Question about HP Compaq Presario SR1303WM (PP150AAR) PC Desktop
My Compaq Presario SR1303wm PP150AA cuts off by itself and a little green light on the back starts blinking
    Genius:
  • 1,066 Answers
It could be overheading or it could be a power supply going bad. where is this green light, is it adjacent to the power cord, like on the back of the power supply unit, or is it adjacent to all the ports?
if the light is on the power supply then replace your power supply. if the light is adjacent to the ports, then remove the side cover of the case and blow the dust out of the cpu heatsink (the cpu heatsink is pretty big, usually aluminum, fin array, topped with a large fan). do not touch any microchips inside the computer, and discharge any static electricity before acessing the inside by touching an unpainted part of the case right after you have removed the side cover. if the heatsink is not dirty, and all the fans are working and well ventalated, then it is likely the power supply.
Posted on Mar 12, 2011
Green light on back blinking but can not get it start up
Blinking green light on the back is your network light.
Explain your problem so you can get some help.
Jun 15, 2014 | Compaq Presario 5000 PC Desktop
Compac computer won't turn on and the power light blinks constantly what can i do to fix this problem
Does it beep? if it does, whats the beep pattern...ie long long short, or short short short
if nothing else, something is causing a short...check the usb ports (real common) the contacts break from wear and short out, have your power supply tested.
Aug 20, 2012 | HP Compaq Presario SR1303wm PC Desktop
I have a second-hand compaq sr1303wm and it was unplugged before it was shut down. Now when its plugged in, the green light in the back is blinking but the cpu will not come on.
if it has a power button on the back of the power supply just turn it off and then unplugg it for about 5 mins then plugg it in and turn on the power supply again before you use the computer power button. if this wont work replace the power supply. this could be costly to fix since you could have fried the cpu when it was unplugged but start and the beginning.
Jan 29, 2011 | HP Compaq Presario SR1303wm PC Desktop
What kind of strongest vedio card can you put in a compaq presario sr1303wm
Hi, mandonut1
Video cards nowadays require a powerful psu if your psu can handle it. Since a HP Compaq Presario SR1303wm have an agp
slot. Agp slots are old now you can find one but you can only play games that require minimal power. this one is the best that i could find
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6076197&CatId=2234
Hope it helps,
Thx
Banaple
Sep 03, 2010 | HP Compaq Presario SR1303wm PC Desktop
Compaq presario Sr1303wm power will not stay on...but when I unplug the p7 power supply wire from the motherboard it does stay on...please help.
What does the P7 connector control? How many wires come out of it and what are their color codes? We should be able to fix this. Write me back.
Nov 30, 2009 | Compaq Presario sr1303wm Computer - AMD...
My power switch won't turn on and a green light on the back of the computer is blinking when the red switch is on the 115 and stops when on the 225. What do you think is wrong?
First off, the red switch is for 155 or 220 volts and should not be adjusted or moved from its position.
Now, disconnect the unit from its power source and allow to set for 3 minutes.
Re-install your power connection and do not push the power switch.
Look in the rear of the unit at the power supply and see if you have a green light.
If so, push power and have fun.
If not, you will need to most likely replace the power supply.
Good luck..
Nov 24, 2009 | HP Compaq Presario SR1303wm PC Desktop
Got a used Compaq Pressario SR1303wm and need to set up correctly
Monitor into Small Blue connector at back.
If Mouse and keyboard are Round and not Rectangular in shape then that's a PS/2 Mouse and keyboard. Purple goes into Keyboard slot at back. Green goes into Mouse at back. Watch for the design as the pins inside each one need to be inserted accordingly.
If they ARE rectangular then that is a USB connection. On the back connect the keyborad and mouse to the top two. Again, only going to insert one ways.
Jun 26, 2009 | HP Compaq Presario SR1303wm PC Desktop
Compaq presario sr1303wm not powering up
Try another power cord first to be sure; if that doesn't works, then replace the power supply.
Apr 17, 2009 | HP Compaq Presario SR1303wm PC Desktop
I have a Compaq SR1303wm and I unplugged it yesterday and I plugged it back in toay and it won't power up. There is a little flashing green light in the back and it making a little clicking sound
Yep--you need a new power supply. Get one that is the same size (they mostly are) and probably 350Watts. That should do it.
Measure it before you go to the store to be sure it's the correct size.
Or, better yet, take the old one with you.
Apr 14, 2009 | HP Compaq Presario SR1303wm PC Desktop
HP Compaq Presario SR1303WM (PP150AAR) PC Desktop Logo
409 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
