I have an lg 42LD550 tv. My charter remote and Motorola DVR work fine with it except for 2 things. I have to stand directly in front of the TV (short distance) to turn it off with the Charter Remote and I have to stand directly in front of the TV to adjust the volume with the Charter Remote. Otherwise guides, etc. work fine from anywhere in the room at any angle. I have tried codes 363, 113, 116, 102, 004, 106, 112, 119, 127, 145, 243, 284 and nothing worked.
4 Suggested Answers
SOURCE: MY REMOTE WILL NOT CHANGE CHANNELS ONLY TURNS TV ON OR OFF
After much trial and error, we discovered a temporary fix. We taped a 3 x 5 index card to the front of the box directly to the right of the time/ channel number. The remote will change both the channels and the sound level with this "fix." Could there be some kind of emission coming from the box that interferes with the remote? Maybe Motorola could put a more opaque front on the box.
ympm
Posted on Jan 22, 2009
SOURCE: Trouble using Motorola DCH6416 HD DVR with standard def. tv
I fixed the problem! I found a posting on a message board by someone who had the same DVR and a similar problem. This person found a way to access a secret menu in the DVR to override the format which is automatically assigned. I followed the same steps to access the menu on my DVR and then tried changing a few settings until I found the ones that worked--changing the automatic setting from OVERRIDE to STRETCH and changing the output setting from 1080i to 480p. (It's pretty pathetic that no one at Charter could fix this problem!) Here is the link to the posting that I used: http://www.avsforum.com/avs-vb/showthread.php?t=1132766
Posted on Oct 02, 2009
  • 24 Answers
SOURCE: charter remote will not change
You will need to program it to your cable box to change channels. Remember, the channels in your tv are coming from your box, so if the remote can't control the box, you won't be able to change channels. Call charter for help on programming remote to cable box.
Posted on Jan 29, 2011
I have problem with LG TV 42LD550. After power up I see just first screen "Live Good" with no time on it and that all. Remote doesn't work, buttons on TV don't work. What can I do?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Dec 20, 2014 | LG 42LD550 42 in. TV
42LD550 hdmi no signal
hi have you tried factory reset if this don't work you may have to go into service menu and reset the tv back to when you first brought it, to do this, there's 2 sequences you have to do 1 press hold menu on the remote and menu on the tv for about 10 second , if this don't work try this one, press and hold ok on the remote and ok on the tv for about 10 seconds you see a menu pop up scroll to reset but you have to retune the tv in again hope it helps
regards
shaun
Jan 04, 2014 | LG 42LD550 42 in. TV
The other day my plasma was on and everything was fine. Connected to it is a charter DVR. Suddenly the picture and sound went out. I have a PS3 also hooked up to it and it displays and sounds fine. I...
Most likelly it is your DVR that has a problem. Their are a lot of issues with those DVR's from the cable or satellite companies. I would recomend swapping it out.
Jun 08, 2011 | Panasonic TH-50PX60U 50 in. Plasma HDTV
LG 42LD550 LCD - Internet connection problem
After the network is connected to the TV, you have to go into the TV’s network menu to complete the setup process.
If you look in your owner’s manual starting on page #55-#57, you can read the direction to walk you through the wired network setup process.
It should be very easy to setup as long as your router has the DHCP turned on. That allows the TV to automatically assign it an IP address on your network.
If the DHCP is not turned on in your router, then the TV’s IP will have to manually entered by you.
May 20, 2010 | LG 42LD550 42 in. TV
Motorola cable box/dvr/remote problem.
I have the same problem. Any solutions out there?
Dec 09, 2009 | Motorola Televison & Video
Oct 01, 2009 | Motorola Televison & Video
Need remote code for LC420SS8
SEARCHING FOR YOUR CODE
If your home entertainment device does not respond to the remote control after trying all of the codes listed for your brand, or if your brand is not listed at all, try searching for your code.
For example, after trying all of the codes for your TV, you still cannot get the remote control to operate your TV, then:
Turn on your TV.
On the remote control, press TV once. Then press and hold Setup until the key blinks twice, then release Setup.
Enter 9 - 9 - 1- 1. The TV key will blink twice.
Note: Substitute 1 with 0 if searching for a Cable code, 2 if searching for a DVD, VCR or PVR and 3 if searching for an Audio device.
Press Power and aim the remote control at the TV and press CH + one or more times until the TV turns off.
NOTE: In the search mode, the remote control will send IR codes from its library to the selected device, starting with the most popular code first.
Press Setup once to lock in the code. The TV key will blink twice.
To search for the codes of another device, repeat steps 1 to 5, but substitute the AUX key for the auxiliary device you are searching for.
Apr 05, 2009 | Sylvania LC420SS8 LCD TV
Dvr not working
take the box itself to your locale charter office then they are more likley to give you a new one. worked for me
Jan 12, 2009 | Arris DCT6200 DTV Receiver
Tivo DirecTV Remote-Program AKAI LCT2721AD
Try this: On the Tivo remote press and hold the TV Power button and the Directv/TIVO button at the same time. Hold both buttons down for about 4 seconds or until remote light stays red. Then press the channel up button until the tv turns off. You may press the button over 100 times. You need to go slow. When the TV turns off press the enter button (or select button).
Dec 09, 2007 | Tivo DirectTV Remote Remote Control
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
