Question about Wells F-67 21167 Deep Fryer
Fryer is heating up very slowly. - Wells F-67 21167 Deep Fryer
  • Wells Expert
  • 684 Answers
Check if the supply voltage is sufficient, oil level is correct or if the heaters are all working.
Posted on Mar 30, 2011
How to remove heating element
In order to remove the heating element of a Cuisinart deep fryer you need to do the following:
1. Unplug the fryer.
2. Tip the fryer and put the oil into a container.
3. Put the fryer on its side, with the open top over the sink and a bowl in the sink beneath it. Leave it this way so most of the rest of the oil can drain.
4. Wipe the inside of the fryer with a paper towel.
5. Put several layers of newspaper on the counter and stand the electric deep fryer upside down on top of the paper. You will see that there are rubber feet under the base held in by screws.
6. Remove the feet and screws and you will be able to take off the base to expose the electrical workings inside.
7. Locate the heating element which has wires leading to it. Start by removing the wires leading to it and then loosen up and remove the heating element itself.
May 24, 2015 | Cuisinart Kitchen Appliances - Others
I have a frymaster sr14esd, it turns on and makes noise but does not heat up. Is it my thermostat?
If the unit seems to be powering up and making noise, then you have power and it doesn't sound like a tripped breaker. About the only noise I would expect would be the element heating up and maybe the oil popping unless there is a fan. What kind of noise is it making? IF you have the equipment & know how, you could confirm power to the heating element or check the load the item is placing on the electrical service. One way to check the thermostat is you can turn the Tstat all the way down, turn on the power and see if you can hear the power engage as you slowly bring the temp setting up.
Nov 29, 2014 | Frymaster Dean 2424G Deep Fryer
Unit is not turning on or calling for heat, why?
sounds like the elements have opened check with an OHM meter
Mar 23, 2017 | Cecilware EL2X15 Deep Fryer
I have a Butterball indoor turkey fryer that lost power and the red light went off, is there a reset button on the fryer
There is a thermal cutoff near the heating element just like all appliances that make heat. It's supposed to stop a house fire but makes these appliance companies a lot of money.
Nov 28, 2013 | Masterbuilt Butterball Professional Series...
I have a Butterball Electric Turkey Fryer that heated up but when I placed the turkey in the fryer the red indicator went off and it lost power , is there a reset button on the fryer
All appliances that produce heat have a thermal cutoff inside to prevent a fire or meltdown. It's a shame they make them so fragile that it may ruin your special occasion. If you cross the wires on the sensor it may run forever but might be a fire hazzard.
I have a deep fryer. The heating element does not
Probably the heating element or the control has failed.
Feb 16, 2018 | Ultrex 607-922 Deep Flash - Double Filter...
My bravetti dep fryer F1063B wont heat up
In the back of the unit there is a recessed reset switch(red) Depress it until it clicks.
Dec 24, 2008 | Bravetti EP4305FS Deep Fryer
Bravetti Deep Fryer-Model EP65
I have Bravetti Platinum Pro Deep Fryer model EP65 but my heating element was damaged, I debating to sell parts or try to find a new heating element.
Apr 01, 2008 | Bravetti EP4305FS Deep Fryer
DEEP FRYER WONT HEAT
have you tried taking out all of the oil and washing it realy good I know that mine wasnt working and thats what i did and it started heating up again
Feb 18, 2008 | Bravetti EP4305FS Deep Fryer
Wells F-67 21167 Deep Fryer Logo
Top Wells Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Raymond Koonce
Level 1 Expert
Dennis Boxerman
Are you a Wells Kitchen Appliances - Other Expert? Answer questions, earn points and help others
