Question about Compaq Presario SR1103WM-B (PC183B#ABA) PC Desktop
Blue Screen my operating system appears to have crashed it will not respond to F8 to open in safe mode I only get a blue screen stating A problem has been detected and windows shut down to protect my computer. Technical Informaition: Stop: OXOOOOC1F5 It is a Gateway I purchased about 12 months ago. Robin Douglas when i log on i get stop: oxooooc1f5 a blue screen i can get into advance startup options by pressing f8 but when i tell it to go into safe mode i get the same blue screen please help me
  • Anonymous May 04, 2009
    While installing SP 1 Vista, my laptop crashed.  I have now purchased a Mac.....LOVE IT!!!, but do want to fix the Dell Inspiron 1525 since I don't
    like the Virtual Machine on the Mac.
    HELP!!!!  Would like to save what I have.  Do not want to re-install the OS and would appreciate all suggestions, preferably from someone who had a similar experience with Microsoft.
  • 876 Answers
You could try turning the computer off at the switch when this happens. Sometimes it is a very temporary problem. You would need to wait a few minutes then turn it back on and restart your computer.
Posted on Aug 01, 2008
I have a Asus G73JH Windows 7 64 bit operating system. Frequently it crashes into the blue screen of death and subsequently when i try to restart it. I get the select proper boot option error. Upon fu
press F8 on bootup and select SAFE MODE. try to login and do normal things. if this works then this is probably just a driver or application issue. if SAFE MODE doesn't work, this is probably a hardware issue.
Start your computer in safe mode Microsoft Windows Help
Mar 27, 2014 | ASUS Computers & Internet
My laptop go on then blue screen then turn off
There is one solution for your BSOD problem and it's free,, As soon as you turn laptop on, keep tapping F8 until another screen appears,, then choose safe mode with networking.
Type tdsskiller.exe into google and download from the first site listed. Download the exe not the zip.
once downloaded install to your desktop. Once installed open tdsskiller and run a scan,
Once scan is complete select cure. Once cured, Please reboot your system and you will have no further blue screen errors.. Hope this helps and please rate,,
Mar 08, 2011 | HP Computers & Internet
Blue screen appears at start up boot screen and restarts again
press "F8" while statrting , and then select "safe mode"
Feb 01, 2011 | Computers & Internet
Can't boot
Have you tried changing the boot order in bios? press the F8 key (usually) when you boot up. Set to boot fron CD. Then reinstall operating system
May 29, 2010 | Toshiba Portege M400 PPM40U01000E Tablet...
Blue screen appears and windows has crashed
Boot into safe mode by pressing F8 repeatedly as the computer boots until you get to the advanced start up menu. Choose safe mode and either roll back your video driver or use a system restore point.
Jun 02, 2009 | E-Machines eMachines Desktop PC
Blue screen appears on start up and has no icons on screen cannot do anything does anyone know what this is
What is your operating system if it is XP then press the F8 key repeatedly when you switch the machine on.
This should put you into safe mode
If you can achieve that then go to Start,Programs, Accessories System Tools, System Restore and try to restore it back a week or so.
Blue Screen is a memory crash so it could also be a problem with the Ram or a conflict
May 21, 2009 | Asus Eee Pc 701Sd Notebook
Stalled screen, openning 75 windows at a time, dead blue screen
Reboot and while its rebooting keep tapping on F8 to go to Safe Mode. Once in Safe Mode select "Last known good configuration" and press Enter. If that doesn't work continue to go to Safe Mode and do System Restore to an earlier date of before this happened
Jan 31, 2009 | Microsoft Windows XP Home Edition
Dell 1501 inspiron laptop blank screen
Have you installed any application/program prior to the blue screen? Most blue screen causes your system not to boot to your operating system anymore. It is possible that your hard drive is crashed due to a virus infections or spywares. Incompatibility and corrupted system registry may affect your system to have blue screen as well.
You may try the following steps below.
1. Restart your computer. After you pressed the power button to restart. Keep on tapping F8 key on the keyboard on and off.
2. Boot advanced option will show up on the screen. You may boot your computer to the following option.
a. Last known good configuration
b. Safe mode with Networking.
If Safe mode w/networking works, restore your computer to an earlier using the system restore features.
Keep me posted.
Regards,
jeff
Oct 18, 2008 | Dell Inspiron 1501 Notebook
Blue Screen
Is this still under warranty? If not then you'll just need to buy another HDD (hard drive device) and connect that one where the old was. Re-install XP or Vista. Conact Gateway or go to the Gateway web site to see what was hardware was supported for your system.
HDD IDE/EIDE or SATA/SATA II
OS XP or Vista
After you find out the info just install the new HDD, and install the OS. I only recommend doing this since you can't even get into the Safe Mode. When everything is back up and running you can also re-attach the old drive to what is called Slave or CS (cable select) this is more automatic process. Then you'll be able to recover any data missing that you need that was on the older drive.
Jul 30, 2008 | Gateway GT5404 PC Desktop
Blue screen
A blue screen means operating system error. Your operating system will have to be either repaired or reinstalled using your recovery disc or operating system disc. A blue screen can also occur with a hard drive failure/crash. It's about 50/50 between system error and hard drive failure. If you have any issues or problems during or after the repair/reload of the operating system, then it's the hard drive and it will need to be replaced.
Jul 07, 2008 | Dell Inspiron 8600 Notebook
Compaq Presario SR1103WM-B (PC183B#ABA) PC Desktop Logo
349 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
