Question about Refrigerators
Punctured inside bottom of chest freezer, now it wont work. how can it be fixed?
  • Refrigerators Master
  • 43,501 Answers
Sorry, but you punctures a refrigerant line and the system lost the freon...
To fix this the bottom would need to be cut out of the freezer and then the lines fixed and the system recharged...
Considering the cost of a new freezer... you will be better off to replace the freezer rather then doing that much work to it..
heatman101
Posted on Mar 12, 2011
How could i fix my ref i was able to puncture it? .. how could i fix it?
you cannot fix a punctured evaporator coil. The cost is not economical and the repair is unreliable. best consider another fridge.
Jun 20, 2014 | Kelvinator 12 cu. ft. / 340 liter Chest...
Inside water dispenser is leaking
If your chest freezer is showing signs of age, it may begin leaking. There are a few methods for troubleshooting faulty chest freezers but knowing some of the obvious signs of why it might leak can be very useful if you need to fix it yourself. Leaking is not limited to older models so be aware that certain maintenance procedures can help prevent leaks in newer models.
Understanding Changeable Parts Prior to Troubleshooting There are not that many serviceable or changeable parts inside a chest freezer. A chest freezer works on a very simple basis. It contains evaporator coils, condenser coils, a compressor, a compressor overload, a relay and a thermostat. These are the basic moving parts of a chest freezer but some of them are not serviceable.
The condenser coils condense the water and the evaporator coils disperse excess water caused by the freezing process. The compressor is a heating component which compresses excess water and recycles it through the system.
Defrosting Remove the contents of your chest freezer and place them in an alternative area to keep them frozen. Unplug and defrost your chest freezer before you do any troubleshooting or maintenance. Wipe and clean the inside of the freezer so that when you plug it back in it, will free of any grime or loose bits of debris. A clean freezer will also help to promote visibility when it comes to fixing leaks.
Where is the Leak? Once you have defrosted your freezer, you need to establish which part of the freezer the leak is coming from. It could be coming from the inside of the freezer and this would indicate a thermostat issue. Alternatively, it could be coming from the freezing unit at the back of the freezer. Water always finds a way to escape so your leak could be restricted to one place but the actual cause could be elsewhere. Locate the drain tube which is normally found at the back of the freezer. You will probably have to unscrew or unclip the backing panel.
Check the Drain Hole If the drain hole on your chest freezer has become blocked for any reason, you will need to clear it thoroughly to continue getting the best performance from your chest freezer. The drain hole is a component within the lower works of the freezer through which excess water runs to be recycled.
Compressor Issues Your chest freezer contains a compressor which evaporates the excess water from the freezer. The freezer will defrost excess ice and the water flows down the drain tube to a pan where the heat of the compressor evaporates the water. If your compressor has failed, the leak will be caused by the water failing to evaporate. Have a repair contractor replace your compressor or, if this is not cost-effective, you may need to buy a new freezer.
Thermostat If your freezer is not freezing at all and is dispersing water in several places, you may well have a thermostat failure. Check that your freezer is cycling correctly prior to making changes or altering the thermostat. Only if the freezer is not cycling are you likely to need to change the thermostat. If you have checked all the parts of your freezer and you still cannot locate the leak, calling in a service technician might be the best answer.
Hoping this will help to solve the problem....
Aug 18, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Water leaking inside around the drain from the freezer, water collects in the bottom under the drawers
Defrosting
Where is the Leak?
Compressor Issues
Thermostat
Hope this will help in solving the problem...
Aug 04, 2011 | Amana ATB1504AR Top Freezer Refrigerator
Water freezes in bottom freezer and then leeks onto floor
Defrosting
Where is the Leak?
Compressor Issues
Thermostat
If your freezer is not freezing at all and is dispersing water in several places, you may well have a thermostat failure. Check that your freezer is cycling correctly prior to making changes or altering the thermostat. Only if the freezer is not cycling are you likely to need to change the thermostat. If you have checked all the parts of your freezer and you still cannot locate the leak, calling in a service technician might be the best answer if you can not handle it yourself..
Do take care in solving the problem....
Jun 28, 2011 | Amana Refrigerators
While clearing out frozen rubbish out of the base of the chest freezer I've slightly punctured the lining, can I still use the freezer?do I need to put body filler into it.
Yes, you need to patch the hole right away with epoxy. Before applying the epoxy make sure you sand and clean around the punctured area to give the epoxy a rough surface to adhere to. Turn the freezer off and wait for it to achieve room temperature before applying the epoxy.
Dec 29, 2010 | Refrigerators
Water is dripping from bottom of chest freezer, also some condensation on side,
dear sir/madam
i think yor freezer.s inside insulation has been damage or warn out so please contcet to your freezer maintenance personnel for replace it .
hope answer the question
thank you
please vote!
Jul 12, 2010 | Whirlpool 10 cu. ft. / 283 liter Chest...
Kenmore chest freezer wont cool
Hi.
Here is a tip that will help you...
There are also more tips at the bottom of this one...
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
heatman101
Feb 26, 2010 | Kenmore 8.8 cu. ft. / 249 liter Chest...
I have a GE chest freezer and the exterior green light has started flashing. The freezer is less than a year old.
Is this just a "Power-on" light to let you know it's plugged in and has power? This is probably just a "neon" (although the actual gas inside is hydrogen for the green color) bulb and sometimes they will do the flickering thing literally forever. In a way it's a good thing as it makes you look at it. If it really concerns you, or if it is actually a warning that something is going wrong (it should say in the manual, you DO have the manual don't you?) have it fixed under the warranty.
Jul 07, 2009 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Freezer not freezing!
try plugging the electric cord into a receptical
Feb 18, 2009 | Zanussi 5.76 cu. ft. / 163 liter Chest...
Rust On Bottom Of Chest Freezer
id sand it paint it with white rustolm and go from there and no it couldn't there is a layer of foam between the bottom of the outside and in side
Feb 11, 2008 | Freezers
Refrigerators Logo
329 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
