Question about Breadman TR2200C Ultimate Bread Maker
I think I may have messed up the clips???
You say don't mess up the clips,... well.. what if I touched them already and bend them upward (which didn't make a difference at all) Is it too late for me??? I loved this machine! What happens now.....?????
Thank you for any info!
JoyceC777@aol.com
  • 25 Answers
No you can reset them again to the original position.
It will work the same unless you break them.
I just killed my TR2500BC that machine just plain stinks.
I replaced it today with a Sunbeam 5891.
Hopefully it will be better but the 2200c is a good unit.
I just don't like the pan holding system.
Posted on Aug 05, 2008
Why do wings tend to bend upward on a plane?
The entire weight of the aircraft is being supported by the wings. Longer wings are designed to bend upwards to support that weight. Due to the curvature of the wings (more curved on top and flatter on bottom) there is low pressure on the top of the wings and higher pressure under the wings. So the wings are actually pulled up into the air by the low pressure over the top of them.
Jan 04, 2017 | Aircrafts
they should be bent away from the walls they are mounted on and if you have tryed this maybe either it has not been bent enough or it has been bent too much when looking at them from the side it should almost be a quarter moon shape. if I where you I would attempt to try a few more times making sure both left and right clips are about the same distance out.
hopefully it will snap into place.
Aug 03, 2008 | Breadman TR2200C Ultimate Bread Maker
Suddenly my screen resolution got huge. how do i go back?
Go: Start -- Control Panel -- Display -- Settings -- To the upper left it says Screen Resolution. Adjust this upward and click "Apply". You may have to toy with it a few times to figure out which one it is actually supposed to be on. But don't worry, there is nothing there where you could mess anything up - after all...its already messed up. :-)
Anyway, if memory serves, going up gives you finer resolution, which makes things smaller. If you get there and its already all the way up, over toward your right, then my memory is backwards.....so just take it the other way.
And look at this as a blessing. You'll know more about your computer than you did. And - its a useful thing to know because if you ever plug your computer into a larger screen (like your TV), you will need to make adjustments here at this screen.
If this is helpful to you, please take a sec to rate me. Thanks!
Don
Mar 24, 2012 | Acer Computers & Internet
My power outlet stopped working in my 2008 jeep patriot after I plugged in an air compressor
Use a testlight to check for power at the outlet. Clip or hold the black lead of tester to the side of the lighter case, and touch the probe to the very back of the socket(don't touch the sides with probe, or you will blow the fuse.) With key on, testlight should be brightly lit. If no power there, check the ground wire and power wire to the socket.
Dec 31, 2011 | Jeep Patriot Cars & Trucks
How to replace headlight bulb in 1987 toyota camra
For an 87 specifically, I don't know the answer, sorry. There were at least 3 designs used in the 93-94 models alone. If it is anything like them, you have to either
- press in the plastic barb clip on the centre of the wiring connector at the back of the globe housing, and pull down on the wiring connector to disconnect it. Then rotate the globe holder anticlockwise and withdraw it. Don't touch the new globe glass with your fingers, or if you have, clean it well with metho. Then installation is in reverse. Or for a different design,
- alternatively, unplug the electrical connector. Then turn the hard plastic cover, at the back of the headlight globe holder, anticlockwise and remove it. Then remove the rubber cover underneath. If you are replacing an outer bulb remove the bulb spring clip, first taking note of how it is fitted. On an inner globe there may be a covering socket over the globe itself. Remove that, and the spring clip underneath. Replace the globe. Installation is in reverse, making sure all bits are in position, and the 'lock' mark on the hard plastic cover is facing upwards.
Nov 16, 2011 | Toyota Camry Cars & Trucks
Have a 4-5 yr old Canon S2 IS PowerShot A75 Digital Camera. The batteries are new &/or charged but the camera won't always work reliably - says to change batres. but if I just open the bat. door...
Sometimes, the lower contacts get bent downward after years of use, causing the batteries to ride low in the compartment, and thus making poor contact when the battery door is closed. Try lifting/bending these interior battery contacts upward, so that the batteries ride higher when inserted.
