Question about Bosch AquaStar 2400ES-NG
Can you change the bosch 2400e lp over to n gas
See the distributor ,they should be able to supply the required regulator.
I have an earlier model Bosch tankless water heater. my instruction says mine can.
I would assume that yours should be also.
Good Luck.
Posted on Mar 13, 2011
Hotwatervariesinuse
probably the chamber is burned out --- call Bosch with the problem and they will walk you through the sequence of testing. Call them
Mar 13, 2014 | Bosch & Tankless LP Hot Water Heater
The water wont get even warm its just plain cold! we have tried uplugging it we have tried turning the hot water on and off to restart it as it says and non of this is working!!! we have a bosch GWH...
The gas flame igniter is not working properly.
Go to the link below and type in your model or select it and the instructions take you through the gas pressures and so on.
Feb 02, 2011 | Bosch AquaStar 2400ES-NG
Our Bosch 2400E NG tankless water heater is displaying the EC code. I've checked the ionization electrode (rubbed it with a pencil eraser as instructed once before when we had this problem) and I also made...
Had same problem on my five year old water heater (ec error). Didn't figure it was a gas supply problem after five years but double checked to see if the gas bill was paid. It was.
Cleaned the contacts on the two sensors that are clamped to copper pipes inside. Still had error after powering up. Held the error button in for about five seconds, and the blinking EC code went away.
May 21, 2010 | Bosch AquaStar 2400ES-NG
Bosch 2400E-NG output temp fluctuates
This is a great heater. It is however crucial that it be installed to every detail of the manual. If there is trouble send pictures to Bosch tankless you can call 1-800-283-3787 ask for Bosch Tech support or go to boschhotwater.com click find a contractor and call the closest Bosch Service Provider most will travel.
Mar 04, 2010 | Bosch AquaStar 2400ES-NG
Bosch Aquastar 2400E LP Does Not Heat Water
Sounds like the water flow sensor and servo, may just need cleaning, get it checked out by a Bosch agent
Nov 10, 2009 | Bosch AquaStar 2400ES-NG
I have a gas bosch water heater (2400E) that keeps shutting down and has to be reset. It shows code A3. What is this code? What do I do to correct this problem. Call the installer. I have had the unit...
you should contact the installer....4 months old should still be under their installation warranty. I looked at the site and it does not mention an A3 code...
Oct 18, 2009 | Bosch Water Heaters
My bosh 2400E LP waterheater fails to ignite often and I have to reset it. At the moment it will not fire up at all. It has run sporatically but not consistantly in the two years it has been installed.
You may very well have a defective thermocoupler. It id the bulb that sits at the tip if the pilot flame. It neeeds th be changed out. Good Luck
Oct 15, 2009 | Water Heaters
Bosch 2400E EC code
it sounds more like the gas valve, you can taje the numbers off of it call or e-mail the compant and buy a new one,,, the thermal coupling keeps the piliot lit but i don't get it RECONDITIONED, I have been doing plumbing for 34 years now and to get a water heater thats reconditioned it would probobly be cheaper to buy a new water heater with this kind of problem good luck
Apr 17, 2009 | Bosch AquaStar 2400ES-NG
Bosch AquaStar 2400ES-NG  Logo
67 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
