Question about Advent Netbook
My advent battery would not charge so i bought a new one and it still wont charge having to run my laptop from the mains
  • 96 Answers
Try to calibrate the battery.
Start your laptop, and let it die (don't plug in the wallet) Reload (off course with the adapter) and do this at least 2 times.
Hope it works.
Posted on Mar 12, 2011
  • Advent Master
  • 4,338 Answers
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
2 Suggested Answers
SOURCE: Advent 7113 doesn't detect mains
It is highly posible that the jack in your laptop where you plug the main dapter is making a false contcat due to a problem in the welding of its connectors to the main board or to corrosion. Check if the rentral plug is not loose or if the plugs seems to be loose when you plug it.
If it is so, you need some expert technician to solve the problem by re weilding it or replacing it.
Posted on Jan 27, 2009
My advent modena m202 will only work through mains power supply. I have a brand new batter which I was only able to charge in my old laptop. so m202 is not charging and wont work with fully charged
If the battery is OK then there may be an issue with the contacts that connect the battery to the motherboard or the regulator on the mother board has failed due to a previously faulty battery, in which a motherboard repair is required.
Jan 12, 2014 | Advent Computers & Internet
How do I replace the main battery in my Advent 9115 laptop and any suggested supplier?
look for the model number of the battery and look on ebay. watch out for cheap batteries since they won't last long.
Mar 22, 2013 | Advent Computers & Internet
Advent 7109b battery wont charge
Yes! it is very possible, specs are different in none original power adapters, because it sounds like the charging circuits are working. I recommend getting the original adapter for your model.
Apr 19, 2012 | Advent Computers & Internet
I bought a new battery for my advent 4490 net book .the battery worked fine on the initial charged tht it already had but now whn the battery is now left with the 9% charge in it , i plug in my charger and...
I I have the same issue and i took my netbook to more than 4 electronic engineers, all of them said that doesnt seem there is a problem in my netbook though.
Mar 31, 2011 | Advent Netbook
Battery does not seem to hold charge on Advent 9115 laptop. 18 months old. Charged overnight. Switches off within half hour of switching on.
Sounds like your battery is dying.
Laptops should not be run on mains power all the time, it kills the battery. Should be run on battery until battery warning occurs, then plug in to recharge.
You'll need a new battery at this stage.
Apr 04, 2010 | Computers & Internet
Advent laptop wont charge up or switch on
Hello
This is a battery problem.But first try charging your laptop with another power cord to see if it works
If it doesn't,remove the battery from the laptop and plug the laptop directly into power if the laptop comes on,that means that the battery is dead and you should get a new one
Thank you for visiting fixya
Mar 06, 2010 | Advent Netbook
I have an advent 8315 thta will not charge up. don't know if it is the charger or battery pack. Any advice as to where to get a cheap replacement.
Can get universal power supplies for about a tenner on ebay.If it wont charge but runs on mains it will prob be the battery
Jan 19, 2010 | Advent Netbook
It runs fine on mains power but will not run at all on battery despite apprently being fully charged.
Your battery cell unfortunately seems to have run dry. The most favorable solution is usually to get a new battery for your computer.
Nov 13, 2009 | Advent 4211c Notebook
Advent 4211 battery light flashes orange mains power only
Yeah the same has happened to lenovo x61s, i contacted the supplier and they told me i need a new battery, unfortunatly laptop atterys arnt the cheapest things around
Jun 07, 2009 | Advent 4211c Notebook
Advent 7016 (AKA Gericom Blockbuster 251S)main
It was the BATTERY all along !!!!! Incidentally the new battery bought mail order from China was no good as it would not boot-up the laptop. The curious thing was that if the laptop was booted-up using mains power, the Chinese battery would then last long enough to play an entire feature film and more! The "Tech Guys" test battery was also no good and the technicians at that well known computer store claimed that the laptop was faulty, WRONG! Eventually I bought a scrap laptop of a similar type with a view to swapping the power controller board. The scrap laptop happened to have a battery fitted so the "scrap" battery was tried. Voila! all came good! After THREE dud batteries (including the test battery at the computer store) the problem was solved.
One can surmise that during the boot-up, computers take a heavy power draw. One can also surmise that the Lithium Ion batteries have current limiters built-in in order to prevent them from catching fire. If the current limiter is set too low the laptop will not boot. Those 2.8 GHz Pentium 4s were always renowned as hungry power-guzzlers and that was the problem.
The sad thing was that once it was all fixed-up, defragged and memory maxed-out, it got stolen in a burglary. Shame as it was a really good machine. These days I ONLY buy crappy low powered computers as why donate an i5 or i7 machine to your local drug addicts?
Feb 18, 2009 | Compaq Armada M700 Notebook
Advent Netbook Logo
362 people viewed this question
Top Advent Computers & Internet Experts
Lee Durbin
Lee Durbin
Computer Links
Are you an Advent Computer and Internet Expert? Answer questions, earn points and help others
