Question about Edimax ES 3105P (ES-3105P) Networking Switch
I'm using an edimax es-3105p fast ethernet switch and i'm having troubles connecting a second computer. all the slots are working as i have verified it by connecting this computer on every slot.Internet is working and all the cables work too.
  • 96 Answers
Do you use the right ports.
So the 5th is for a extra switch/rouer.
Posted on Mar 12, 2011
Only power light goes on when I reconnect to electricity. WLAN and LAN lights stay off
It sonds like you are ethernet connected to the Edimax from your home computer. Can you access a wireless connection? If so Try This:
Unplug the ethernet connection between the PC and the router. Exchange the connection (The ethernet connected to the PC place it in the Edimax and Put the connection from the Edimax into the PC) Check to see if you have a connection light on both devices.
Reboot you Edimax and PC. First turn on the PC and let it power up to the desktop. Once the PC is on then power on the Edimax. Now check to see if you have a connection. If these steps don't work I suggest you try replacing the ethernet plug connected between both devices.
Aug 14, 2012 | Edimax EW7416APn (EW7416APN) Pre80211n...
FS605 V2 5-port Fast Ethernet Switch 10/100 Mbps setup
Try repairing second by right clicking on network icon. Make sure drivers are ok in Device Manager. To verify IP's on machines use ipconfig /all from the command prompt. Get there from Start > Run > type cmd.
Aug 04, 2012 | NetGear Computers & Internet
On my edimax es3116p when 1 pc is connected the other remaining pc cannot connect how to fix
Well the problem is probably due to the fact that you are trying to share a 1mb/s connect. Thats not a lot of bandwidth even for 1 computer. So when you have multiple PCs all fighting for that 1mb/s you will certainly have slow or what appears to be n connection. Now if your second PC is not getting an IP address well then you probably have an issue with DHCP.
May 11, 2012 | Edimax ES 3116P (ES-3116P) Networking...
Edimax ES 3105P 5 port ethernet switch. I am wondering if in some way it is possible to manually reset this device. Because on the outside of the box there arent any reset buttons. I have set up my...
hi there; your switch hub has no reset button, only router has a reset button for factory default, you can only reset it by unplugging the power adapter, router has WAN connection try to check your other device, thanks ,,,
Sep 21, 2011 | Edimax ES 3105P (ES-3105P) Networking...
Can I connect Ethernet to the internet without router
This is possible a few different ways:
-Connect the switch directly to the modem and each computer, then pay your ISP for extra IP addresses for each computer, if they will allow it. Make sure that you secure each computer with proper firewall/security software as it will be directly exposed to the internet. This method typically will not work with ADSL or any ISP that uses a PPPoE connection.
-Install two ethernet cards in one of the computers. Connect the switch to one ethernet card and the modem to the other, then enable internet connection sharing.
-Acquire an older computer with two ethernet cards in it and install free linux based router software such as Smoothwall to create your own homebrew router that has all of the features of the pricy linksys/netgear/etc. routers and then some.
May 01, 2011 | Edimax ES 3116P (ES-3116P) Networking...
Edimax br6204wg wan led doesn't light up and there is no internet connection
Hi yaminmagdi,
I believe that you are trying to get connected wireless using your Edimax Router, we may need to check some settings in your Edimax regarding the wan light not lit up and could be a possible reason why there is no internet connection.
1. First we will need to find an Ethernet cable for us to be able to connect your Laptop directly to your Edimax Router for us to be able to check and change any settings needed to enable your Edimax wireless connection. also make sure that the Ethernet cable is connected to the Ethernet ports behind the Router not the WAN port then the other end goes directly to your Router.
2. Once connected directly to your router from the Laptop open IE or any Browsers on your Laptop, in the Address bar type in 192.168.2.1 then press Enter this will prompt for a user name and password, User Name will be ' admin ' and the password should be 1234 unless you changed it.
3. Inside the Edimax setting page click on the Tab that says Wireless, check and see if the wireless is enabled if not then enable it or turn it on, after enabling / turning the Route ON save the settings by clicking on Apply or Save then it will prompt that the Router is restarting it will be 30 seconds to apply once the 30 seconds is up that should be done check your Edimax if the WAN light is already lit up, then you can try an connect Wireless from your Laptop.
I hope this helps.
Have a nice day.
Apr 03, 2011 | Computers & Internet
Problem with internet when using LAN
You have to set-up proxy setting for the same thing
If both your system is having Win xp then please activate internet connection sharing which is there at the network properties
or you can install 3rd party proxy also
just chek with ping uitlity weather it can ping with each other
Mar 14, 2009 | Edimax ES 3108P (ES-3108P) Networking...
Connecting the switch to LAN
How old is the switch, check other ports,how many ports do you have? what model switch do you have?how long has this been going on?what computer do you have and what OS are you operating with?
May 27, 2008 | Edimax ES 3108P (ES-3108P) Networking...
Loss of link packets
Auto-negotiation, or duplex mismatch problems are common between 10/100 and 1Gb devices. Make sure the driver on your computer's ethernet adapter is up-to-date. If that doesn't help, you may need to try an inexpensive D-link or Linksys 10/100 switch.
Jan 08, 2008 | Edimax ES-5800S Networking Switch
Edimax ES 3105P (ES-3105P) Networking Switch Logo
165 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Michael Vincent Cruz
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
