My laptop wont boot at all. i turn it on the light comes on and goes back off unless i leave charger plugged in then the light stays on but nothing else happens. i cant do anything not ctr alt del or f8 or anything. im in need of help.
  • 56 Answers
Most likely your battery is bad and giving incorrect voltage to the system. Try removing the battery and leaving the charger plugged in. Some laptops will run off only the charger so it may help verify if it is the battery.
Posted on Mar 12, 2011
    Scholar:
  • 155 Answers
It may be the battery draining all the current and not allowing the motherboard to receive enough power to boot.
Can you please remove completely the battery and try to boot again?
Please let me know more details and I will guide you to the next step.
Best regards
Won't boot up without primary screen.
2 Beeps sometimes refers to memory problems. Try re-seating.
Sep 28, 2012 | Acer Ferrari ONE 200-1799 Notebook
Compaq presario v6101uswont boot not even start up screen
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Apr 09, 2012 | Microsoft HP Compaq Presario V6101US...
MODEL LT2016U WONT BOOT UP
Is it trying to boot up or is it doing absolutely nothing when you plug in the power cord and hit the power button?
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Mar 30, 2012 | Computers & Internet
IBM Thinkpad 2647 will not power on , i plug it in to charge and orange light flashes 5 times then stays solid orange . I can leave it plugged in for days and will not change , it will also not turn on...
This is a tricky problem, you need to troubleshoot this bit by bit - first take the memory out one stick at a time and try to turn it on each time, then try the hard drive. If it boots further with one of these things out then you know thats the problem. If it still doesnt boot after trying these components then you need a repair as it will be an onboard component.
My immediate guess would be the onboard power supply unit, unless your charger is broken and you can test with another charger to rule that out too.
Feb 26, 2011 | IBM ThinkPad T20 2647 Notebook
MY BLACKBERRY BOLD 9000 WON'T TURN ON!!! My friend gave me her Blackberry Bold 9000. It's battery was replaced a few months ago but it hasn't been used since then. When I plug it into the wall charger,...
Ok...don't panic. The charger you are using is not compatible. Verizon only works with verizon blackberry's. Non verizon will not work with blackberry and vice versa. This is what will happen. you plug it in and it will boot for a few seconds and then the lightning bolt you see is the charge icon and then a red line in it means that charger is not compatable. Blackberry does make its own charger but there is a "pin" on the plug in that will tell it it is not the right one. Am I confusing you?
Jan 06, 2011 | RIM BlackBerry Bold 9000 Smartphone
My toshiba r10 laptop wont turn on the green power light to the front is on but the yellow battery light only comes onn when i plug in the power cord to it and it only stays about 2 seconds
Ok here's what you will do
1) Unplug the notebook from the ac adapter (charger power cord)
2) Take off the battery pack on the notebook
3) Once the ac adapter and battery is off the notebook, hold down the power button for 15 seconds
4) After 15 seconds, let go of the power button
5) Now plug in the AC ADAPTER (OR CHARGER POWER CORD) ONLY (DO NOT PUT BACK THE BATTERY PACK)
6) Now press the power button once.
7) If the unit boots, the unit suffered a slight surge
8) If the unit does not boot and remains dead, the unit suffered a severe surge and may be burned out and needs replacing
I hope this helps and let me know how it goes afterwards
May 03, 2010 | Tablets & eReaders
Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Mar 07, 2010 | Gateway Computers & Internet
My toshiba 2455-s305 wont boot up
If you are familiar with your laptop, i.e. the locations of hard drive, try to take it out of the its bay and put it back again. Also, if you can have someone check your battery packs, because from my experience with this laptop, when the battery packs is not charging well, i got some booting up problems.
Mar 19, 2009 | Toshiba Satellite 2455-S305 Notebook
NO POWER!!!HELP
Is the voltage meter directly on the Battery?? What model Dell is it?? I have found that on the D800 models for some reason the connection from the power button to the Motherboard comes loose. You need to remove the Keyboard cover to check this.
Jun 06, 2008 | Compaq Evo N610C Notebook
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
