Question about Ricoh Aficio CL4000DN, SPC400DN, SPC410DN, SPC411DN, SPC420DN Black Photoconductor Unit (50,000 Yiel...
Ricoh SPC400DN Getting frequent "Press A
  • 34 Answers
It sounds as if it is not picking up the paper from the tray. It might need new feed rollers. Another thing to check is the lift arms on both sides of the tray. Make sure the springs are still attached to them. There is also a little switch on the left side front of the tray that adjusts the bottom plate pressure. You can try adjusting that to see if it helps.
Posted on Mar 12, 2011
Testimonial: "Springs on left arm are attached. I adjusted plate pressure to Thick and problem seems to have gone away (paper if 20lb, so either setting was ok)"
Factional parablems ricoh aficio 400
it really need to be wrote which specific functional problem is showing, as example SC 541.
Feb 19, 2014 | Ricoh Aficio CL4000DN, SPC400DN, SPC410DN,...
Where is waste toner bottle on spc420
when you will open the right cover all the way to the down, you will see a black big box, inside is the waste toner, it need eater to be replaced or empty from the the toner inside.
Jan 22, 2013 | Ricoh Aficio CL4000DN, SPC400DN, SPC410DN,...
Flatron W1942TQ monitor has "OSD Locked" message
Press and hold menu button for a few seconds, pressing and holding, acts as a toggle. So if OSD LOCKED still appears, pressing again UNLOCKS.
Mar 25, 2011 | LG Flatron L1951S 19" LCD Flat Panel...
How do I reset the "Change Drum soon" Message
Open the front cover
Press Option
Press "1" for yes
after that, close the front cover and you are ready to use again.
Feb 22, 2011 | Brother MFC 7420 All-In-One Laser Printer
Fax Machines Ricoh Fax 4430NF error 0550H "call
Easy !
Press yellow button
Enter numbers: 107
Push red button for 5 seconds
Press number: 1
Enter: 5#810#
Press number: 1
Press (Half)tone and OK button at the same time for some seconds.
DONE ! Greet Barry
Feb 01, 2011 | Ricoh 4430NF Laser Fax
How to open front cover for ricoh aficio c820dn printer as it is displaying message " open the front cover to check the paper jam"
Hi there !
You have to open the front cover means that you have to oper the toner compartment and check for the paper jammed inside.
Did it helps your or you find the paper jammed.
Jan 29, 2011 | Ricoh Aficio SP C820DN Laser Printer
We are getting the following error message when we turn on power. "Functional problem within the Copier. Please call service and report the service code SC552". Ricoh Copier Model MP5001
That is a fuser under heat condition.
Try this. May take a couple of times to clear.
Press the in this order. Clear all ( yellow button) then press 107, then press and hold the red stop button until the screen changes to show a screen that says. Copy SP ,,, Print SP etc.
Press Copy SP, when the screen changes, shut the main power off then back on.
If that doesnt work then repeat the clear all 107 stop and enter Copy SP again, Then scroll down to the 5 tab. press it, scroll to 810 and preform that reset.
If that doesnt fix the problem, then most likely the thermistors and over heat thermostats will need to be replaced.
Jan 29, 2011 | Ricoh Office Equipment & Supplies
Ricoh Aficio 2035e showing "Open Cover" message.
If in the control panel don't show any places or any door, change the switches on the front cover area and the switches of the fuser area. If the problem continuos check the laser area.
Dec 03, 2010 | Ricoh Aficio 2035 Copier
Getting "inner cover is open" message
The inner cover is a flap on the inside in front of the carriage when it is at rest when the cover us open. You had to flip the inner cover down to access the ink cartridges.
Open the cover. The inner cover is in the center and need to be flipped up.
Good luck.
Dec 04, 2009 | Canon Pixma MP500 All-In-One InkJet...
Ricoh Aficio CL4000DN, SPC400DN, SPC410DN, SPC411DN, SPC420DN Black Photoconductor Unit (50,000 Yiel... Logo
288 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
