Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Takes a long time to preheat. this is gas. - Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
  • Frigidaire Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Mar 12, 2011
Oven takes long time to preheat
if the oven has a glow bar it,s not staying hot enough to keep the main burner on change the glow bar
Nov 23, 2013 | Whirlpool SB160PEE Gas Single Oven
Maytag gas oven takes a long time heat and smells of gas.
Important---if you smell gas--I'd be very very careful---could be your control valve or lines to it are malfunctioning or leaking. You might have to call in an expert repair person. How old is the oven? Some preliminary checks you might make are: Do you have a pilot lite or preheaters on the unit? If a pilot lite, make sure it is lit. An unlit pilot lite could sometimes give the smell of gas if malfunctioning. If so, there is is a procedure for lighting the pilot lite--check your user or installation manual. If you have pre-heaters make sure they are lighting up. Normally you have one for the top broiler burner, and one for the bottom oven burner. Check your preheater(s) by selecting either broiler or oven and visually checking to see if they are warming up. After 15 seconds or so, they should be turning bright red. You will see some light coming from them. Check one pre-burner at a time. If they do not come on quickly, shut off the associated valve. Again, be very, very careful with any buildup of gas. It could cause an explosion. At the least it could make you sick.
Sep 12, 2012 | Maytag Ovens
My Maytag gas oven is taking a long time to preheat (45min)
Oven not Working or Oven not Heating
heatman101
Apr 15, 2011 | Maytag CWG3100A Gas Single Oven
I have a Maytag Advanced Cooking System (Super Capacity) gas stove. The oven takes an incredible amount of time to preheat & then smell an odor of gas. What could be wrong?
heatman101
Jan 04, 2011 | Maytag Ovens
Oven takes forever to preheat
check to see if both broil and bake elements/gas works
May 25, 2010 | Maytag CWG3100A Gas Single Oven
Slow and uneven ignition on the oven burners that causes the oven to take hours to preheat
MOST OF THE TIME THIS IS CAUSED BY A WEAK IGNITOR.WHEN THE IGNITOR IS WEAK IT WONT PULL ENOUGH CURRENT THROUGH THE GAS VALVE TO OPEN IT UP.SOMETIMES IT WILL OPEN ONLY PARTWAY .GOOD LUCK!
ERIC
Jan 23, 2010 | Viking Ovens
Oven temp takes long time to preheat. Heat is not consistent
gas or electric? if gas, most likely the ignitor. if electric, most likely you lost a "leg" on your electric supply. ie only getting 110 vac needs 220 vac. check breaker or fuse box.
Oct 25, 2009 | GE Ovens
I have a whirlpool range that was purchased 04 2000. last week when i would set it to preheat 350 i was smelling gas and the oven was not preheating unless i set it to 500 and then it wasnt getting as hot...
Hello , sounds like the electronic ignitor has went out , they are not difficult to replace if your willing , the part is around fifty dollars and it should only take about a half hour to replace. please let me know if you have any other questions.
Phil
Jan 08, 2009 | Ovens
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
346 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
