Question about Watches
My pulsar watch is too small..need extra links for it number on back of watch 990520
SOURCE: Armitron watch band needs extra links
I just called the main headquarters and they sent me 2 links for FREE!!! 1-800-840-2933 my model # for my watch is 20/1897T1 found on back. Hope this helps :)
Posted on Jan 08, 2008
SOURCE: remove the extra links in a luminox 3204 watch band
It was nothing more than split pins holding the links together. I pushed them out removed the links and pushed them back in.
Posted on May 13, 2008
escapement
  • 2334 Answers
SOURCE: i need to remove 2 links on my pulsar analogue watch.
You have to drive out the pins from bracelet.
Split end of the pin must come out first.
Use blunt steel needle as a driving pin and a small hammer.
Posted on Dec 19, 2008
slp11508
  • 43 Answers
SOURCE: Need to add a link to Armatron watch band
You have to call Armitron to get extra links for this watch. You could add them in yourself (if you purchase a watch link remover tool), or you could take it to a jeweler. You could also ask if they have the easy links which just snap on and off available when you call and these can be just snapped on and off without any tools.
Posted on Jan 05, 2009
escapement
  • 2334 Answers
SOURCE: need watch links cartier stainless steel
Unfortunately there is no way to get the link(s) for your Cartier watch without getting in touch with Cartier.
Everything you need you can find here:
www.cartier.com
Cartier is very aware about their products and you will be asked to bring in or send in your watch with supplied documents(proof of purchase etc.).
In case if you do not have the proof of purchase you will be asked too many questions(when you bought it, from who, for how much, etc.) and this can lead even to police investigation as quite many of Cartier made items are stolen(not abuse to you, of course).
So, if you do not have any original papers with your watch, the best solution is to find your nearest watch repair shop and ask for help.
Decent watchmaker allways can find out how to help.
Hope this helps a lot.
Don't forget to rate, please.
Posted on Jan 10, 2009
How do I get extra links for my Pulsar PH7240 watch?
Most any good Jewelry Store can order you extra links, and will likely put them on for you for free.
Jul 26, 2014 | Pulsar Ladies Crystal Watch PH7240
gGo to a watch shop they usually have link pieces laying around.
Watch serial numbers
Model numbers and battery details etc. on Pulsar watches are normally stamped on the back plate but the serial numbers can sometimes be found on the inside of the back plate.
Jan 06, 2014 | Pulsar Watches
I have a Pulsar watch with the number VT33-0A00 on the back along with 540966. How do I replace the battery? Thank you!
mcdevito75 here, While a battery change is fairly easy, you will need a set of precision screwdrivers, you can improvise but could ruin your watch, Look for a small watch repair shop in your area the $15.00 will equal your time, effort, and tools you"d need. Plus the battery lasts a year.
Feb 09, 2011 | Pulsar Watches
Lost stem on watch. can i get replacement? can i install myself?
mcdevito75 Here, Pulsar a quartz watch. If you lost the stem, the mechanism holding it into the watch maybe damaged, this mechanism also turns your Pulsar watch on / off. Best Bet, visit a small watch repair shop in your area, have them take a look at your Pulsar watch. You could replace the stem yourself but first you"d need the right size stem, (hard to get) then if the mechanism holding the stem in is damaged you"ve wasted your time. Your local small watch repair shop can let you know, and they usually don"t charge to have a look.
Feb 05, 2011 | Pulsar PXH227 Wrist Watch
Remove links
  • Wrap the watch band around your wrist to determine how many links need to be removed for the watch to fit properly.
  • 2 Place the watch face-down on a flat surface.
  • 3 Look on the back of the watch band. You will find an arrow that indicates which direction you should push the pins to remove the links.
  • Find the point at which the extra links need to be removed for your watch to fit your wrist. Using a 1 mm flathead screwdriver (or the edge of one side of a pair of tweezers), push the pins in the direction indicated by the arrows.
  • Finish removing the pins with your pliers.
  • Keep the extra links in case you ever need extra room on your watch band.
  • For further assistance, check out the link:
    http://www.pulsarwatches.com/home2.asp#FAQ
    Aug 17, 2010 | Pulsar Men's Stainless Steel Bracelet...
    I need a manual for a Pulsar watch calibur #7T62
    Pulsar are made by Seiko and support can be obtained from their web site. (The number your quoted is a Seiko number- all Pulsar models seem to start with two or three letters).
    Put "www.seiko.co.uk/support/instructionbooklets" into you search engine and you should come to the Seiko instructions list. Scroll down to find your watch and download the instructions.
    Mar 06, 2010 | Seiko Pulsar watch
    Looking for links for bracelet of Pulsar bought 1983
    http://www.pulsarwatches.com/home2.asp#Contact_PULSAR
    Call Pulsar and they can help you find your band number and tell you if links are still available for your watch! :-) They will ship them to you and you then need to take the watch and links to a reputable watch repair company!
    Jan 15, 2010 | Pulsar Watches
    Removing links to shorten watch for a ladies Wallmart watch brand is white stag #Ws50880w
    I just removed links from one of the white stag watches today. The answer is in the link below.
    http://www.watchmaterial.com/How_to_size_a_watch_band.asp
    Friction pins are used to hold the links together. I used a jeweler's screwdriver and a small hammer to tap them out in the direction of the arrow. I put them back in the same way.
    Dec 28, 2008 | Pulsar Ladies Watch
    Watches Logo
    306 people viewed this question
    Top Watches Experts
    Jimmy Accardi
    Are you a Watch Expert? Answer questions, earn points and help others
