Question about Samsung P2050 Monitor
My samsung P2050 monitors menu has been lockd, now i cant set up my monitor setings. Please tell me how to unlock it
  • 1,591 Answers
On: If you press and hold the MENU button down for 5 seconds, the OSD Adjustment Lock
function is activated.
Off: If you press and hold the MENU button down for 5 seconds again, the OSD Adjustment
Lock function is disabled.
That should FixYa.
Posted on Mar 12, 2011
How do I turn off the Samsung sync-master p2050 monitor?
If it doesn't turn off by holding the power button down for 10 seconds, then it cannot be turned off by the power button alone, like most modern lcd monitors. Most modern monitors goes into standby mode. To completely cut power, you must unplug the power cable.
I've enclosed a link to the install manual for reference.
Samsung SyncMaster P2050 User Manual Page 7
Nov 24, 2014 | Samsung Computers & Internet
Osd main controler lockd
Hi there.
OSD Lockout or On Screen Display Lockout message is that irritating on-screen message that sometimes pops up when you switch on your monitor. This completely locks all monitor settings.
This problem has most likely happened to everybody at some stage or another. Everything has worked fine until now you turn on your monitor and have a message glaring you in the face displaying something about "OSD Lockout". This doesn't allow you to change any of your monitors settings, including the setting intended to turn off this message. While this problem mainly happens on HP monitors from my looking around I know that others have encountered it on other brands as well. The fixes I provide below should work on those monitors too so don't fear if your monitor isn't an HP model.
The HP Fixes
FIX 1
Plug in the monitor and power it up. Hold down the monitor's Power button until you get a message saying "OSD Unlocked". If the problem persists after OSD is unlocked then unplug the monitor from the wall, wait a few seconds (just to be sure I'd give it anything around 20-30 seconds) and then try again.
FIX 2
Instead of holding down the Power button, turn on the monitor and hold down the Menu button for 10-20 seconds. This should unlock the OSD.
FIX 3
Turn off the monitor, press down the Menu button and then turn on the monitor. Wait 10-20 seconds. This should unlock the OSD.
FIX 4
The Menu button may be stuck in a pressed in position. To get it "unstuck" you'll usually need to open up the monitor. If your not a seasoned veteran at opening up electronics (and knowing where all the screws go back into) then this could be tricky unless you know what you're doing. Unfortunately there are too many models of monitors for me to give a step by step instruction guide for you. If you have warranty this is where you should use it, I suggest you contact the manufacturer.
The AOC Fixes
FIX 1
Turn off the monitor, hold menu and power button together for 10 seconds then turn back on.
Currently these are the most commeon fixes.
~ Slasher_X
Sep 28, 2011 | Philips 190B6CB/27 19" LCD
We have a samsung syncmaster p2050 monitor and a dell tower but the screen does not stay on to enable you do anything pls help to identify if its a monitor problem or a dell problem?
At a guess it's probably a monitor problem but the only way to be sure is to test the theory.
You need to beg, borrow or steel another monitor and connect it to your tower, if it works Ok, your monitor has the problem, if not, its your graphics card.
Or, if you can't borrow a monitor, ask if you can connect yours to a friends tower or even a laptop with a vga port on the back (blue 23 pins).
With the laptop, you should be able to switch between the laptop monitor and the ancillary monitor by pressing the "Fn" and another key (look amongst your "F" keys and your Number keys, there should be a picture of a screen). Don't forget to switch back by pressing the same keys again.
Aug 19, 2011 | Samsung P2050 Monitor
Problem is i cant adjust colour and size because of showing "LOCK
This is how:
OSD Lock & Unlock
When pressing the AUTO button after locking the OSD
When pressing the MENU button after locking the OSD
This is the function that locks the OSD in order to keep the current states of settings or prevent others
from adjusting the current settings.
Lock : Hold down the MENU button for more than five (5) seconds to activate the OSD adjustment
lock function.
Unlock : Hold down the MENU button for more than five (5) seconds to deactivate the OSD adjustment
lock function.
User manual:
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_cd=&prd_mdl_name=2233BW&prd_ia_sub_class_cd=P
Apr 23, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
How to to reset monitor setings ?
press menu highlight reset press select .then select ok and press select your monitor settings will reset
Apr 14, 2010 | LG Flatron Ez T710BH 17" CRT Monitor
I have dowloaded drivers for samsung syncmaster P2050 but still cannot get the resolutions to adjust
Your monitor doesn't require any special drivers to work properly. If your monitor is a widescreen monitor, your video card needs to be able to address the monitor's resolution, not the other way around. You'll need to either update your video card's drivers to obtain different resolutions, or you'll need to replace your video card with a newer one that does widescreen resolutions. Good luck!
Jan 14, 2010 | Samsung P2050 Monitor
I cant unlock osd of my samsung monitor , sync master 551v
Please try again to turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu. regards
May 27, 2009 | Samsung SyncMaster 151 N 15" LCD Monitor
How to unlock the control lock in my monitor?
hold menu button for 10 secs for 753df
Dec 30, 2007 | Computers & Internet
Samsung P2050 Monitor Logo
369 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
