Question about Cobra 150 GTL DX Base CB Radio
Help me my radio died
Bought new had it converted at local radio shop. guy insisted i have it tunned up also so i did worked great for 3 months then started to break up modulating and loses power now recieves ok but does not transmit at all. someone please help!!!!
    Problem Solver:
  • 6 Answers
Not a good radio once its tuned up they turn up the audio to hi thats makes it clip when talking..the radio is at factory setting when you get it,95%modulation..any more will cause problems.all you can do it have it set back to thr org. setting and then check the driver buffer and final transistors one may have blown due to improper tuning...good luck doc's cb shop ny
Posted on Aug 19, 2008
I took it to a shop and the guy said it's the distributor and module. Something about fiberoptic cable that is over heated. I thought it was cadilitic converter so I tooked it off and punched it out, did...
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 17, 2011 | 1997 Mercury Villager
Bought radio at Hamfest. Hooked it up worked flawless. Great ability to fine tune signals. Let a tech talk me into installing echo board. He tried two new boards. They wouldn't work. Told him never mind ,...
The guy who was really not a tech probably didn't hook the mic wires back to the mic jack correctly. that will cause the radio not to TX or RX.
Next time make sure the tech knows what he is doing, and check on line for cb radio shop blacklists to make sure that one isn't on the list.
This guy owes you either a new radio, or pay to have that radio repaired.
If both echo boards didn't work, he doesn't know what he is doing, because he put them in wrong.
Oct 17, 2010 | Ranger Communications RCI-6900F-25 CB...
Does radioshack offer cb radio tunning?
Not all but some I would suggest that you find your local CB Radio shop and go there or a HAM Radio shop any of those will be able to help you.
Feb 21, 2010 | Radio Communications
Battery died for no reason
About the only thing you can do is disconnect the battery and connect them again after 5 minutes. If that do not work check for blown fuse. Other than that then the XM radio has been damaged by the charger.
Nov 14, 2009 | 2006 Buick Lucerne
Hoover Vacuum works, then stops in 3-5 mins. Works again in a couple of hours
sounds like the motor is overheating .check and see if the brush roller is turning when its on.if its hard to turn or won't turn at all take it back where you bought it and insist on a new one.my thoughts on new items is if you buy something new then it shouldn't have to be fixed.insist on it.please leave feedback...pete
May 04, 2009 | Vacuums
No radio reception on 2003 Audi A-4 Cabriolet Convertible
After reviewing the feedback on these postings I identified the problem them took it to my local car stereo shop. I showed them how by raising and lowering the trunk the signal went in and out. They fixed it for $60 by splicing in some new coax cable. It works great.
Dec 14, 2008 | 2003 Audi A4 Cabriolet
Local Electronics Repair Shop said there is no product support for this machine.
Sorry, when they die they are dead (it's too expensive to work on them) ... welcome to the disposable society. On the other hand a replacement can be had for a few $ on www.ebay.com or www.craigslist.com.
Apr 22, 2008 | RCA DRC8295N DVD Recorder/VCR
Philips 355 display
you must bargain your cp
Dec 19, 2007 | Philips 355 Cellular Phone
My ipod stopped working
Yes, it is possible for a battery to die, though 2 or 3 months is a bit short. If you have some way of proving the date of purchase you should be able to take the iPod to an Apple store and talk to one of the "Genius" guys. If it is a battery it should still be covered under warranty. If it isn't covered under warranty, they will be able to get a replacement battery for you which would be cheaper than buying a new one. Hope that helps!
May 07, 2007 | Apple iPod mini M9160LL/A MP3 Player
Cobra 29 NW LTD does nothing
Why do you have to fix it? If the local CB shop looked at it last then take it back to them its their problem.
Mar 28, 2007 | Cobra 29 LTD CB Radio
Cobra 150 GTL DX Base CB Radio Logo
143 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
