Question about Cub Cadet Garden
Kohler sv720 the starter will turn, then the engine will stall the starter. very hard to get to start. will spit back though the carb. its like the timing is off. thanks Jay
3 Suggested Answers
mickey813
  • 472 Answers
SOURCE: Kohler courge sv720-0010 on cub cadet
SOUNDS LIKE IT HAS SOME BAD GAS YOU MAY NEED TO CLEAN THE CARB AND IT MAY NEED A KIT
Posted on Oct 12, 2009
nova2nv
  • 197 Answers
SOURCE: John Deer L110 with Kohler 17.5hp backfires wont start
This model is known for shearing the flywheel key.
Posted on Nov 14, 2009
Testimonial: "Just as you said - flywheel key had sheard, an easy fix thanks very much."
Have oil spitting out of carb and dip stick fill tube just started doing that on 19 hp kohler courage
if engine is not overfull you have bad rings on piston have to take in to have it done may end up short blocking it witch is cheaper to do replace rings cheaper by far 200.00 per cylinder
Sep 14, 2014 | Garden
Engine not starting
dirty starter take apart and clean it
Jul 08, 2014 | Garden
I have a 2006 cub cadet LT1050 lawn tractor with a Kohler SV720 engine. It will not turn over, I put a 200 amp jump on starter barely turns over, took plugs out turns over good. thought maybe exhaust valve...
Check oil level. If needle/float in carb stick gas can trickle down into crankcase and cause a condition like you listed. I would also check valve lash. If all these are good, check all grounds and connections, grounds, starter, solenoid. Clean all contacts with wire brush or emery cloth, could be electrical. Good luck and happy wrenching!
Sep 12, 2013 | Cub Cadet Garden
Need to find proper carb needle valve settings for case 444 Kohler
This is the Kohler K321 engine.
You can find the service manual here: (14.16 mb)
http://www.kohlerengines.com/onlinecatalog/pdf/tp_2379.pdf
The inital carb adjustment setting procedures start on page 29
Kohler carb low idle 2 1/2 turns from closed Walbro carb 1 1/2 turn from closed
Kohler carb high idle 3 1/4 turns from closed Walbro carb NA
Thanks for choosing FixYa,
Kelly
Jul 08, 2011 | Garden
Craftsman lawn tractor 917.271060w/kohler 15.5 hp engine cranks but backfires thru carb and wont start.
my 15 hp kohler engine backfired while i was using it, now it wont crank and backfires thru carb
Oct 10, 2010 | Craftsman Garden
Hi i have a citreon saxo 1.1 petrol 1124 engine 1997 its bad starting runs rough eractic stalls spits back through carb the cuts outs was running aok before its just started to happen? any ideas...
i know that if it is spitting you need to change the spark plugs, this might also help the bad starting, and also the cut while running.
best of luck
Aug 20, 2010 | 1989 Peugeot 405
Kohler 17.5 HP floods after turned off over night. Gas spits out of muffler when you try to start. It`s hard to start but run fine after engine starts
Probably a leaking float valve. If it has a fuel shut off, use it, and run it out of gas after each use.
If you pull the bowl off the carb, it's the valve attached to the float. cleaning it may help, or replace it.
Jul 13, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Oct 10, 2009 | Garden
Garden Logo
175 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
