couple minutes. Try it again. If still not coming on, it's new you say? DON'T mess with it. Return it or call the place you bought if from. It's under warranty......That's the good news.
Aug 17, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
LG LCD TV Standby Light Flashing Red Continuously
I have had this same problem twice in the past 3 months. So far both times I've been able to get it back after a week or two. I'm not sure what works, but unplugging and detaching the antenna and cable and waiting a few days seems to be the key. In both instances, I unplugged it for a few days then plugged it in for a few days and repeated the processes until I eventually got the steady red led. Both times prior to the red led the led would flash red then green and make a clickiing noise for several hours before I was able to get it working again.
Apr 14, 2008 | LG 26LX1D 26 in. LCD HDTV
Sound, but no picture. Standby light blinking 5 times
A few weeks ago my set started flashing to a black screen. Now a couple of weeks later, i have no picture, but the set turns on and i have sound. The standby light is flashing. I purchased the set in 2000 so it is seven years old. This is the first problem. Could it be all three of the bulbs? Could it be all three of the bulbs? no as you say that sound is ok that means your power supply &high voltage section is ok. please check chroma ic luminance section or system control section stand by ckt ihanks
Sep 11, 2007 | Sony KP-53HS10 TV
NAD C545BEE Logo
165 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
