Question about Whirlpool Home
We have a profit jetted bathtub that will not shut off. Do you think it is the push button switch and how difficult is it to change?
  • 80 Answers
SOURCE: i have an Eljer jet bathtub with a smell to the water when we bat
What you smell is algae forming in the pipes. If you have small black particles in the tub when running the jets, it is algae. Fill the tub with hot water, add 2 teaspoons of cascade dish soap and 1/2 cup bleach. run the tub for 15 minutes and drain. fill tub with cold water, run for 15 minutes and drain, tub is now ready to use. repeat as necessary.
Posted on Aug 19, 2009
  • 80 Answers
SOURCE: Bathtub Whirlpool button isn't working when pushed
It sounds like a bad air switch. This switch is located on the pump/motor, and is usually found at the end of a clear piece of tubing going to a box on the pump/motor, the other end of the tubing is connected to the push button on the tub. The replacement switches are avaliable through online parts companies. The best thing is to pull the pump and open the box with the switch in it. I have replaced the switch without pulling the pump/motor, but it is difficult and requires plenty of room. If you are not comfortable with doing this repair, call a reputable spa repair company.
Posted on Sep 06, 2009
tunde007
  • 2382 Answers
SOURCE: Kohler jacuzzi, whirlpool bathtub will
Hi, first check the air switch hose that connects to the "button"
Open the access for the pump there should be 1/4" poly tubing (probably clear) that connects to the pump motor. It just slides over a barbed nipple usually located somewhere on the back of the pump housing opposite the pipe connections. Make sure it is in place properly. If it is in place then look else where. The tubing also connects to the back of the air switch "button". This button connection rarely fails, especially if the tub was working and now does not. But if the tub is newly installed and may have disconnected during installation. this connection is probably going to be difficult if not impossible to verify since it is usually concealed after installation.
Some pump motors have resets some do not. If it does it probably is on the very back of pump oppositethe pipe connections.
Also check to make sure that any electrical outlets in the bathroom, or any where in a nearby radius of the tub, to see if they have "GFI" reset buttons and make sure that they havn't tripped by pushing in the button between the plug-ins named "reset". Usually the circuit for the pump will be tied into one of these switches to add ground fault protection to the circuit.
If your pump is not working after checking these things it may be dead. Does your pump "hum" after pushing the button? Do you smell any type oder around the pump that would suggest a "burnt motor"?
If the pump is dead you will have to replace it.
Posted on Nov 07, 2010
jyackle5
  • 8197 Answers
SOURCE: I have a Gemini jetted bathtub (Model LM94161) and
Ok you will need to make sure that the air tube from the switch to the motor is atached on both ends. Also you might want to replace the tube. The reason why is if it has a small hole in it it will not work because the air is leaking out the tube.
Posted on Feb 27, 2011
  • 96 Answers
SOURCE: I have a Royal Whirlpool
You have a bad neumatic switch. Or a small hole in the air line. Try pushing the button fast and hard to see if it will stay on. if so , it is a hole in the tube. if not it is your neumatic switch
Posted on Mar 24, 2011
Testimonial: "perfect! Thanks for your help"
Why do jets turn on, then shut off?
the motor protection device is sensing to many amps. could be a flow restriction or the pump motor bearings are going bad.
Mar 06, 2016 | Jacuzzi Home
Mirolin jaccuzzi tubs
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
US Parts Center
Jan 28, 2014 | Home
Jets won't pump water
Air Switch Repair
US Parts Center
Jan 19, 2014 | Whirlpool Pearl Navarre 7242 True Bathtub...
I have a Royal Whirlpool bathtub. After I fill the tub with water, I push the button for the jets to start and the jets only work while i am pushing the button. The button is a air button. Feels like I am...
Mar 23, 2011 | Home
Pushed button to turn on whirlpool - hear motor - jets don't work
if the motor just hummed then it is likely a bad motor. you will need to replace the pump at that point. Bathtub buttons like the one you have either works or they do not. there isn't any in between areas.
May 31, 2010 | American Standard Cadet Corner Bathtub -...
RapidHeat In-Line Heater U395000 [ Bathtubs and Whirlpools,: My jacuzzi tub jets run for ONLY about 5 minutes b...
you have a bad motor - when a motor overheats there is a sensor inside the motor that will shut if down so as to not damage the windings and such. once your tub has cooled down for 10 mins or so it will turn back on. the fact that you can push the button multiple times just means that you are turning the air switch on the back of the motor on/off until you get to the point where the motor has cooled down and will turn back on. if you do not push the air button after the tub shuts down and you finish your bath then when the pump cools down it will come back on because the air switch in the motor is latching i.e. it is either on or off. Since you left it in the on position the motor will come back on once the motor has cooled down.
May 17, 2010 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Only used my Royal whirlpool bathtub about three times
My jetted tub will not work, and it used to work just fine. Nothing happens when i push the button to turn it on. Could this be a switch problem? Also do not hear the motor doing anything when button is pushed. Dou you think I just need to get a new pump??
Dec 30, 2009 | Home
Bathtub Whirlpool button isn't working when pushed jets do not turn off...
Aug 29, 2009 | Home
Home Logo
164 people viewed this question
Top Whirlpool Home Experts
Craig Butler
Craig Butler
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