Oct 29, 2011 | Canon PowerShot S2 IS Digital Camera
It keeps turning on and off by itself
try using a rubber eraser on the contacts of the battery, phone and sim card. the contacts on the phone protude upwards so do not rub them sideways as they will bend!. rub quiet hard on all the contacts.. the sim card can come loose if you have maybe dropped it , so ensure the slide or clip is holding it firmly in place. if it is a plastic clip that you lift up to remove the sim, slide it up first and after cleaning make sure it is slid back down to hold it in place. if the clip comes off it is no problem to click it back on to the small lugs then replace the sim card don,t, force it you will see the sim has a piece cut out of one corner and it can only go in one way! .look at it before removing it to clean. if it a sim that comes out the side push it in to loosen it will pop out a little then remove etc.. hope this helps, regards terry
May 23, 2011 | Cell Phones
My philips dvdr3510v player is not opening tray its saying blocked how do i solve the problem
This seems to be a manufacturing problem. When the disk is loaded it is centered on a spindle and to make sure that centering succeeds a magnet mounted to a small white rotating plastic piece on the top of the DVD drive. The magnet seems to bee too strong on my machine so the spindle isn't able to disengage when trying to open the tray. The result is blocking. It is of course possible that the electric motor moving the tray and the spindle movement is too weak. Anyhow this is how I solved the problem on my Philips Video/DVS DVDR3510V:
1) Disconnect the device from mains power.
2) Unscrew the eight screws holding the top in place.
3) Unscew four black screws keeping the DVD unit fixed to the main body.
4) Carefully drag the DVD slightly back which allows you to rotate it to point sideways (this allows simpler testing of the mechanical working).
5) Unscew the two blank screws keeping the front half of the top of the DVD unit in place.
6) Using a small screw driver carefully bend the clips to allow the top plate to be removed.
7) Connect the mains power and don't ouch anything inside.
8) After startup try Eject/Load several times to ensure that the DVD unit is mechanically working OK. If the Eject/Load doesnt work with the top off there is no use going further.
9) Disconnect mains power.
10) Use a small felt tipped pen to mark the face of the small metallic (magnet) part in the center of the white movable component fixed to the top.
11) Using a small flat screw driver carefully open the clips holding the two halves of the white component together. Careful! The clips may break easily.
12) Cut small pieces of tape (or use thick drawing paper). The idea is to lift the magnet slightly upwards. We thus use tape or paper as shims. Notice that a hole is needed in the center.
13) When the shims are in place put the magnet back oriented correctly (if you didn't mark it test it against the spindle rotating the disk. The correct orientation is where the magnetic force is strong.
14) Mount the halves back into the hole in the top component and align the clips. Then press the halves together until the clips connect.
15) Put the top component back and clip it into place. No need to screw in the screws yet.
16) Connect mains power, don't touch anything inside.
17) Check that the tray now opens both with a disk and when empty. Check that a DVD is recognized correctly (too little pressure leads to disk loading failure).
18) If the DVD unit now works assemble it and you are done.
The first picture shows the white round plastic part that is modified on the left hand side of picture.
The second picture shows an additional support I glued to the top with super glue because the top is fairly flexible. Initially I thought this was the reason why the spindle got stuck. I think the extra support is unnecessary but i didn't bother with removing it.
Dec 29, 2010 | Cameras
LG KP500 Touch Screen Not Working
Gently bend it like you're trying to split it with screen facing upwards or squeeze around the camera. Amusing solution but it works. recalibrate your touch settings afterwards (menu>settings>touch settings) for perfect operation
Nov 01, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Wiper blades
hi from uk to remove wiper blades? lift the wiper arm off screen to fully up then turn wiper blade upwards so as to make letter T then if you look at the horseshoe type bend on the arm? where blade fits you will see a little press clip which is part of the wiperblade fitting/securing ? to this blade u section just press clip in with finger and at same time push blade downwards out of the u part of arm then you can refit new blade/s the drivers and passenger wiper blades are different lengths when you fit new blades be sure the clip locks into place ? hope this is clear instructions to understand ?
Nov 16, 2008 | Hyundai Motor 1998 Accent
Breadman TR2200C Ultimate Bread Maker Logo
75 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
